Do winglets produce thrust?
Old November 29th 03, 05:25 PM
Eric Greenwell
Bruce Hoult wrote:
But the spar does not have to deal with the extra lift on a *long*
moment arm. Well not all of it anyway.
Hmm ... well a deliberately non-lifting horizontal section at the tip
would reduce induced drag as well.
This could be done for one angle of attack, but I don't see how it could
be done for the usual range a glider uses. A winglet has the same angle
of attack, independent of the wing.
Replace "SPAM" with "charter" to email me directly
Eric Greenwell
Washington State
USA
Old November 29th 03, 05:36 PM
Nyal Williams
At 07:54 29 November 2003, Bruce Hoult wrote:
Eric Greenwell wrote:
Winglets reduce induced drag by effectively making
the wingspan longer.
Perhaps in the past, but maybe not anymo from page
104 of the
Fundamentals of Sailplane Design...
'Subsequently, it has been shown that good results
may be obtained with
relatively small winglets. In contrast to early winglets,
which were
essentially upward wing extensions, recent winglet
designs are optimized
to diffuse the vortex rollup at the wingtip, thus
reducing its strength.
There is also evidence that the velocity field induced
by the winglets
can improve airfoil aerodynamics in the vicinity of
the wing tip by
prolonging laminar flow and delaying separation.'
But the question is, would similar-shaped horizontal
extensions to the
wing have the same effect? What about multiple small
span 'winglets'
off the end of the wing? Birds do that. The modern
winglets look a lot
like a single tip-feather.
-- Bruce
Oh, Golly-gee! In one hundred years we've gone from
bi-planes to bi-winglets!
Old November 29th 03, 05:47 PM
soarski
In my country, our gliders move forward because the wing produces
thrust, and our sailboats move over the water because the sail produces
thrust. Whether we should rule the world is causing much controversy.
PLEASE....Readers of the World! This is not in our textbooks! Did
someone in the USA write the above???
Wings produce Lift!! A by product of lift is drag! Winglets do also
produce lift, and therefore drag. Possibly less than the wing? But
you canot call it thrust!.......
This sounds like I am in the middle of some ski instructors!
Skiing is great in Aspen!
Think Snow!
The Redtail Hawk
Old November 29th 03, 05:48 PM
Jack
Date: Sat, 29 Nov 2003 18:49:16 +0800
Bruce Hoult writes:
If it wasn't for class rules limiting wingspan I don't think anyone
would have winglets.
I wonder what class rules the 744 design has in mind
Those rules which limit gate space at airport terminals.
Jack
"Heavier-than-air flying machines are impossible."
-- Lord Kelvin, President, Royal Society, 1895
Old November 29th 03, 07:08 PM
Duane Eisenbeiss
"Bob Salvo" wrote in message
Anyone?
Bob
Do winglets produce thrust? (CAN winglets produce thrust?)
All non-believers should read the NACA report by Whitcome, the inventor of
winglets. Winglets are an airfoil and therefore produce lift. If the cord
of the winglet is oriented properly, the lift vector will be angled slightly
forward, hence the use of the term "thrust". Since the angle of attack of
the winglet is influenced by the lift coefficient of the main wing, a
significant amount of "thrust" is only produced at a very narrow range of
angle of attack (aircraft speed). A significant amount of "thrust" is
defined as when the forward component of lift of the winglet is greater than
the drag of the winglet. Since sailplanes are flying at either a slow speed
of near stall or very fast speed, the concept would not seem to be of much
use for sailplanes.
The winglets used on sailplanes seem to use an airfoil which has a large low
drag bucket and are designed more to diminish wing tip vortices. This
results in lower sailplane drag, sometimes better aileron control, and
perhaps at some angle of attack of the main wing some "thrust".
Duane
Old November 29th 03, 07:32 PM
Eric Greenwell
"Thrust", for the winglet question and my remarks about gliders and
sailboats, was used to mean "force in the direction of motion".
Apparently, that was an unusual use of the word for some people.
Here's an expanded expanation:
Gravity is pulling straight down, and so can not propel the glider
forward; drag is pulling the glider back, and so can not propel the
glider forward. So, what is left to counteract the drag? Lift, produced
by the wings. This forward force comes from the lift, which is not
vertical, but tipped forward a bit. Look at any diagram showing the
forces on a glider, and you will see how the lift, drag, and gravity
forces accomplish this.
It is not common to call this force moving the glider forward (without
it, drag would bring it to stop) "thrust", but the word is sometimes
used that way.
I still can't answer the original question about the winglets, though.
Eric Greenwell
Washington State
USA
Old November 29th 03, 08:28 PM
Bob Salvo
If winglets produce thrust, at what angle of attack does its thrust/drag ratio
maximise?
Bob
  #28
Old November 29th 03, 11:39 PM
wsburhen
With the production of levity such as this, winglets are certainly
adding (a) lift to dead of winter soaring in the northern hemisphere -
whether it's literally or figuratively! Bravo.
  #29
Old November 30th 03, 01:25 AM
Nyal Williams
Now, I'm confused! An airfoil cannot produce thrust
-- only 'lift.' But if an airfoil has a reverse counterpart,
the two are joined at the center and rotated about
an axis in a vertical plane, they are then a propeller;
this produces 'thrust.' But if their pitch is differentially
variable and they rotate in a horizontal plane, they
are then helicopter blades; they produce 'lift.'
Why don't we just combine the two words in one concept
and call it 'thrift?'
maximise?
Bob
  #30
Old November 30th 03, 11:56 AM
Keith W
Being a bit of a pedant, I have been trying to find whether the technical
definition of 'thrust' fits here, as my aerodynamics is more than a bit
rusty. I cannot find any book on unpowered flight which shows more than
three forces - lift; drag; weight, and might at best resolve these
horizontally and vertically to label the 'horizontal component of lift'.
Looking at general definitions, I would think that the backward force on the
air below the wings could be defined as thrust, but the notional forward
reactive force on the aircraft resulting from this couldn't! 8-)
Keith
"Nyal Williams" wrote in message
maximise?
Bob
A Level 1 AOA clarification Ramapriya Piloting 64 January 9th 05 01:19 AM
Space Elevator Big John Home Built 111 July 21st 04 04:31 PM
max altitude and Mach 1 Boomer Military Aviation 22 June 1st 04 08:04 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
P-38 Exhaust Stephen Harding Military Aviation 10 April 19th 04 07:03 AM
