"Bob Salvo" wrote in message
... Anyone? Bob Do winglets produce thrust? (CAN winglets produce thrust?) All non-believers should read the NACA report by Whitcome, the inventor of winglets. Winglets are an airfoil and therefore produce lift. If the cord of the winglet is oriented properly, the lift vector will be angled slightly forward, hence the use of the term "thrust". Since the angle of attack of the winglet is influenced by the lift coefficient of the main wing, a significant amount of "thrust" is only produced at a very narrow range of angle of attack (aircraft speed). A significant amount of "thrust" is defined as when the forward component of lift of the winglet is greater than the drag of the winglet. Since sailplanes are flying at either a slow speed of near stall or very fast speed, the concept would not seem to be of much use for sailplanes. The winglets used on sailplanes seem to use an airfoil which has a large low drag bucket and are designed more to diminish wing tip vortices. This results in lower sailplane drag, sometimes better aileron control, and perhaps at some angle of attack of the main wing some "thrust". Duane |
A Level 1 AOA clarification | Ramapriya | Piloting | 64 | January 9th 05 01:19 AM |
Space Elevator | Big John | Home Built | 111 | July 21st 04 04:31 PM |
max altitude and Mach 1 | Boomer | Military Aviation | 22 | June 1st 04 08:04 PM |
Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 06:42 PM |
P-38 Exhaust | Stephen Harding | Military Aviation | 10 | April 19th 04 07:03 AM |
