Earlier, someone named Al wrote:
Did'nt one of these come apart about 4 years ago when the flaps failed and seperated inflight the pilot a young man was killed IIRC. Yes, it's a matter of public record. It was one of three fatal BG-12 inflight failures in the last few years. The accidents of note a http://www.ntsb.gov/NTSB/brief.asp?e...12X21782&key=1 http://www.ntsb.gov/NTSB/brief.asp?e...08X08572&key=1 http://www.ntsb.gov/NTSB/brief.asp?e...08X07996&key=1 The first of those three is the one "Al" cites. The NTSB determined that the probable cause was excess speed beyond the flap deployment speed. I worked at the 2003 Standard Nationals with the late pilot's father, and our conversations had no small impact on my way of thinking about the safety and nature of homebuilt soaring. The second accident was due to the failure of a control push-pull tube element on a ferry flight, the impending nature of which would probably have been evident even in a very casual inspection. One of the conditions of the ferry permit was an inspection of the aircraft by an A&P or similar, but there was no evidence that the inspection was performed. The third accident was a wing separation after several pitch excursions at relatively high speed. The aircraft was substantially heavier than max gross, with a CG out of the aft end of the CG envelope. Dont buy this junk there are better ships out there that are less dangerous. These 60/70's homebuilts are cheap for a reason pay some more and live longer!! There are also better ships out there that are more expensive and _more_ dangerous. But that aside, I have to agree with the general consesus that the social and economic landscape of soaring has changed so that many homebuilt gliders are very far out of their original context. These days, a walk through the ocean of most souls would scarcely get your feet wet. Thanks, and best regards to all Bob K. http://www.hpaircraft.com/hp-24 |
Opinions on Cessna 340, 414 and 421 | john szpara | Owning | 55 | April 2nd 04 09:08 PM |
Opinions wanted | ArtKramr | Military Aviation | 65 | January 21st 04 04:15 AM |
OPINIONS: THE SOLUTION | ArtKramr | Military Aviation | 4 | January 7th 04 10:43 PM |
Rallye/Koliber AD's and opinions | R. Wubben | Owning | 2 | October 16th 03 05:39 AM |
Rallye/Koliber AD's and opinions | R. Wubben | Piloting | 2 | October 16th 03 05:39 AM |
