Are you sure there has not been a misunderstanding?
Which club is this, where was the Assistant Cat course and who was the coach? For the U.K. the B.G.A. give advice to be found in "Laws and Rules for Glider Pilots" 14th edition June 2003: Under "Recommended Practices": "RP13. After releasing the cable, the glider should turn away so that the tug aircraft pilot can see clearly that the glider is free." If you can find out the reason given I should very much like to hear it, since it contradicts the BGA's own recommended practice published just 6 months ago. If there has been a change in doctrine since then I have not heard about it. Apart from other considerations, it is normal to release in order to join a thermal, failing to turn at once could easily lose you the thermal. W.J. (Bill) Dean (U.K.). Remove "ic" to reply. "Stephen Cook" ] wrote in message ... "W.J. (Bill) Dean (U.K.)." wrote in message ... I agree completely with David Starer about what pupils ought to do, and what to do about it if they don't. c. As soon as the cable is seen to release start the climbing turn, and look again to make sure it is safe to continue the turn. It is important that the turn is not started with the rope still attached (this has been known, tug pilots don't like it!). The BGA are now teaching instructors on Assistant Cat courses to climb away from the tug without turning. This was reported by someone at my club who did a course recently. Unfortunately I can't remember the reason for the change. Stephen |
Long Tow Rope Pros & Cons | chris | Soaring | 7 | December 10th 03 02:30 PM |
High tow vs. low tow for rough tows (long) | Mark James Boyd | Soaring | 36 | December 9th 03 07:13 PM |
Tow position, posting and the truth | Bill Wallace | Soaring | 0 | December 6th 03 12:31 AM |
Tow Rope Freindly Fences | John Spargo | Soaring | 8 | September 2nd 03 04:17 AM |
using winch instead of aerotow | goneill | Soaring | 5 | August 27th 03 02:46 PM |
