Bill,
The emphasis of the exercise being taught is that it is not necessary to turn away from the tug. All that is required is to gently decelerate the glider by gently climbing the glider as the tug will accelerate away. This was demonstrated by both Dave Bullock and Simon Adlard on assistant cat courses at Bicester some 3 years ago. The emphasis on turning is not always practical particularly if one has been towed close to a ridge e.g. both aircraft would require to turn away from the ridge - if the glider remains straight on course the tug turning away will result in divergence of both rope and glider. Suggest that if you want to discuss this further that you should contact either of the National Coaches to determine the exact reasoning for this teaching. SRE Scotland & Borders |
![]() "John Smith" wrote in message ... Bill, The emphasis of the exercise being taught is that it is not necessary to turn away from the tug. All that is required is to gently decelerate the glider by gently climbing the glider as the tug will accelerate away. This was demonstrated by both Dave Bullock and Simon Adlard on assistant cat courses at Bicester some 3 years ago. The emphasis on turning is not always practical particularly if one has been towed close to a ridge e.g. both aircraft would require to turn away from the ridge - if the glider remains straight on course the tug turning away will result in divergence of both rope and glider. Suggest that if you want to discuss this further that you should contact either of the National Coaches to determine the exact reasoning for this teaching. SRE Scotland & Borders Thanks for this John. I was going to get in touch with the person on the course before replying to Bill's post. If this has been the recommended method for three years why hasn't it reached the rest of us? Our Chief Flying Instructor makes an effort to get recently qualified instructors to pass on what they have learnt, but there should be a more direct route than this. This isn't the only change to instructional technique that I have found out about on the grapevine. Why isn't there an instructors newsletter? Stephen |
![]() "John Smith" wrote in message ... Bill, The emphasis of the exercise being taught is that it is not necessary to turn away from the tug. All that is required is to gently decelerate the glider by gently climbing the glider as the tug will accelerate away. This was demonstrated by both Dave Bullock and Simon Adlard on assistant cat courses at Bicester some 3 years ago. The emphasis on turning is not always practical particularly if one has been towed close to a ridge e.g. both aircraft would require to turn away from the ridge Other situations also come to mind, for example, traffic or cloud clearance issues may make a turn a bad option. Also it should be stressed that turns after a waveoff depend on the situation; first, it is important to allow the towplane the most direct path to the runway (assume that he really has an emergency) and second, the glider itself may not want to turn away from the runway if it was a low waveoff. Vaughn |
The release without turning is not a recommended method as such and does =
not replace a (climbing?) turn where local club rules require that the = glider turn in a specific direction after tow. The aim , I believe, is = to show that a highly banked and fast climbing turn is not required as = it is this scenario that causes tug upsets when the glider pilot has not = ensured that the tow rope has actually released prior to initiating the = turn. As a tug pilot myself I know which method of release that I would = prefer particularly if the rope hangs up on the glider. If the club = rules specify a particular direction of turn this may be due to the = position of the mirror on the tug or for other similar visibility = reasons. This exercise shows that after the rope is released a gentle = climb is all that is required to achieve separation. It can be combined = with a turn in either direction. |
We don't teach climbing turns on release because of setting up the habit of
slowing down after the release. If the rope breaks, you need that airspeed to make the turn back to the field. If you get in the habit of climbing, you will always climb and slow down. Fred |
Long Tow Rope Pros & Cons | chris | Soaring | 7 | December 10th 03 02:30 PM |
High tow vs. low tow for rough tows (long) | Mark James Boyd | Soaring | 36 | December 9th 03 07:13 PM |
Tow position, posting and the truth | Bill Wallace | Soaring | 0 | December 6th 03 12:31 AM |
Tow Rope Freindly Fences | John Spargo | Soaring | 8 | September 2nd 03 04:17 AM |
using winch instead of aerotow | goneill | Soaring | 5 | August 27th 03 02:46 PM |
