Brian Case wrote:
We have a Pegasus here that was resprayed over the old gel coat. I don't know much about how it was done as it was not done locally. What I can tell you is that nearly every single one of the old cracks in the gelcoat are now showing through the new finish. Do you know what was used for the new finish? Is it gel-coat or 2 part polyurathane paint? If it is paint, what kind of primer went on underneath it? Ian |
polyurathane paint? If it is paint, what kind of primer went on underneath it? Ian It is not a 2 part polyurathane paint. I suspect it is Gel Coat on top but I can't say for sure. Brian |
Commercial Glider refinishing book | Martin Carolan | Soaring | 0 | December 15th 03 09:41 AM |
REFINISHING | Ventus B | Soaring | 32 | December 3rd 03 10:14 PM |
Older glass glider refinishing question | Gus Rasch | Soaring | 6 | November 10th 03 12:18 AM |
Refinishing Your Aircraft (now in Oregon) | aerocomposites | Home Built | 0 | September 24th 03 05:29 AM |
Tracon II Shortcut key for "THEN" | Jack Frost | Simulators | 0 | August 17th 03 02:54 PM |
