I have worked on several gliders over the past 25 years where the =
gelcoat cracks did indeed propagate down into the glass structure. One = in particular was an ASW-15 where we had to zip off the entire outer = layer of unidirectional glass in order to remove all of the cracks. = These were crazing cracks over the entire surface, not stress cracks = from load (crashing,etc.). A severely cracked LS-4 comes to mind as = well. With good light and a jeweler's loop, we have noted a good = handful of other ships that had localized crazing that had gone down = into the structure. Speaking of down under, the Australians have noted = this problem and issued an "AD" (or whatever they call it) concerning = this. Paul |
Commercial Glider refinishing book | Martin Carolan | Soaring | 0 | December 15th 03 09:41 AM |
REFINISHING | Ventus B | Soaring | 32 | December 3rd 03 10:14 PM |
Older glass glider refinishing question | Gus Rasch | Soaring | 6 | November 10th 03 12:18 AM |
Refinishing Your Aircraft (now in Oregon) | aerocomposites | Home Built | 0 | September 24th 03 05:29 AM |
Tracon II Shortcut key for "THEN" | Jack Frost | Simulators | 0 | August 17th 03 02:54 PM |
