50+:1 15m sailplanes
Old December 22nd 03, 07:21 PM
Chris OCallaghan
It's been a few years, but if memory serves Gerhard said that the 27
wing could manage a Finesse (best L/D) of 100, that is, if he didn't
have to hang a fuselage off of it. However, most glider pilots like to
fly their aircraft in the first person, so he compromised and got a
Finesse around 46. The Diana, on the other hand, took the road less
travelled by and decided that pilot comfort (or in my case, presence)
were not critical marketing factors. Based on that philosophy, I
wouldn't doubt that a determined engineer could achieve a Finesse of
50+ for a 15 meter glider. However, we've learned that best L/D is a
poor means of judging sailplane performance. It is the flatness of the
drag curves on both sides of the intersection that really determine
the worth of your glider. A polar free of a low speed bucket and
relatively flat increase of sink with speed make a great glider. Might
the poles have found a new trick? A more stable high aspect ratio
airfoil that needs less tail? A better fuselage/wing transition?
Improved laminar control? Perhaps.
Paul T wrote in message ...
'DuckHawk 15m racer announced at 2003 SHA Western Workshop.
53:1glide ratio VNE 200 kts' -from Winward Performance
- anyone got anymore details?
'SZD-56-2, Diana 2: Newest 15-meter Sailplane.The technologically
advanced SZD-56-2 Diana 2 will soar on new wings next
summer. Bogumil Beres, chief design engineer of the
Diana and owner of Biuro Projektowe 'B' Bogumil Beres,
recently announced the design project of a breakthrough
Diana 2, featuring a curved wing platform with a continuously
varying airfoil and high-performance winglets. The
original Diana fuselage will be retained, but with
a lower drag fuselage-wing junction. The wing loading
range will be 6.08 - 11.7 psf. Most remarkably, the
Diana 2 will break the long-standing 15-meter glide
ratio barrier of 50/1 with room to spa forecast
performance includes a max L/D of 52/1. The prototype
Diana 2 wings will fly next August. Diana 2's will
be delivered in the Spring of 2005.'
Have the Germans got something to worry about?
Old December 23rd 03, 11:56 AM
Robert Danewid
There were 2 SZD56 flying in the worlds in Sweden in 1993. They
performed nice but not astonishing. One of them even had a minor midair.
A year later or so we had one (modified) exhibited at the Annual Swedish
Cliding Conference, and as Chris writes, the cockpit were not built for
nice looking guys from the West, but supposedly for thin, starving
pilots from the eastblock...... (now that has thank God changed!)
Moffat once wrote: there is no substitute for span! If you want 50+ go
for an 18m or larger ship, if you want nice handling, easy rigging etc,
it is easy to trade in som finesse-point to achieve that in a 15m glider!
Robert
H304
Old December 23rd 03, 05:00 PM
Bob Johnson
Just to keep stuff straight, while Mr. Moffat has certainly expessed
from time to time his fondness for span, I believe "there is no
substitute for span" quote comes from Michael Bird ("Platypus") who used
to "tinsfos" us quite regularly in S & G (Brit mag) from across the pond
Of course I could be wrong ..
BJ
Robert
H304
Old December 23rd 03, 09:05 PM
Ian Strachan
In article , Bob Johnson
writes
I do not think that Plat would claim credit for this saying which,
regarding straight performance, has been extant in gliding since I
started in the 1950s.
It refers to the "easiest way to increase performance" (max L/D I
suppose), contrasting the relative simplicity of adding span compared to
the complexities of adding flaps, new airfoil sections, new
configurations, etc.
In my own case I remember the Grunau (about 13m I think), good in a
thermal but not in a glide, a sort of ancient PW-5. After the Grunau, I
progressed through the 15m Meise (well the UK Olympia version anyway) to
the Skylark 2 (laminar 15m) to the Skylark 3 & 4 (18m) and finally
through various syndicates from 15 to 18m to the Nimbus series, starting
at 22m and now 26 in the Nimbus 4DM, twice the span of the dear old
Grunau.
As far as I am concerned, "there is no substitute for span". In UK
soaring conditions, anyway, if you wish to avoid landing "aux vaches".
Our vaches may not be very vicious but our roads (for retrieving) are
Ian Strachan
Lasham Gliding Centre
UK South
Old December 24th 03, 12:07 AM
Robert Danewid
Ian, I thought your "aux vaches" was the M in Nimbus4DM......
Robert
writes
at 22m and now 26 in the Nimbus 4DM, twice the span of the dear old Grunau.
Old December 24th 03, 05:20 AM
wsburhen
The quote that I've seen attributed to Plat concerning tinsfos is
something to the effect of:
"There is a substitute for span, it's called skill, but you can buy
span"
Old December 24th 03, 02:18 PM
JJ Sinclair
span"
OK, it's 7:00 PM, the sky has been completely overcast for hours, you have
5000 feet and your looking at a 50 mile final glide. Now SKILL your way home.
A very mery Christmas to all my RAS buddies.
JJ Sinclair
Old December 24th 03, 09:53 PM
Robert Danewid
JJ, negative thinking - use the force!
Robert
span"
JJ Sinclair
Old December 25th 03, 10:42 PM
Eric Greenwell
span"
You don't grasp the concept, JJ: with skill, the pilot is 50 miles out
at 6 pm, not 7 pm, and gets home just before all the lift dies.
Since I can't buy skill either, I bought a motor.
Old December 25th 03, 09:33 AM
Paul T
Here's the figures on the American DuckHawk (got to
be one of the most awful names for a sailplane) from
the promo sheet.
Windward Performance LLC takes its advanced technology
to the racing class.
Specifications
Empty Weight 300 LBS
Gross Weight 900 LBS
Wing Span 49.17 FT
Wing Area 74.93 FT^2
Aspect Ratio 32.2:1
Length 20.6 FT
Horizontal Span 6.8 FT
Vertical Height 4.5 FT
Structural Limits
+11.0 / -9.0 g’s
Va, Vb = 165 KTS
Vne = 200 KTS
Performance
At 500 LBS, 6.7 Lbs/FT^2
Best Glide 50:1 at 50 KTS
Min Sink 94 FPM at 40 KTS
Stall Speed 35 KTS
At 900 LBS, 12.0 Lbs/FT^2
Best Glide 52:1 at 67 KTS
Min Sink 122 FPM at 57 KTS
Stall Speed 47 KTS
(data for 900 LBS, 12 PSF)
Airfoils
Inboard 12.7 % t/c
Outboard 10.2 % t/c
The DuckHawk has the broadest wing loading range available,
the highest maneuvering and redline speeds, and the
lowest inertias for snappy handling. The lower flying
mass within the 15m span constraint gives an induced
drag advantage of 49% at 500 LBS and 33% at 900 LBS
(span loading squared) compared to the competition
Time will tell - my money is on the Diana 2 which is
a development of the SZD-56-1 Diana. (Whose cockpit
is bigger than a Ventus a!). Incedently at Leszno they
were also talking about an 18m version and 22m Open
class version.
sailplanes for sale Jerry Marshall Soaring 1 October 21st 03 03:51 AM
