I don't see it on their web page..
BT "Paul T" wrote in message ... Here's the figures on the American DuckHawk (got to be one of the most awful names for a sailplane) from the promo sheet. Windward Performance LLC takes its advanced technology to the racing class. Specifications Empty Weight 300 LBS Gross Weight 900 LBS Wing Span 49.17 FT Wing Area 74.93 FT^2 Aspect Ratio 32.2:1 Length 20.6 FT Horizontal Span 6.8 FT Vertical Height 4.5 FT Structural Limits +11.0 / -9.0 g's Va, Vb = 165 KTS Vne = 200 KTS Performance At 500 LBS, 6.7 Lbs/FT^2 Best Glide 50:1 at 50 KTS Min Sink 94 FPM at 40 KTS Stall Speed 35 KTS At 900 LBS, 12.0 Lbs/FT^2 Best Glide 52:1 at 67 KTS Min Sink 122 FPM at 57 KTS Stall Speed 47 KTS (data for 900 LBS, 12 PSF) Airfoils Inboard 12.7 % t/c Outboard 10.2 % t/c The DuckHawk has the broadest wing loading range available, the highest maneuvering and redline speeds, and the lowest inertias for snappy handling. The lower flying mass within the 15m span constraint gives an induced drag advantage of 49% at 500 LBS and 33% at 900 LBS (span loading squared) compared to the competition Time will tell - my money is on the Diana 2 which is a development of the SZD-56-1 Diana. (Whose cockpit is bigger than a Ventus a!). Incedently at Leszno they were also talking about an 18m version and 22m Open class version. |
I hope that they will give the wing a bit more AOA related to the
cockpit/fuselage. The Dianas I have seen always had bad visibility in the landing approach and in high speed the tail always hang a bit low in the airstream. One of the factory guys from Poland told me in Borlaenge, that the performance could be increased by fixing that problem, but these days they had no money to do so. The design shows some clever features, but I heard German designers having some doubts if the glider really would pass all JAR requirements. CHo "Paul T" wrote in message ... Here's the figures on the American DuckHawk (got to be one of the most awful names for a sailplane) from the promo sheet. Windward Performance LLC takes its advanced technology to the racing class. Specifications Empty Weight 300 LBS Gross Weight 900 LBS Wing Span 49.17 FT Wing Area 74.93 FT^2 Aspect Ratio 32.2:1 Length 20.6 FT Horizontal Span 6.8 FT Vertical Height 4.5 FT Structural Limits +11.0 / -9.0 g's Va, Vb = 165 KTS Vne = 200 KTS Performance At 500 LBS, 6.7 Lbs/FT^2 Best Glide 50:1 at 50 KTS Min Sink 94 FPM at 40 KTS Stall Speed 35 KTS At 900 LBS, 12.0 Lbs/FT^2 Best Glide 52:1 at 67 KTS Min Sink 122 FPM at 57 KTS Stall Speed 47 KTS (data for 900 LBS, 12 PSF) Airfoils Inboard 12.7 % t/c Outboard 10.2 % t/c The DuckHawk has the broadest wing loading range available, the highest maneuvering and redline speeds, and the lowest inertias for snappy handling. The lower flying mass within the 15m span constraint gives an induced drag advantage of 49% at 500 LBS and 33% at 900 LBS (span loading squared) compared to the competition Time will tell - my money is on the Diana 2 which is a development of the SZD-56-1 Diana. (Whose cockpit is bigger than a Ventus a!). Incedently at Leszno they were also talking about an 18m version and 22m Open class version. |
I seem to remember a wonderful letter in Sailplane and Gliding in which
the writer noted that, when he first started gliding in his twenties, average glider LD ratios were around 1:20's. In his thirties, this rose to 1;30's and, at the time of writing, in his forties, 1:40's. He was looking forward to his 100th birthday! May be new materials, better design will prove a substitute for span. The one thing that there will never be a substitute for is Money. Anyone who disagrees may care to explain the absence of K8's from the various handicapped comps. -----Original Message----- From: Glider Pilot Network ] Sent: Wednesday, December 24, 2003 10:10 PM To: Steve Hopkins Subject: [r.a.s] 50+:1 15m sailplanes ------------------------------------------------------------ Newsgroup: rec.aviation.soaring Subject: 50+:1 15m sailplanes Author: Robert Danewid Date/Time: 22:00 24 December 2003 ------------------------------------------------------------ JJ, negative thinking - use the force! Robert JJ Sinclair wrote: "There is a substitute for span, it's called skill, but you can buy span" OK, it's 7:00 PM, the sky has been completely overcast for hours, you have 5000 feet and your looking at a 50 mile final glide. Now SKILL your way home. A very mery Christmas to all my RAS buddies. JJ Sinclair ------------------------------------------------------------ |
Does someby know a set of specs for the Diana 2 similar to those =
supplied for the American Duck Eagle ? |
Ian Strachan wrote:
Our vaches may not be very vicious but our roads (for retrieving) are But didn't the ``vaches folles'' (=mad cow) start out in the UK?? SCNR ;-) -Gerhard |
"Ian Strachan" wrote in message
... In article , Bob Johnson writes .......... It refers to the "easiest way to increase performance" (max L/D I suppose), contrasting the relative simplicity of adding span compared to the complexities of adding flaps, new airfoil sections, new configurations, etc. ........ ahhh - I like this remark Ian, wouldn't it have been very wise if the IGC would have had this insight before they created the 15m class. Isn't it true that already then, several manufacturers proposed 18m wingspan instaed of the PIKs 15m? Or can you tell us why the racing class really got 15 instead of 18m wingspan? Chris |
In article u, Swiftel
writes "Ian Strachan" wrote in message ... In article , Bob Johnson writes ......... It refers to the "easiest way to increase performance" (max L/D I suppose), contrasting the relative simplicity of adding span compared to the complexities of adding flaps, new airfoil sections, new configurations, etc. ....... ahhh - I like this remark Ian, wouldn't it have been very wise if the IGC would have had this insight before they created the 15m class. Isn't it true that already then, several manufacturers proposed 18m wingspan instaed of the PIKs 15m? No, but some of the German manufacturers proposed 16 m, which was so close to the 15m flapped ships already being built (like the Pik 15) that IGC decided to stick with 15m. From memory the date was 1974 or so, when I was the UK delegate to IGC. It was actually a BGA proposal to IGC that the old standard class rules (under which the K6 was designed) be left alone, and the new class should only be span-limited. It is interesting that when Gerhard Weibal lectured at the BGA weekend about 5 years ago, he naturally concentrated on huge-span sailplanes. I therefore asked him in the question period what he considered the most "cost-effective span". I expected him to say about 20 or 22 metres but his reply was 17. Pretty close to the 16m I mentioned above, and fortunately also to 18m which is now a separate IGC class and is particularly suited to bearing the extra weight of a motor (whereas 15m is a tad small for a self-launcher in a weak-thermal country). Or can you tell us why the racing class really got 15 instead of 18m wingspan? I have written up my perspective on this for Sailplane and Gliding and it may be published shortly. But basically as above. 18m was never discussed by IGC in 1974 although this span was used in older wooden designs such as the Skylark 3 and 4, etc. -- Ian Strachan Bentworth Hall West Tel: +44 1420 564 195 Bentworth, Alton Fax: +44 1420 563 140 Hampshire GU34 5LA, ENGLAND |
![]() "Ian Strachan" wrote in message ... In article u, Swiftel Snip----- It is interesting that when Gerhard Weibal lectured at the BGA weekend about 5 years ago, he naturally concentrated on huge-span sailplanes. I therefore asked him in the question period what he considered the most "cost-effective span". I expected him to say about 20 or 22 metres but his reply was 17. Pretty close to the 16m I mentioned above, and fortunately also to 18m which is now a separate IGC class and is particularly suited to bearing the extra weight of a motor (whereas 15m is a tad small for a self-launcher in a weak-thermal country). Snip----- Ian Strachan Bentworth Hall West Tel: +44 1420 564 195 Bentworth, Alton Fax: +44 1420 563 140 Hampshire GU34 5LA, ENGLAND Interesting. I recall a technical discussion a long time ago asking whether there was a "natural best wingspan" imposed by the nature of soaring weather. The question was this: "Ignoring competition classes, is there a single best wingspan that is suited for the widest range of soaring conditions? The answers converged around 18 meters. Larger spans were considered too slow in strong conditions and smaller spans suffered in weak conditions. It's interesting that the "most cost effective wingspan" is about the same. This makes me wonder if eventually the 18 meter class will become dominant. It also makes me wonder if the selection of 15 meters for the two most popular classes was an error. Bill Daniels |
![]() "Ian Strachan" wrote in message ... No, but some of the German manufacturers proposed 16 m, which was so close to the 15m flapped ships already being built (like the Pik 15) that IGC decided to stick with 15m. Just a bit of nit-picking, but it was Pik-20. Pik-15 "Hinu" is a towing plane... regards, h |
Never mind
It is till a good quote (I still think it was Moffat back in the 70s) Robert Bob Johnson wrote: Just to keep stuff straight, while Mr. Moffat has certainly expessed from time to time his fondness for span, I believe "there is no substitute for span" quote comes from Michael Bird ("Platypus") who used to "tinsfos" us quite regularly in S & G (Brit mag) from across the pond ... Of course I could be wrong .. BJ Robert Danewid wrote: There were 2 SZD56 flying in the worlds in Sweden in 1993. They performed nice but not astonishing. One of them even had a minor midair. A year later or so we had one (modified) exhibited at the Annual Swedish Cliding Conference, and as Chris writes, the cockpit were not built for nice looking guys from the West, but supposedly for thin, starving pilots from the eastblock...... (now that has thank God changed!) Moffat once wrote: there is no substitute for span! If you want 50+ go for an 18m or larger ship, if you want nice handling, easy rigging etc, it is easy to trade in som finesse-point to achieve that in a 15m glider! Robert H304 Chris OCallaghan wrote: It's been a few years, but if memory serves Gerhard said that the 27 wing could manage a Finesse (best L/D) of 100, that is, if he didn't have to hang a fuselage off of it. However, most glider pilots like to fly their aircraft in the first person, so he compromised and got a Finesse around 46. The Diana, on the other hand, took the road less travelled by and decided that pilot comfort (or in my case, presence) were not critical marketing factors. Based on that philosophy, I wouldn't doubt that a determined engineer could achieve a Finesse of 50+ for a 15 meter glider. However, we've learned that best L/D is a poor means of judging sailplane performance. It is the flatness of the drag curves on both sides of the intersection that really determine the worth of your glider. A polar free of a low speed bucket and relatively flat increase of sink with speed make a great glider. Might the poles have found a new trick? A more stable high aspect ratio airfoil that needs less tail? A better fuselage/wing transition? Improved laminar control? Perhaps. Paul T wrote in message ... 'DuckHawk 15m racer announced at 2003 SHA Western Workshop. 53:1glide ratio VNE 200 kts' -from Winward Performance - anyone got anymore details? 'SZD-56-2, Diana 2: Newest 15-meter Sailplane.The technologically advanced SZD-56-2 Diana 2 will soar on new wings next summer. Bogumil Beres, chief design engineer of the Diana and owner of Biuro Projektowe 'B' Bogumil Beres, recently announced the design project of a breakthrough Diana 2, featuring a curved wing platform with a continuously varying airfoil and high-performance winglets. The original Diana fuselage will be retained, but with a lower drag fuselage-wing junction. The wing loading range will be 6.08 - 11.7 psf. Most remarkably, the Diana 2 will break the long-standing 15-meter glide ratio barrier of 50/1 with room to spa forecast performance includes a max L/D of 52/1. The prototype Diana 2 wings will fly next August. Diana 2's will be delivered in the Spring of 2005.' Have the Germans got something to worry about? |
sailplanes for sale | Jerry Marshall | Soaring | 1 | October 21st 03 03:51 AM |
