http://www.popsci.com/popsci/aviatio...563899,00.html
Interesting reading in the 01/2004 Popular Science and the approach to fuel consumption. Frank Whiteley "John Mason" wrote in message ... The advantage of the lightweight jet engine is totally eclipsed by the fuel consumption problem. A self launcher engine and prop and fuel tanks weighs 55-60kg with full fuel tanks. They are already heavy enough and it would be better to go lighter not heavier. A pair of jet engines will weigh only 7kg but the fuel with tanks will be about 95kg and so at 103kg is nearly double the weight surcharge, furthermore as I implied before there is a big problem in finding enough room to store 120lts. There may also be a weight and balance issue but if the fuel were stored in the wing tanks instead of water ballast that would be less of a problem but you would have little room left or weight reserve for water then. You could treat the fuel as ballast and dump the fuel if you chose to, it is pretty cheap stuff, cheaper than many brands of mineral water. If there existed a model fanjet engine and if it were to use say less than half the fuel, a jet engine would begin to look like a good option. "Peter Seddon" wrote in message ... To give the same duration the jet will need a very large and heavy-when-full 120lt tank. Yes but what about the weight saving over the mechanics of the petrol engine/prop etc.? Peter S DLA |
D.C. Air Guard Unit Flies New 737s | Otis Willie | Military Aviation | 0 | January 14th 04 11:12 PM |
Sailplane Homebuilders Association workshop "report" | Eric Greenwell | Soaring | 0 | September 12th 03 06:07 AM |
Electro-self-launching sailplane | clement | Soaring | 5 | September 12th 03 05:03 AM |
Enola Gay flies into new A-bomb controversy | Otis Willie | Military Aviation | 0 | August 21st 03 09:10 PM |
uh oh, Plane flies over Bush motorcade | Mutts | Piloting | 38 | July 29th 03 04:20 AM |
