IS-28 Fuselage Construction
Old December 26th 03, 06:30 AM
smjmitchell
Default IS-28 Fuselage Construction
Hi All,
Can onyone tell me if the skins on the forward fuselage of an IS-28
are flat wrapped or compound curved (i.e. stretch formed).
In other words would it be easy to rebuild the forward fuselage using
sheet stock or would it be necessary to buy the preformed skins.
Thanks,
Steve
Old December 26th 03, 06:43 AM
Bob Kuykendall
I think that Bill Daniels is probably the RAS resident
Lark expert. But from what I've seen of various Larks,
the forward fuselage skins are pretty much all compound
curved.
Such skins aren't necessarily stretch-formed. They
can also be done using English wheel and hammering
or bumping. Dick Schreder used relatively low-tech
hydroforming to make the compound-curved forward fuselage
skins of the HP homebuilt gliders.
Thanks, and best regards to all
Bob K.
http://www.hpaircraft.com
Old December 26th 03, 03:04 PM
"Bob Kuykendall" wrote in message
Bob K.
Here is an article that Bob wrote several years ago describing Dick
Schreder's system.
http://www.soaridaho.com/Schreder/Co...lly_skins.html
Old December 26th 03, 04:41 PM
F.L. Whiteley
Although the glider division is clearly missing, you still might try the
factory. www.iar.ro
"smjmitchell" wrote in message
om...
Hi All,
Thanks,
Steve
Old December 27th 03, 10:52 PM
Paul Adriance
I have contacted the factory via email regarding an IS-28b2 and IS-32 and
received helpful responses. I would encourage you to try as well.
Paul Adriance
"F.L. Whiteley" wrote in message
factory. www.iar.ro
om...
Hi All,
Thanks,
Steve
Old December 31st 03, 02:07 AM
Bill Daniels
curved.
Bob K.
The forward skins are compound curves so simple wraps of aluminum won't
work. The lengthwise curves are actually very large radius so the English
wheel should work fine as would Dick Schreder method.
The factory will probably be able to supply skins but they can be made from
scratch by any competent metal shop.
Bill Daniels
Bill Daniels
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 03:13 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 07:29 PM
Worthy EAA Construction Books Brock Home Built 5 September 16th 03 07:48 PM
#1 Jet of World War II Christopher Military Aviation 203 September 1st 03 03:04 AM
