Bill,
Use a vacuum flask and put 2 or 3 copper pot scrubbers (chore girl brand works OK) in the bottle, then cap the bottle and make sure you test for leaks. Leaks on the bottle side of a vario make for huge errors. Jim |
Bill Daniels wrote:
snip Clearly, as every instrumentation book says, the flask has to be insulated. The purpose of the above narrative is leading up to the question about the best material to insulate the flask. I want to mount the flask behind the instrument panel to keep the tubing runs as short as possible. What's the best insulation material? Bill Daniels A vacuum |
Michael McNulty wrote in message news:DCLMb.408$
A vacuum Awwww. you cheated, that's not a 'material'....isn't a vacuum a lack of material?? ;-) |
At 14:00 13 January 2004, Andy Durbin wrote:
I thought the pot scrubbers were used to reduce the flask capacity to compensate for the capacity added by a long tubing run. Andy Andy, You can fill a pint beer glass with water to the brim and then slowly introduce a fine pot scrubber wihout spilling a drop if you are careful. I can't remember where I first heard that but I didn't believe it until I tried it. John Galloway |
![]() You can fill a pint beer glass with water to the brim and then slowly introduce a fine pot scrubber wihout spilling a drop if you are careful. I can't remember where I first heard that but I didn't believe it until I tried it. John Galloway What a waste of beer! Hopefully the scrubber didn't have any soap or detergent? 8-) Keith |
John Galloway wrote in message ...
At 14:00 13 January 2004, Andy Durbin wrote: I thought the pot scrubbers were used to reduce the flask capacity to compensate for the capacity added by a long tubing run. Andy Andy, You can fill a pint beer glass with water to the brim and then slowly introduce a fine pot scrubber wihout spilling a drop if you are careful. I can't remember where I first heard that but I didn't believe it until I tried it. John Galloway That seems to say that the volume of copper is *very* small so its mass would be too. Is there any useful heat exchange between a negligible mass of copper and .45 litres of air? I'll add the knowledge to my useful pub tricks list though. Andy |
![]() "Ian Johnston" wrote in message news:cCUlhtvFIYkV-pn2-slrYLOWSYEIp@localhost... On Tue, 13 Jan 2004 20:47:07 UTC, (Andy Durbin) wrote: : That seems to say that the volume of copper is *very* small so its : mass would be too. Is there any useful heat exchange between a : negligible mass of copper and .45 litres of air? I bet the trick wouldn't work if the glass was really, really full. You can pile a lot of water up in a meniscus. That said, the specific heat capacities for copper and air are 380 and 1004 J/kgK, but since the densities are 896 and 1.225 kg/m^3, the volumetric heat capacities are 340 and 1.23 kJ/Km^3, a ratio of 276:1. In other words, filling 1% of the capacity with copper will nearly treble the heat capacity of the, um, capacity. Ian -- I've been doing some searching for a 0.45L vacuum flask - no luck. All consumer thermos bottles these days are heavy, bulky, not very insulating stainless steel. Laboratory glassware suppliers do sell 500ml glass dewars. The ones that I could find however, are short, wide mouth containers which, with the large rubber stopper required, wouldn't be very good either. Anybody got a lead on a narrow-mouth, half liter glass dewar? The other approach is to use the tan plastic 0.45 liter capacity flask that comes with varios these days like the one that failed the test for thermal effects. Insulating one of these might be acceptable but there is no way to insert a copper scrub pad. Bill Daniels |
Earlier, "Ian Johnston" wrote:
...You can pile a lot of water up in a meniscus. I think you just named Pez's next sailplane! |
![]() "Andy Durbin" wrote in message om... snip That seems to say that the volume of copper is *very* small so its mass would be too. Is there any useful heat exchange between a negligible mass of copper and .45 litres of air? I'll add the knowledge to my useful pub tricks list though. Andy Rather than squeeze this out a piece at a time, take a look at: http://www.betsybyars.com/guy/soarin.../69-vario.html and get a perhaps-useful overview. Tim Ward |
Tasman audio vario for sale | JJ Sinclair | Soaring | 8 | February 1st 14 02:01 PM |
Ball vario overhaul? | Anthony Turiano | Soaring | 6 | June 17th 09 08:06 PM |
Firewall Insulation | Marv Hamm | Home Built | 2 | August 31st 04 02:14 AM |
Firewall Insulation | Kyle Boatright | Home Built | 1 | August 27th 04 01:11 AM |
radio / vario interference - HELP! | Chris Davison | Soaring | 13 | November 3rd 03 06:09 AM |
