Neal Pfeiffer wrote in message om...
Moving of weights within a fuselage (or other part of the aircraft) is not a viable solution. Response needs to be quick and reliable, even for unusual attitudes. ************************************************** ***************************** Moveable weights for pitch control aren't as responsive in the negative pitch airfoils used in conventional gliders because increasing speed increases the downward pitching moment which the wing produces. Moving the weight forward to drop the nose and increase speed leads to the requirement for back stick to increase downward pressure on the horizontal stab and keep the nose from continuing to drop. If you tried to do this only with weight shift, you would need to move the weights forward to increase speed and then progressively move the weight backward as the speed builds up just to maintain stability. Computerized fuel shifting on airlines does this but they still use all-flying-tails for the fine corrections. Weight shifting for pitch control is very workable in flying-wing type gliders as they are very responsive to changes in cg; and the inherent stability of the reflex wing keeps the glider very close to the weight shifted pitch.(and speed) Several Genesis owners use rudimentary forms of weight shift on a regular basis. One has mentioned putting ankle weights on the rudder pedals and moving them back and forth, someone else has stated in the GenesisFlyers Yahoo Groups site that inflating the lumbar support adds 4 knots to the trimmed speed. There have been discussions about using nose and tail water tanks and shifting from one to the other to trim for best thermalling or high speed. This is a very workable improvement for Genesis 2 and Marske Pioneer type gliders. Weight shifting on the Pioneer may work even better as it may be possible to fly with a very aft cg which keeps the nose high and then use forward stick to deflect the elevators down increasing the lift coeffecient of the wing. Moving the weight forward would then allow it to fly fast with the elevators slightly raised the way flapped gliders fly with negative flaps.(reflex) Based on the vast majority of the gliders in existance, however, using a correctly-sized tail is not a bad way to go. Remember, if you don't truly enjoy what you're flying, you probably won't fly it long. Tailed aircraft are probably easier to make fly good. ************************************************** ****************************** It's hard to argue against correctly-sized tails, although I suspect that what you call "correctly-sized" is what I spitefully and maliciously call a boomsnapper. Boomsnappers interfere with low energy landings as your pitch at flair is limited by your willingness to slam down tail first and damage the boom. Some boomsnappers (G 102) are speed limited because, oops!, the elevator isn't as strong as we thought and it is prone to flutter. The G103 Acro is acro no more because that big heavy extremely strong tail boom isn't as strong as it should be. Need to slap on a few more layers of carbon so's it don't come off. So, how strong and durable are those tiny, light weight tail booms on newer high performance gliders? Are they at least as strong as the wing spars on Shemp-Hirth gliders? How strong will they be when they are as old as Grobs? Got to keep that tape on tight, too, cause lifting of the front edge of tape near the elevator causes an almost total loss of elevator authority. Genesis 2 and Pioneer owners all seem to really like the handling characteristics of their flying-wing gliders and as a group they don't seem to miss or wish they had longer tail booms. Long tailed aircraft are certainly easier to make and they satisfy an esthetic which sees ships, trains and trucks as boxes or tubes which carry cargo, so an aircraft should be a box or tube with wings. The more it looks like a truck the safer it "feels". |
Sailplane Rides - Gifts | Michael | Rotorcraft | 0 | December 7th 04 06:20 PM |
Sailplane Rides - Gifts | Michael | Products | 0 | December 7th 04 06:19 PM |
Any sailplane pilots? | Larry Dighera | Soaring | 99 | January 7th 04 03:46 AM |
Sailplane Homebuilders Association workshop "report" | Eric Greenwell | Soaring | 0 | September 12th 03 06:07 AM |
Electro-self-launching sailplane | clement | Soaring | 5 | September 12th 03 05:03 AM |
