Water injection works but glowing shock diamonds in an afterburners exhaust
would be cool. Noisy, but cool. Bill Daniels "Steve Davis" wrote in message ... Early models of the KC-135 tanker used water injection on takeoff for added thrust. No idea how much additional thrust could be gained by adding this to a 45Lb thrust turbine but it wouldn't increase fuel consumption the way an afterburner would. How about a cowling around the jet and water could be sprayed or misted onto the exhaust section. Could the steam then mix with the exhaust well enough to increase thrust or would it be a perpetual motion add on? If not, you can add the afterburner! (re-heat) Bill Daniels |
Well, I've looked into canards, and as a previous
poster pointed out, modern canards sacrafice a bit of efficiency over trailing tailbooms. So if this is out, canting engines to the side, or down, seems a good choice. Doing this with a single engine is awkward. So perhaps the engine right out the tail? Hmmm.... |
Mark James Boyd wrote:
Well, I've looked into canards, and as a previous poster pointed out, modern canards sacrafice a bit of efficiency over trailing tailbooms. So if this is out, canting engines to the side, or down, seems a good choice. Doing this with a single engine is awkward. So perhaps the engine right out the tail? Hmmm.... Look at Max Barel's "Graal" experimental glider in France. http://perso.wanadoo.fr/max.barel/Graal/overview.html Seems to work rather well. |
Sport Pilot - School Won't Offer | Gary G | Piloting | 38 | February 16th 05 10:41 AM |
I wish I'd never got into this... | Kevin Neave | Soaring | 32 | September 19th 03 12:18 PM |
Restricting Glider Ops at Public Arpt. | rjciii | Soaring | 36 | August 25th 03 04:50 PM |
Announce/USA: FAA Glider Flying Handbook / Bob Wander | SoarBooks | Soaring | 0 | August 11th 03 03:55 PM |
