Denis, you should read up on the French designer Charles Fauvell and his
flying wings. They flew pretty well although I think Jim Marske's designs are showing higher performance. Tailless designs fly quite well and the performance really doesn't suffer. They would be perfect for small jet engine self launchers. Bill Daniels "Denis Flament" wrote in message ... Mark James Boyd wrote: I'm considering these factors, because eliminating the elevator and stab would reduce drag. That's right. You should also consider eliminating the wings, that would reduce even more drag. I suppose the best way to experiment with this is in a model glider first, Well... I suppose too... if you want to experiment this with a full scale glider, it will be difficult to find a pilot to put in ;-) -- Denis R. Parce que ça rompt le cours normal de la conversation !!! Q. Pourquoi ne faut-il pas répondre au-dessus de la question ? |
Bill Daniels wrote:
Denis, you should read up on the French designer Charles Fauvell and his flying wings. They flew pretty well although I think Jim Marske's designs are showing higher performance. Tailless designs fly quite well and the performance really doesn't suffer. They would be perfect for small jet engine self launchers. Hi Bill Yes I know that Fauvel "ailes volantes" like the glider AV36, and other flying wings like Horten's fly quite well. But I still doubt that suppressing the tail means suppressing the trim drag of an airplane. Flying wings have to use stable wing profiles (with positive pitching moment) and these produce more extra drag than a tailplane. Things are not so simple... -- Denis R. Parce que ça rompt le cours normal de la conversation !!! Q. Pourquoi ne faut-il pas répondre au-dessus de la question ? |
Bill Daniels wrote:
Denis, you should read up on the French designer Charles Fauvell and his flying wings. They flew pretty well although I think Jim Marske's designs are showing higher performance. Tailless designs fly quite well and the performance really doesn't suffer. They would be perfect for small jet engine self launchers. Bill Daniels There are some obvious reasons not to use a canard (towrope tangling, landout damage, creates turbulence before the wing) but this seems an option as well... I've only flown one canard aircraft, (and never a flying wing) so I may delve into this more... |
Sailplane Rides - Gifts | Michael | Rotorcraft | 0 | December 7th 04 06:20 PM |
Sailplane Rides - Gifts | Michael | Products | 0 | December 7th 04 06:19 PM |
Any sailplane pilots? | Larry Dighera | Soaring | 99 | January 7th 04 03:46 AM |
Sailplane Homebuilders Association workshop "report" | Eric Greenwell | Soaring | 0 | September 12th 03 06:07 AM |
Electro-self-launching sailplane | clement | Soaring | 5 | September 12th 03 05:03 AM |
