Chris OCallaghan wrote:
Smaller people using cushions often don't have the leverage to get the handle fully back. [snip] It takes a good bit of force to engage the brake fully. It's not difficulat for a male in a good seat position (right mix of leverage and strength), but can be very challenging for a small-framed woman. I have had four flights in the G103A. I am 5'1", 108#, and use cushions. I can *barely* muscle open the airbrakes all the way on the ground during preflight, and it is quite challenging, to say the least, on rollout...I have to sort of shift/turn upper body toward the left to do so. I have a similar situation in the 1-26, as I am so short that I have the seatback up as far as it will go to reach the peddles (can't use the bottom cushion made for the plane with the seatback in that position because it gets in the way of the stick!), and opening the divebrakes all the way ends up being an interesting, awkward contortion. Worth it, though!! :-) --Shirley |
I missed Andy's paragraph about his wife's height.
Inseam length is also important. The longer your legs, the further back you can sit and the more leverage you can muster. Perhaps bringing the rudder pedals all the way back, then adjust the headrest and cushions to suit... this might get her in a better position to handle the brakes. |
