I am not the guy with all the tech details but our club has a truck axle
1950s vintage doing that job, I think for at least 25 years mounted in the winch. The driver hops out unwinds a locking lug then pulls the half shaft to disengage it from the gears in the centre walks round and reverses the procedure to use the other side.I believe it was from a 5-7 ton load truck. gary "Ulrich Neumann" wrote in message m... c1rrus wrote in message ... One for the mechanically minded out there. Our club is currently constructing a double drum winch. More accurately I should say - re-constructing as said winch is based on, and uses the major components of an old single drum winch. The design is of the trailer with a V8 vehicle transmission attached type. Ford 352W (2V) engine 3 Speed automatic transmission Modified differential feeding power to drums attached to the half shafts. Drums are steel units with the large base diameter and narrow aperture suitable for our 2.75mm single strand medium carbon spring steel cable. Having become involved in resurrecting the project after it's originators left the club and the winch lay derelict for some years I am not at all confident that the power transmission mechanism is safe, durable or desirable. Current design has a crude castellated gear (I would not glorify it to refer to it as a dog clutch) This slides from side to side so that it is completely disengaged in the centre and engages one or the other half shaft when moved to either side. There is an interconnected disk brake that locks the undriven half shaft. One problem is that this leaves the diff spinning one way or the other on every launch. Now Borg-Warner make a good product but I doubt the engineers had his treatment in mind... Another problem is the poorly supported axle to the drum. There is no way we can afford a modern commercial winch, but this does not mean we should not make a better attempt at out homebuilt. Would appreciate the opportunity to learn from the experience out there. We need input on transmission paths, materials, controls and probably many things we have not thought of yet. The engine and gearbox are standard , reliable and have been competently overhauled. For the rest, the only decently engineered parts of the project are the drums , which are solid, accurately made and balanced. The rest would be very familiar to Messrs Heath and Robinson... Any help gladly received. Hi Cirrus, I am in the process of investigating the different technical aspects of building a winch. So far, I have several reports that indicate using an axle - specially one from a commom pick-up truck - in the way you described it, is a sure way of heading for a desaster. The differential gear has to be locked out by welding the spider gears solid. You can find references about this on the net. Keep in mind that doing this will change the gear ratio. Your drums will most likely spin slower at a given input shaft speed than with the differential spinning. To keep the design simple, you may want to consider just a single drum design. To keep the cable from piling up on the center of the drum, keep the distance between the fairlead and the drum as long as possible. German regulations require a distance of at least 18 times the width of drum between the drum and the fairlead to be operated without a level-wind mechanism. Do you have well functioning guilliotins capable of hacking through at least two cables in one trial? Happy winching, Uli Neumann Libelle 'GM' |
Aircraft Design 1942 flying boats FA | Sally | Home Built | 0 | August 19th 04 06:49 PM |
amateur design consultant? | Shin Gou | Home Built | 14 | June 30th 04 01:34 AM |
How 'bout a thread on the F-22 with no mud slinging, no axe grinding, no emotional diatribes, and just some clear, objective discussion? | Scott Ferrin | Military Aviation | 23 | January 8th 04 12:39 AM |
One Design viability? | Stewart Kissel | Soaring | 41 | December 10th 03 03:27 AM |
using winch instead of aerotow | goneill | Soaring | 5 | August 27th 03 02:46 PM |
