I have two batteries and have flown for many hours
on transponder - no problem. The drain is higher if you use mode C (height encoding) but still no problem. At 05:42 22 January 2004, Ch wrote: and how long does the battery last? with the transponder on? Australia decided, that planes without a permanent source of power on board, do not need transponders in mixed airspace. I would prefer, that IFR traffic out of airport airspace should fly higher than the convection height from sunrise to sunset :-) How's that?? Chris 'Ben Flewett' wrote in message ... Are you on drugs? This is a bad idea for so, so many reasons. Here are a few... 1. I don't want to pedal. 2. My feet are busy operating the rudder. 3. My cockpit is a constant state of crisis, which allows no time for pedalling. 4. I sometimes fly in airspace for hours at a time. I resent have to move the stick for hours at a time, let alone having to pedal for hours at a time. 5. Weight. 6. Complexity. 7. I like a simple life. 8. I don't want a bearded sandal wearer installing weird science contraptions in my glider. Here's an idea. Why not use a battery? At 15:00 21 January 2004, Vaughn Simon wrote: 'Mil80C' wrote in message ... A question to you fine soaring fraternity, what would your response be to someone who suggested that it might be feasable to run a transponder in a glider with a pedal generator? A raised eyebrow, a polite silence, a glance at my wris****ch, followed by a graceful withdrawal. Vaughn -- BEER! So much more than just a breakfast drink! |
Non-radar transponder codes | Michael | Instrument Flight Rules | 16 | February 13th 04 01:15 PM |
Dual Transponders? | Scott Aron Bloom | Instrument Flight Rules | 17 | December 14th 03 05:54 AM |
Mode S Transponders - Can ATC tell the difference? | Doodybutch | Owning | 2 | August 10th 03 06:21 AM |
Transponders, Radios and other avionics procurement questions | Corky Scott | Home Built | 5 | July 2nd 03 11:27 PM |
