Folks would like to plod through life thinking that they will
recognize the good old nose up, stall, kick rudder, this must be the entry to a spin, I can recover from this. Who wouldn't. The one we like to pound into their memory is the nose level on the horizon, cross control (over shooting the final)feed in top aileron, and away you go into the nicest spin entry. Recognize it and recover. We don't need to let it wind up either. Again a good cirriculum lets you do this training with a high degree of safety, if the instructor is properly trained. Stewart Kissel wrote in message ... OK JJ, I'll bite (sorta)- With spin entry training being done so often in benign-handling ships, what in fact are we teaching/learning? 'Pull back, Pull back, okay kick in full rudder'-and the thinking might go-'Gee, how does anyone get into a spin, this is way to much work' How does this apply the first time someone gets in a ship that may fall off on its own? At 18:24 23 January 2004, Mark James Boyd wrote: In article , JJ Sinclair wrote: It's winter, I'm bored and I haven't started any good controversies (this year) so here goes: In the early 50's the USAF had a policy to give jump training to all aircrew personnel. They soon learned that they were getting twice the injuries in training that they were experiencing in real bail-outs. They decided to stop the actual jump training and just give PLF and kit deployment, etc training. So, JJ asks, In light of recent events that show its been reining Puchaz's, Do we really want to teach full blown spins? Isn't spin entry and immediate recovery, all we should be doing? JJ Sinclair With three times as many fatalities in training than flying (helicopters), one wonders the wisdom of practicing hundreds of autorotations during helicopter training as well. |
That's the one that would get me. Low and slow, sneaking over a fence
needing juuuuuuust liiiiiitle rudder to line up. I think an instructor can pound into your head NOT to do that, how to check yourself, and let you practice your stupidity. On my own as a test pilot, I will certainly get killed. "SNOOP" wrote in message om... Folks would like to plod through life thinking that they will recognize the good old nose up, stall, kick rudder, this must be the entry to a spin, I can recover from this. Who wouldn't. The one we like to pound into their memory is the nose level on the horizon, cross control (over shooting the final)feed in top aileron, and away you go into the nicest spin entry. Recognize it and recover. We don't need to let it wind up either. Again a good cirriculum lets you do this training with a high degree of safety, if the instructor is properly trained. |
If I took charge of a gliding club using Puchacz(s) for basic training, the
first thing I would do is pile them all in a heap in the corner of the field and set fire to them. This may come across as something of a controversial viewpoint. Let me explain. As far as I know, we are now into double figures (in the UK alone) in terms of fatalities when it comes to stall/spin accidents in the Puchacz. Compare this to gliders like the twin Grob and K-21: there are far greater numbers of them flying many times more hours with a much better record. Even older machines such as the K-13 stand out well in comparison. I really can't see the advantage of a training glider that spins so readily and kills you if you get the recovery (slightly) wrong. I think some of the instructing fraternity (in the UK) have become too focussed on spinning as an 'exercise' and not something to be avoided. I believe that if a significant group of pilots are having _inadvertent_ stall/spin incidents/accidents when they are flying solo, then there is something very very wrong with the most elementary training we are giving. I read and hear much concerning technical details of spinning, i.e. what glider X does after 5 turns with part aileron and that glider Y flicks when you yank and stamp on the controls. All fairly irrelevant. If you get to the point of having to do a full recovery one might question as to how you got there in the first place. If you are low down (especially in machines like the Puchacz), where most bad accidents occur, knowing how to recover from a spin is probably not going to be of much use. Indeed, it may help to make the subsequent impact unsurviveable. What we seem to be failing to do is to instill a basic awareness of what the glider is up to, and the _instinctive_ reactions required if the airframe stops responding to your commands. Mike Cuming wrote a seminal article in S&G, some years back, entiltled: "STOP PULLING THE STICK BACK!". This should be required reading for all pre-solo students. If you really want to show people full-blooded spins and recoveries, take them up to a safe height in an aerobatic power aircraft, certified for those kind of manoevres. You will be able to do much more for a lot less money. Frankly, I see little point in making pilots deliberately demonstrate their 'expertise' in abusing a glider to the point it autorotates, then attempting to do something about it. This is not the world aerobatic championships. I would much rather see immediate instinctive corrections to any possible loss of control. To the experienced pilots/instructors reading this: when was the last time you ended up (inadvertently) in a spin? Yes, you get wing drops in thermals etc. but do you sit there, doing nothing, until the ground and sky start going round very fast? No. I'm sure you don't, as you are alive to read this. What drove me to stay up at night to write this post was a feeling of anger/helplessness/sadness that yet more people have died in what I regard as a pointless exercise. I knew the P1 in the double-fatal crash this week but not his fifteen year old student. Safe flying to all of you. |
![]() "Mike Borgelt" wrote in message news ![]() On 25 Jan 2004 01:26:39 GMT, (Edward Downham) wrote: If I took charge of a gliding club using Puchacz(s) for basic training, the first thing I would do is pile them all in a heap in the corner of the field and set fire to them. This may come across as something of a controversial viewpoint. Let me explain. As far as I know, we are now into double figures (in the UK alone) in terms of fatalities when it comes to stall/spin accidents in the Puchacz. Compare this to gliders like the twin Grob and K-21: there are far greater numbers of them flying many times more hours with a much better record. Even older machines such as the K-13 stand out well in comparison. I really can't see the advantage of a training glider that spins so readily and kills you if you get the recovery (slightly) wrong. I think some of the instructing fraternity (in the UK) have become too focussed on spinning as an 'exercise' and not something to be avoided. I believe that if a significant group of pilots are having _inadvertent_ stall/spin incidents/accidents when they are flying solo, then there is something very very wrong with the most elementary training we are giving. I read and hear much concerning technical details of spinning, i.e. what glider X does after 5 turns with part aileron and that glider Y flicks when you yank and stamp on the controls. All fairly irrelevant. If you get to the point of having to do a full recovery one might question as to how you got there in the first place. If you are low down (especially in machines like the Puchacz), where most bad accidents occur, knowing how to recover from a spin is probably not going to be of much use. Indeed, it may help to make the subsequent impact unsurviveable. What we seem to be failing to do is to instill a basic awareness of what the glider is up to, and the _instinctive_ reactions required if the airframe stops responding to your commands. Mike Cuming wrote a seminal article in S&G, some years back, entiltled: "STOP PULLING THE STICK BACK!". This should be required reading for all pre-solo students. If you really want to show people full-blooded spins and recoveries, take them up to a safe height in an aerobatic power aircraft, certified for those kind of manoevres. You will be able to do much more for a lot less money. Frankly, I see little point in making pilots deliberately demonstrate their 'expertise' in abusing a glider to the point it autorotates, then attempting to do something about it. This is not the world aerobatic championships. I would much rather see immediate instinctive corrections to any possible loss of control. To the experienced pilots/instructors reading this: when was the last time you ended up (inadvertently) in a spin? Yes, you get wing drops in thermals etc. but do you sit there, doing nothing, until the ground and sky start going round very fast? No. I'm sure you don't, as you are alive to read this. What drove me to stay up at night to write this post was a feeling of anger/helplessness/sadness that yet more people have died in what I regard as a pointless exercise. I knew the P1 in the double-fatal crash this week but not his fifteen year old student. Safe flying to all of you. Thank you Edward. That is the best article on this issue I have ever seen. I agree 100% and particularly with the "do it in a power plane designed for this". I did this two years ago in a Pitts S2A with an experienced airshow pilot who is also an aerobatic instructor. We both wore parachutes, had a proper briefing and agreed to abandon ship if control not regained by 4000 feet AGL. All spins were begun from at least 9000 feet. I learned more about spinning in that hour than in my previous 35 years flying. Now for a solution to keep everyone happy - I believe we have the technology to build a realistic, close to full motion, spin simulator at an affordable price. This will allow through and complete exploration of the pre stall, stall and spin regime for training and combine this with one real full spin aircraft exercise at altitude with proper precautions and briefing. Lets do this and stop killing people in training exercises. We lost a couple of people in Australia a few years ago in a Blanik during an annual "spin check". The spin turned into a spiral and the aircraft broke up in the recovery. They weren't at high altitude nor wearing parachutes. Many experienced pilots I know flat out refuse to do full spins during annual checks as being an unnecessary risk. They will happily demonstrate stalls and incipient spins. Mike Borgelt I did an annual check of a ATP pilot who owns a glider. He had also been flying aerobatic aircraft such as the Citabria and PItts. The annual check was in a Blanik L-23. We decided on a two turn spin so that I could know when to expect a recovery attempt. At two turns, I saw the rear pedals shift to their anti-spin position but the stick remained aft of center and the L-23 continued to spin as if nothing had been done to stop it. I said, "two turns" to remind him of our bargain. Then the stick moved forward and the glider stopped rotating and entered the recovery dive. Asked about the delay in recovery, the pilot said that the standard recovery technique used in the powered aircraft he had been flying was just to reverse the rudder and to keep the stick aft of center. I pointed out that every glider I knew of required forward stick for a sure recovery. (We did several more spins until we both were comfortable with his spin recovery technique.) I think the take-home lesson is that airplanes can spin more benignly than gliders. Relying on spin training in airplanes is just not always appropriate and can leave the pilot with misconceptions about glider spin recovery. I think that, if you fly gliders that will spin, it is wise to experience the spin recovery at least once and preferably more often than that. That said, there is nothing wrong with basic training that emphasizes recognition of an incipient spin over spin recovery. Recognition that a spin is imminent, and knowledge of the technique to prevent it, will save more lives than expert spin recovery. So, is spin training dangerous? Yes, but much less dangerous than not doing spin training. The path from novice to expert is sometimes fraught with peril but remaining a novice is more dangerous still. The Puch, Blanik, and Lark spin more like the glass gliders most of us fly. As such, they are excellent trainers. Just choose an instructor that is very experienced with them. Bill Daniels Bill Daniels |
On Sun, 25 Jan 2004 18:56:36 -0700, "Bill Daniels"
wrote: Asked about the delay in recovery, the pilot said that the standard recovery technique used in the powered aircraft he had been flying was just to reverse the rudder and to keep the stick aft of center. I pointed out that every glider I knew of required forward stick for a sure recovery. (We did several more spins until we both were comfortable with his spin recovery technique.) I think the take-home lesson is that airplanes can spin more benignly than gliders. Relying on spin training in airplanes is just not always appropriate and can leave the pilot with misconceptions about glider spin recovery. I think the gentleman's spin recovery training was suspect. Since when was standard spin recovery other than: Full opposite rudder Pause Move the stick forward When the spin stops centralise rudder and recover gently from the dive? Even if the aircraft recovers with mere application of opposite rudder surely the full standard recovery must be taught? The fatality in the Blanik here a few years ago was that the spin became a spiral so even the Blanik won't necessarily stay in a spin. I think that, if you fly gliders that will spin, it is wise to experience the spin recovery at least once and preferably more often than that. As I said I agree. Note however you cannot do this in all types that you fly. Some like the Standard Libelle and Nimbus 3DM are placarded against deliberate spins. That said, there is nothing wrong with basic training that emphasizes recognition of an incipient spin over spin recovery. Recognition that a spin is imminent, and knowledge of the technique to prevent it, will save more lives than expert spin recovery. So, is spin training dangerous? Yes, but much less dangerous than not doing spin training. The path from novice to expert is sometimes fraught with peril but remaining a novice is more dangerous still. The Puch, Blanik, and Lark spin more like the glass gliders most of us fly. As such, they are excellent trainers. Just choose an instructor that is very experienced with them. Bill Daniels When two testpilot/spin instructors, at least one of whom had extensive spin experience in gliders can kill themselves in a Puch by spinning in I wonder how much experience the instructor has to have? The experienced cross country pilots I know never spin accidently. At most they may get a wing drop in a thermal. The question is what do they know or do that prevents them from ever spinning accidently? If we find this out we might make some progress. Mike |
![]() "Mike Borgelt" wrote in message ... Snip--- When two testpilot/spin instructors, at least one of whom had extensive spin experience in gliders can kill themselves in a Puch by spinning in I wonder how much experience the instructor has to have? Snip--- Mike It does make one wonder. I seem to recall something on r.a.s. to the effect that an inspection of a Puch in the USA turned up a metal plate that was adrift somewhere in the rudder control curcuit. This loose plate, it was said, could prevent the rudder from moving back from the fully deflected position. I seem to recall that it was suspected that some of the spin-in accidents might be due to this. Perhaps someone with a better memory will comment. Bill Daniels |
If you read the other thread about spinning you may understand what
experienced pilots do. Recovery from incipient spins might be just a sligh easing of the stick with slight opposite rudder pressure. No need to dive inside the thermal. However, the only way to recognize this condition is to train for it, while also training for fully developed spins, resulting from level attitudes with pro-turn rudder and low speed (a definite killer in low altitudes). The reference to the more benign spin characteristic of some training airplanes is true. In some of them you don't need to move the stick full forward to recover from a spin. Basically the spin breaks off very easily with just a sligh easing of the control column forward and opposite rudder. Full forward stick will only cause an excessively nose-low attitude resulting in a high-speed dive following the spin. But this is only true in certain aircraft, and if the pilot trains in them he will recognize this. The Puchacz has a similar characteristic, actually. If you press opposite rudder while keeping the stick aft, nothing much happens for a full turn (I never went beyond that). But with this opposit rudder applied, as soon as back pressure on the stick is removed, the glider sort of "snaps" out of the spin. There is no need to move the stick all the way forward or you will then be in an aerobatic, 90 degree nose-low dive. Unnecessary. As I pointed out earlier, Dick Johnson tested the Puchacz and gave it a clean bill of health. www.ssa.org, click on Magazines, Dick Johnson, scroll down to find the Puchacz evaluations (2 articles). "Mike Borgelt" wrote in message ... On Sun, 25 Jan 2004 18:56:36 -0700, "Bill Daniels" wrote: Asked about the delay in recovery, the pilot said that the standard recovery technique used in the powered aircraft he had been flying was just to reverse the rudder and to keep the stick aft of center. I pointed out that every glider I knew of required forward stick for a sure recovery. (We did several more spins until we both were comfortable with his spin recovery technique.) I think the take-home lesson is that airplanes can spin more benignly than gliders. Relying on spin training in airplanes is just not always appropriate and can leave the pilot with misconceptions about glider spin recovery. I think the gentleman's spin recovery training was suspect. Since when was standard spin recovery other than: Full opposite rudder Pause Move the stick forward When the spin stops centralise rudder and recover gently from the dive? Even if the aircraft recovers with mere application of opposite rudder surely the full standard recovery must be taught? The fatality in the Blanik here a few years ago was that the spin became a spiral so even the Blanik won't necessarily stay in a spin. I think that, if you fly gliders that will spin, it is wise to experience the spin recovery at least once and preferably more often than that. As I said I agree. Note however you cannot do this in all types that you fly. Some like the Standard Libelle and Nimbus 3DM are placarded against deliberate spins. That said, there is nothing wrong with basic training that emphasizes recognition of an incipient spin over spin recovery. Recognition that a spin is imminent, and knowledge of the technique to prevent it, will save more lives than expert spin recovery. So, is spin training dangerous? Yes, but much less dangerous than not doing spin training. The path from novice to expert is sometimes fraught with peril but remaining a novice is more dangerous still. The Puch, Blanik, and Lark spin more like the glass gliders most of us fly. As such, they are excellent trainers. Just choose an instructor that is very experienced with them. Bill Daniels When two testpilot/spin instructors, at least one of whom had extensive spin experience in gliders can kill themselves in a Puch by spinning in I wonder how much experience the instructor has to have? The experienced cross country pilots I know never spin accidently. At most they may get a wing drop in a thermal. The question is what do they know or do that prevents them from ever spinning accidently? If we find this out we might make some progress. Mike |
On Mon, 26 Jan 2004 00:15:20 UTC, Mike Borgelt
wrote: : Many experienced pilots I know flat out refuse to do full spins during : annual checks as being an unnecessary risk. They will happily : demonstrate stalls and incipient spins. I would hate to have somebody as nervous about their flying skills as that above me in a thermal. Ian -- |
On 26 Jan 2004 14:29:29 GMT, "Ian Johnston"
wrote: On Mon, 26 Jan 2004 00:15:20 UTC, Mike Borgelt wrote: : Many experienced pilots I know flat out refuse to do full spins during : annual checks as being an unnecessary risk. They will happily : demonstrate stalls and incipient spins. I would hate to have somebody as nervous about their flying skills as that above me in a thermal. Ian It is called risk management. They fly gliders to go soaring not to do aerobatics. Most of them have thousands of hours of flying cross country and in competition. They consider it far riskier to do spins in gliders of uncertain history with instructors of little experience and training who typically seem to them to demonstrate dangerous overconfidence. And they won't spin down on you from above. Some of the attitudes revealed in this thread make me despair that anything will ever happen to improve the soaring safety record. Mike Borgelt |
Inspiration by friends - mutal interest and motivation to get the PPL | Gary G | Piloting | 1 | October 29th 04 09:19 PM |
Baby Bush will be Closing Airports in California to VFR Flight Again | Larry Dighera | Piloting | 119 | March 13th 04 02:56 AM |
Some Fiction For Interest | Badwater Bill | Rotorcraft | 8 | March 6th 04 03:45 AM |
Spinning Horizon | Mike Adams | Owning | 8 | December 26th 03 01:35 AM |
