Puchaz Spinning thread that might be of interest in light of the recent accident.
Old January 25th 04, 01:26 AM
Edward Downham
If I took charge of a gliding club using Puchacz(s) for basic training, the
first thing I would do is pile them all in a heap in the corner of the field
and set fire to them.
This may come across as something of a controversial viewpoint. Let me explain.
As far as I know, we are now into double figures (in the UK alone) in terms of
fatalities when it comes to stall/spin accidents in the Puchacz. Compare this
to gliders like the twin Grob and K-21: there are far greater numbers of them
flying many times more hours with a much better record. Even older machines
such as the K-13 stand out well in comparison.
I really can't see the advantage of a training glider that spins so readily and
kills you if you get the recovery (slightly) wrong.
I think some of the instructing fraternity (in the UK) have become too focussed
on spinning as an 'exercise' and not something to be avoided. I believe that if
a significant group of pilots are having _inadvertent_ stall/spin
incidents/accidents when they are flying solo, then there is something very
very wrong with the most elementary training we are giving.
I read and hear much concerning technical details of spinning, i.e. what glider
X does after 5 turns with part aileron and that glider Y flicks when you yank
and stamp on the controls. All fairly irrelevant. If you get to the point of
having to do a full recovery one might question as to how you got there in the
first place. If you are low down (especially in machines like the Puchacz),
where most bad accidents occur, knowing how to recover from a spin is probably
not going to be of much use. Indeed, it may help to make the subsequent impact
unsurviveable.
What we seem to be failing to do is to instill a basic awareness of what the
glider is up to, and the _instinctive_ reactions required if the airframe stops
responding to your commands. Mike Cuming wrote a seminal article in S&G, some
years back, entiltled: "STOP PULLING THE STICK BACK!". This should be required
reading for all pre-solo students.
If you really want to show people full-blooded spins and recoveries, take them
up to a safe height in an aerobatic power aircraft, certified for those kind of
manoevres. You will be able to do much more for a lot less money.
Frankly, I see little point in making pilots deliberately demonstrate their
'expertise' in abusing a glider to the point it autorotates, then attempting to
do something about it. This is not the world aerobatic championships. I would
much rather see immediate instinctive corrections to any possible loss of
control.
To the experienced pilots/instructors reading this: when was the last time you
ended up (inadvertently) in a spin? Yes, you get wing drops in thermals etc.
but do you sit there, doing nothing, until the ground and sky start going round
very fast? No. I'm sure you don't, as you are alive to read this.
What drove me to stay up at night to write this post was a feeling of
anger/helplessness/sadness that yet more people have died in what I regard as a
pointless exercise. I knew the P1 in the double-fatal crash this week but not
his fifteen year old student.
Safe flying to all of you.
Old January 26th 04, 12:15 AM
Mike Borgelt
On 25 Jan 2004 01:26:39 GMT, (Edward Downham)
unsurviveable.
control.
Thank you Edward. That is the best article on this issue I have ever
seen.
I agree 100% and particularly with the "do it in a power plane
designed for this". I did this two years ago in a Pitts S2A with an
experienced airshow pilot who is also an aerobatic instructor. We both
wore parachutes, had a proper briefing and agreed to abandon ship if
control not regained by 4000 feet AGL. All spins were begun from at
least 9000 feet. I learned more about spinning in that hour than in my
previous 35 years flying.
Now for a solution to keep everyone happy - I believe we have the
technology to build a realistic, close to full motion, spin simulator
at an affordable price.
This will allow through and complete exploration of the pre stall,
stall and spin regime for training and combine this with one real full
spin aircraft exercise at altitude with proper precautions and
briefing.
Lets do this and stop killing people in training exercises.
We lost a couple of people in Australia a few years ago in a Blanik
during an annual "spin check".
The spin turned into a spiral and the aircraft broke up in the
recovery. They weren't at high altitude nor wearing parachutes.
Many experienced pilots I know flat out refuse to do full spins during
annual checks as being an unnecessary risk. They will happily
demonstrate stalls and incipient spins.
Mike Borgelt
Old January 26th 04, 01:56 AM
Bill Daniels
"Mike Borgelt" wrote in message
news
field
explain.
terms of
this
them
machines
readily and
focussed
that if
very
glider
yank
of
in the
Puchacz),
probably
impact
unsurviveable.
stops
some
required
them
kind of
their
attempting to
would
control.
time you
etc.
round
regard as a
not
seen.
briefing.
Mike Borgelt
I did an annual check of a ATP pilot who owns a glider. He had also been
flying aerobatic aircraft such as the Citabria and PItts. The annual check
was in a Blanik L-23. We decided on a two turn spin so that I could know
when to expect a recovery attempt.
At two turns, I saw the rear pedals shift to their anti-spin position but
the stick remained aft of center and the L-23 continued to spin as if
nothing had been done to stop it. I said, "two turns" to remind him of our
bargain. Then the stick moved forward and the glider stopped rotating and
entered the recovery dive.
Asked about the delay in recovery, the pilot said that the standard recovery
technique used in the powered aircraft he had been flying was just to
reverse the rudder and to keep the stick aft of center. I pointed out that
every glider I knew of required forward stick for a sure recovery. (We did
several more spins until we both were comfortable with his spin recovery
technique.)
I think the take-home lesson is that airplanes can spin more benignly than
gliders. Relying on spin training in airplanes is just not always
appropriate and can leave the pilot with misconceptions about glider spin
recovery.
I think that, if you fly gliders that will spin, it is wise to experience
the spin recovery at least once and preferably more often than that.
That said, there is nothing wrong with basic training that emphasizes
recognition of an incipient spin over spin recovery. Recognition that a
spin is imminent, and knowledge of the technique to prevent it, will save
more lives than expert spin recovery.
So, is spin training dangerous? Yes, but much less dangerous than not doing
spin training. The path from novice to expert is sometimes fraught with
peril but remaining a novice is more dangerous still. The Puch, Blanik, and
Lark spin more like the glass gliders most of us fly. As such, they are
excellent trainers. Just choose an instructor that is very experienced with
them.
Bill Daniels
Bill Daniels
Old January 27th 04, 10:54 PM
Mike Borgelt
On Sun, 25 Jan 2004 18:56:36 -0700, "Bill Daniels"
technique.)
recovery.
I think the gentleman's spin recovery training was suspect. Since when
was standard spin recovery other than:
Full opposite rudder
Pause
Move the stick forward
When the spin stops centralise rudder and recover gently from the
dive?
Even if the aircraft recovers with mere application of opposite rudder
surely the full standard recovery must be taught?
The fatality in the Blanik here a few years ago was that the spin
became a spiral so even the Blanik won't necessarily stay in a spin.
As I said I agree. Note however you cannot do this in all types that
you fly. Some like the Standard Libelle and Nimbus 3DM are placarded
against deliberate spins.
them.
Bill Daniels
When two testpilot/spin instructors, at least one of whom had
extensive spin experience in gliders can kill themselves in a Puch by
spinning in I wonder how much experience the instructor has to have?
The experienced cross country pilots I know never spin accidently. At
most they may get a wing drop in a thermal. The question is what do
they know or do that prevents them from ever spinning accidently?
If we find this out we might make some progress.
Mike
Old January 27th 04, 11:21 PM
Bill Daniels
Snip---
Snip---
Mike
It does make one wonder. I seem to recall something on r.a.s. to the effect
that an inspection of a Puch in the USA turned up a metal plate that was
adrift somewhere in the rudder control curcuit. This loose plate, it was
said, could prevent the rudder from moving back from the fully deflected
position. I seem to recall that it was suspected that some of the spin-in
accidents might be due to this.
Perhaps someone with a better memory will comment.
Bill Daniels
Old January 31st 04, 01:46 PM
Janusz Kesik
U=BFytkownik Bill Daniels w wiadomooci do grup =
dyskusyjnych ...
=20
It does make one wonder. I seem to recall something on r.a.s. to the =
effect
that an inspection of a Puch in the USA turned up a metal plate that =
was
adrift somewhere in the rudder control curcuit. This loose plate, it =
was
said, could prevent the rudder from moving back from the fully =
deflected
position. I seem to recall that it was suspected that some of the =
spin-in
One day I was told about a Puchacz accident at Bielsko in southern =
Poland, many years ago. The trim handle (a small green ball made of =
fabric) went loose and disappeared. The student replaced it with another =
one, but didn't check where's the one which got lost, and then took off =
for a spin training...
The ball has been left inside, and it managed to get into controls, and =
in the moment they were in spin and tried to move stick forward to get =
out of the spin, it locked itself preventing the stick from moving =
forward. The student with instructor kept on pushing the stick, and =
finally hit the ground killing themselves.
Finally it became clear that if they had moved stick back for a second, =
they could survive, because thic could loosen the ball...
I just wonder how the student stupid had to be to not check the glider =
throughly after noticing that the handle has gone.
Regards,
--=20
Janusz Kesik
visit
www.leszno.pl - home of the www.css-leszno.it.pl
Old January 31st 04, 06:11 PM
Vaughn
"Janusz Kesik" wrote in message
Three thoughts:
1) I find it courious that the student was doing maintence work on the
glider. and...
2) In exactly the same situation, I wonder if I would have been sufficiently
courious to check all of the deep-dark spaces in the belly of the glider.
Frankly, I am afraid of the answer. Perhaps that is why we let A&P's do
that sort of thing? and...
3) In many gliders it is very difficult to inspect under the floorboards and
back in the tailcone, yet you never really know what may be lurking there,
tools, lost cellphones, critters, etc. I once saw a good-sized snake bail
out of a glider just as it was landing and then slink off quickly,
apparently none the worse for the experience. It was not the first flight
of the day for that ship.
Regards,
Vaughn
Janusz Kesik
visit
Old February 1st 04, 09:30 AM
Martin Gregorie
On Sat, 31 Jan 2004 14:46:10 +0100, "Janusz Kesik"
I just wonder how the student stupid had to be to not check the glider throughly after noticing that the handle has gone.
I wonder if he thought to tell anybody else about the missing knob.
martin@ : Martin Gregorie
gregorie : Harlow, UK
demon :
co : Zappa fan & glider pilot
uk :
Old January 27th 04, 11:48 PM
Arnold Pieper
If you read the other thread about spinning you may understand what
experienced pilots do.
Recovery from incipient spins might be just a sligh easing of the stick with
slight opposite rudder pressure.
No need to dive inside the thermal.
However, the only way to recognize this condition is to train for it, while
also training for fully developed spins, resulting from level attitudes with
pro-turn rudder and low speed (a definite killer in low altitudes).
The reference to the more benign spin characteristic of some training
airplanes is true.
In some of them you don't need to move the stick full forward to recover
from a spin.
Basically the spin breaks off very easily with just a sligh easing of the
control column forward and opposite rudder.
Full forward stick will only cause an excessively nose-low attitude
resulting in a high-speed dive following the spin.
But this is only true in certain aircraft, and if the pilot trains in them
he will recognize this.
The Puchacz has a similar characteristic, actually.
If you press opposite rudder while keeping the stick aft, nothing much
happens for a full turn (I never went beyond that).
But with this opposit rudder applied, as soon as back pressure on the stick
is removed, the glider sort of "snaps" out of the spin.
There is no need to move the stick all the way forward or you will then be
in an aerobatic, 90 degree nose-low dive.
Unnecessary.
As I pointed out earlier, Dick Johnson tested the Puchacz and gave it a
clean bill of health.
www.ssa.org, click on Magazines, Dick Johnson, scroll down to find the
Puchacz evaluations (2 articles).
recovery
that
did
technique.)
than
recovery.
Pause
dive?
doing
and
with
them.
Bill Daniels
Mike
Old January 28th 04, 12:29 AM
JJ Sinclair
Well, we certainly have two schools of thought on this spinning issue. I think
the "Spinners", hearken back 60 years or more and probably have their roots in
military training. They say things like, "Train Hard, Fight Easy" Who are we
fighting? My God, we're killing people as we try to make them safer pilots. I
was amazed to read that the Brits seek out sailplanes with "GOOD" spin
characteristics. Isn't that like buying a sailboat that is easily upset, just
so we can all get dumped in the water and then set it right side up again?
The truth is, most sailplanes from the Eastern block, spin real GOOD. Put them
in the hands of a low time pilot and we are setting up a disaster. Aren't we
just asking for trouble when we solo a student in a Puch? We had one spin-in,
here in California with two high time sailplane pilots on board. We had a
single place Lark spin-in from 10,000 feet with a low time pilot on board. RIP
X 3
Here's a thought. Buy sailplanes that don't spin easily (G-103 & ASK-21) and
enjoy this sport by teaching only spin entry and emmediate recovery.
JJ Sinclair
Inspiration by friends - mutal interest and motivation to get the PPL Gary G Piloting 1 October 29th 04 09:19 PM
Baby Bush will be Closing Airports in California to VFR Flight Again Larry Dighera Piloting 119 March 13th 04 02:56 AM
Some Fiction For Interest Badwater Bill Rotorcraft 8 March 6th 04 03:45 AM
Spinning Horizon Mike Adams Owning 8 December 26th 03 01:35 AM
