From what I can gather, the low-power transponders are 400mA
and encoder 200mA at about 12 volts. The microfilm superthin solar panels about 1 foot square (12" by 12") advertise 600mA at about 12 volts. Sadly, the solar panels in my experience don't put out rated power on typical days, with less than ideal sun angles (maybe really only putting out 25%). Also, I suspect transponders underrate their power consumption, and if flown in high jet traffic areas (where they get pinged by ATC and the jets), probably consume quite a bit more. So really one might be looking at 8 square feet of solar array just for a transponder! Maybe a little hard to implement on a glider without using the wing surfaces, and the caveats that entails... Well, it was a nice thought... |
![]() "Mark James Boyd" wrote in message news:40140af4$1@darkstar... From what I can gather, the low-power transponders are 400mA and encoder 200mA at about 12 volts. The microfilm superthin solar panels about 1 foot square (12" by 12") advertise 600mA at about 12 volts. Sadly, the solar panels in my experience don't put out rated power on typical days, with less than ideal sun angles (maybe really only putting out 25%). Also, I suspect transponders underrate their power consumption, and if flown in high jet traffic areas (where they get pinged by ATC and the jets), probably consume quite a bit more. So really one might be looking at 8 square feet of solar array just for a transponder! Maybe a little hard to implement on a glider without using the wing surfaces, and the caveats that entails... Well, it was a nice thought... That's today, tomorrow may well be different. http://www.lbl.gov/Science-Articles/...olarcells.html http://www.scienceagogo.com/news/200...runc_sys.shtml or this http://www.californiasolarcenter.org...0030128-6.html Perhaps someday be able to shoot a top coat that will take care of keeping the batteries up. There's work being done at the nanotech level to make these much more efficient. Imagine the diversity of applications, roofing materials, car finishes, clothing, tents, aircraft, boats, etc. Frank Whiteley Colorado |
The situation isn't nearly so gloomy!
Mark James Boyd wrote: From what I can gather, the low-power transponders are 400mA and encoder 200mA at about 12 volts. My Becker and ACK encoder ~ 410 ma with no replies, and less than 500 ma even in southern California airspace. A 5 hour flight is 2.5 amphour, leaving lots of juice for the other instruments on the typical 7 ah battery. The microfilm superthin solar panels about 1 foot square (12" by 12") advertise 600mA at about 12 volts. Sadly, the solar panels in my experience don't put out rated power on typical days, with less than ideal sun angles (maybe really only putting out 25%). Put two on! But even one, with your assumption, means the battery has to supply 1.7 ah to the battery, leaving ~ 5 ah in the battery for other purposes. With two supplying 300 ma, the net transponder usage is only 1 ah! Also, I suspect transponders underrate their power consumption, and if flown in high jet traffic areas (where they get pinged by ATC and the jets), probably consume quite a bit more. Not true for the Becker. Ask a Microair owner about it's consumption. So really one might be looking at 8 square feet of solar array just for a transponder! Maybe a little hard to implement on a glider without using the wing surfaces, and the caveats that entails... The Strobl panels used by the German manufacturers are very efficient (http://www.strobl-solar.de/ - use the Google translation tools) and can supply enough with less than 2 square feet. The disadvantage is the cost, so most people would probably opt for another, or bigger, battery. Well, it was a nice thought... It _is_ a nice thought! People are doing it - it works! -- ----- change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Non-radar transponder codes | Michael | Instrument Flight Rules | 16 | February 13th 04 01:15 PM |
Dual Transponders? | Scott Aron Bloom | Instrument Flight Rules | 17 | December 14th 03 05:54 AM |
Mode S Transponders - Can ATC tell the difference? | Doodybutch | Owning | 2 | August 10th 03 06:21 AM |
Transponders, Radios and other avionics procurement questions | Corky Scott | Home Built | 5 | July 2nd 03 11:27 PM |
