![]() "Mike Borgelt" wrote in message news ![]() On 25 Jan 2004 01:26:39 GMT, (Edward Downham) wrote: If I took charge of a gliding club using Puchacz(s) for basic training, the first thing I would do is pile them all in a heap in the corner of the field and set fire to them. This may come across as something of a controversial viewpoint. Let me explain. As far as I know, we are now into double figures (in the UK alone) in terms of fatalities when it comes to stall/spin accidents in the Puchacz. Compare this to gliders like the twin Grob and K-21: there are far greater numbers of them flying many times more hours with a much better record. Even older machines such as the K-13 stand out well in comparison. I really can't see the advantage of a training glider that spins so readily and kills you if you get the recovery (slightly) wrong. I think some of the instructing fraternity (in the UK) have become too focussed on spinning as an 'exercise' and not something to be avoided. I believe that if a significant group of pilots are having _inadvertent_ stall/spin incidents/accidents when they are flying solo, then there is something very very wrong with the most elementary training we are giving. I read and hear much concerning technical details of spinning, i.e. what glider X does after 5 turns with part aileron and that glider Y flicks when you yank and stamp on the controls. All fairly irrelevant. If you get to the point of having to do a full recovery one might question as to how you got there in the first place. If you are low down (especially in machines like the Puchacz), where most bad accidents occur, knowing how to recover from a spin is probably not going to be of much use. Indeed, it may help to make the subsequent impact unsurviveable. What we seem to be failing to do is to instill a basic awareness of what the glider is up to, and the _instinctive_ reactions required if the airframe stops responding to your commands. Mike Cuming wrote a seminal article in S&G, some years back, entiltled: "STOP PULLING THE STICK BACK!". This should be required reading for all pre-solo students. If you really want to show people full-blooded spins and recoveries, take them up to a safe height in an aerobatic power aircraft, certified for those kind of manoevres. You will be able to do much more for a lot less money. Frankly, I see little point in making pilots deliberately demonstrate their 'expertise' in abusing a glider to the point it autorotates, then attempting to do something about it. This is not the world aerobatic championships. I would much rather see immediate instinctive corrections to any possible loss of control. To the experienced pilots/instructors reading this: when was the last time you ended up (inadvertently) in a spin? Yes, you get wing drops in thermals etc. but do you sit there, doing nothing, until the ground and sky start going round very fast? No. I'm sure you don't, as you are alive to read this. What drove me to stay up at night to write this post was a feeling of anger/helplessness/sadness that yet more people have died in what I regard as a pointless exercise. I knew the P1 in the double-fatal crash this week but not his fifteen year old student. Safe flying to all of you. Thank you Edward. That is the best article on this issue I have ever seen. I agree 100% and particularly with the "do it in a power plane designed for this". I did this two years ago in a Pitts S2A with an experienced airshow pilot who is also an aerobatic instructor. We both wore parachutes, had a proper briefing and agreed to abandon ship if control not regained by 4000 feet AGL. All spins were begun from at least 9000 feet. I learned more about spinning in that hour than in my previous 35 years flying. Now for a solution to keep everyone happy - I believe we have the technology to build a realistic, close to full motion, spin simulator at an affordable price. This will allow through and complete exploration of the pre stall, stall and spin regime for training and combine this with one real full spin aircraft exercise at altitude with proper precautions and briefing. Lets do this and stop killing people in training exercises. We lost a couple of people in Australia a few years ago in a Blanik during an annual "spin check". The spin turned into a spiral and the aircraft broke up in the recovery. They weren't at high altitude nor wearing parachutes. Many experienced pilots I know flat out refuse to do full spins during annual checks as being an unnecessary risk. They will happily demonstrate stalls and incipient spins. Mike Borgelt I did an annual check of a ATP pilot who owns a glider. He had also been flying aerobatic aircraft such as the Citabria and PItts. The annual check was in a Blanik L-23. We decided on a two turn spin so that I could know when to expect a recovery attempt. At two turns, I saw the rear pedals shift to their anti-spin position but the stick remained aft of center and the L-23 continued to spin as if nothing had been done to stop it. I said, "two turns" to remind him of our bargain. Then the stick moved forward and the glider stopped rotating and entered the recovery dive. Asked about the delay in recovery, the pilot said that the standard recovery technique used in the powered aircraft he had been flying was just to reverse the rudder and to keep the stick aft of center. I pointed out that every glider I knew of required forward stick for a sure recovery. (We did several more spins until we both were comfortable with his spin recovery technique.) I think the take-home lesson is that airplanes can spin more benignly than gliders. Relying on spin training in airplanes is just not always appropriate and can leave the pilot with misconceptions about glider spin recovery. I think that, if you fly gliders that will spin, it is wise to experience the spin recovery at least once and preferably more often than that. That said, there is nothing wrong with basic training that emphasizes recognition of an incipient spin over spin recovery. Recognition that a spin is imminent, and knowledge of the technique to prevent it, will save more lives than expert spin recovery. So, is spin training dangerous? Yes, but much less dangerous than not doing spin training. The path from novice to expert is sometimes fraught with peril but remaining a novice is more dangerous still. The Puch, Blanik, and Lark spin more like the glass gliders most of us fly. As such, they are excellent trainers. Just choose an instructor that is very experienced with them. Bill Daniels Bill Daniels |
On Sun, 25 Jan 2004 18:56:36 -0700, "Bill Daniels"
wrote: Asked about the delay in recovery, the pilot said that the standard recovery technique used in the powered aircraft he had been flying was just to reverse the rudder and to keep the stick aft of center. I pointed out that every glider I knew of required forward stick for a sure recovery. (We did several more spins until we both were comfortable with his spin recovery technique.) I think the take-home lesson is that airplanes can spin more benignly than gliders. Relying on spin training in airplanes is just not always appropriate and can leave the pilot with misconceptions about glider spin recovery. I think the gentleman's spin recovery training was suspect. Since when was standard spin recovery other than: Full opposite rudder Pause Move the stick forward When the spin stops centralise rudder and recover gently from the dive? Even if the aircraft recovers with mere application of opposite rudder surely the full standard recovery must be taught? The fatality in the Blanik here a few years ago was that the spin became a spiral so even the Blanik won't necessarily stay in a spin. I think that, if you fly gliders that will spin, it is wise to experience the spin recovery at least once and preferably more often than that. As I said I agree. Note however you cannot do this in all types that you fly. Some like the Standard Libelle and Nimbus 3DM are placarded against deliberate spins. That said, there is nothing wrong with basic training that emphasizes recognition of an incipient spin over spin recovery. Recognition that a spin is imminent, and knowledge of the technique to prevent it, will save more lives than expert spin recovery. So, is spin training dangerous? Yes, but much less dangerous than not doing spin training. The path from novice to expert is sometimes fraught with peril but remaining a novice is more dangerous still. The Puch, Blanik, and Lark spin more like the glass gliders most of us fly. As such, they are excellent trainers. Just choose an instructor that is very experienced with them. Bill Daniels When two testpilot/spin instructors, at least one of whom had extensive spin experience in gliders can kill themselves in a Puch by spinning in I wonder how much experience the instructor has to have? The experienced cross country pilots I know never spin accidently. At most they may get a wing drop in a thermal. The question is what do they know or do that prevents them from ever spinning accidently? If we find this out we might make some progress. Mike |
![]() "Mike Borgelt" wrote in message ... Snip--- When two testpilot/spin instructors, at least one of whom had extensive spin experience in gliders can kill themselves in a Puch by spinning in I wonder how much experience the instructor has to have? Snip--- Mike It does make one wonder. I seem to recall something on r.a.s. to the effect that an inspection of a Puch in the USA turned up a metal plate that was adrift somewhere in the rudder control curcuit. This loose plate, it was said, could prevent the rudder from moving back from the fully deflected position. I seem to recall that it was suspected that some of the spin-in accidents might be due to this. Perhaps someone with a better memory will comment. Bill Daniels |
![]() U=BFytkownik Bill Daniels w wiadomooci do grup = dyskusyjnych ... =20 It does make one wonder. I seem to recall something on r.a.s. to the = effect that an inspection of a Puch in the USA turned up a metal plate that = was adrift somewhere in the rudder control curcuit. This loose plate, it = was said, could prevent the rudder from moving back from the fully = deflected position. I seem to recall that it was suspected that some of the = spin-in accidents might be due to this. One day I was told about a Puchacz accident at Bielsko in southern = Poland, many years ago. The trim handle (a small green ball made of = fabric) went loose and disappeared. The student replaced it with another = one, but didn't check where's the one which got lost, and then took off = for a spin training... The ball has been left inside, and it managed to get into controls, and = in the moment they were in spin and tried to move stick forward to get = out of the spin, it locked itself preventing the stick from moving = forward. The student with instructor kept on pushing the stick, and = finally hit the ground killing themselves. Finally it became clear that if they had moved stick back for a second, = they could survive, because thic could loosen the ball... I just wonder how the student stupid had to be to not check the glider = throughly after noticing that the handle has gone. Regards, --=20 Janusz Kesik visit www.leszno.pl - home of the www.css-leszno.it.pl |
![]() "Janusz Kesik" wrote in message ... I just wonder how the student stupid had to be to not check the glider throughly after noticing that the handle has gone. Three thoughts: 1) I find it courious that the student was doing maintence work on the glider. and... 2) In exactly the same situation, I wonder if I would have been sufficiently courious to check all of the deep-dark spaces in the belly of the glider. Frankly, I am afraid of the answer. Perhaps that is why we let A&P's do that sort of thing? and... 3) In many gliders it is very difficult to inspect under the floorboards and back in the tailcone, yet you never really know what may be lurking there, tools, lost cellphones, critters, etc. I once saw a good-sized snake bail out of a glider just as it was landing and then slink off quickly, apparently none the worse for the experience. It was not the first flight of the day for that ship. Regards, Vaughn -- Janusz Kesik visit www.leszno.pl - home of the www.css-leszno.it.pl |
On Sat, 31 Jan 2004 14:46:10 +0100, "Janusz Kesik"
wrote: I just wonder how the student stupid had to be to not check the glider throughly after noticing that the handle has gone. I wonder if he thought to tell anybody else about the missing knob. -- martin@ : Martin Gregorie gregorie : Harlow, UK demon : co : Zappa fan & glider pilot uk : |
![]() U=BFytkownik Martin Gregorie w wiadomooci = do grup dyskusyjnych = om... I wonder if he thought to tell anybody else about the missing knob. Could be... JK |
If you read the other thread about spinning you may understand what
experienced pilots do. Recovery from incipient spins might be just a sligh easing of the stick with slight opposite rudder pressure. No need to dive inside the thermal. However, the only way to recognize this condition is to train for it, while also training for fully developed spins, resulting from level attitudes with pro-turn rudder and low speed (a definite killer in low altitudes). The reference to the more benign spin characteristic of some training airplanes is true. In some of them you don't need to move the stick full forward to recover from a spin. Basically the spin breaks off very easily with just a sligh easing of the control column forward and opposite rudder. Full forward stick will only cause an excessively nose-low attitude resulting in a high-speed dive following the spin. But this is only true in certain aircraft, and if the pilot trains in them he will recognize this. The Puchacz has a similar characteristic, actually. If you press opposite rudder while keeping the stick aft, nothing much happens for a full turn (I never went beyond that). But with this opposit rudder applied, as soon as back pressure on the stick is removed, the glider sort of "snaps" out of the spin. There is no need to move the stick all the way forward or you will then be in an aerobatic, 90 degree nose-low dive. Unnecessary. As I pointed out earlier, Dick Johnson tested the Puchacz and gave it a clean bill of health. www.ssa.org, click on Magazines, Dick Johnson, scroll down to find the Puchacz evaluations (2 articles). "Mike Borgelt" wrote in message ... On Sun, 25 Jan 2004 18:56:36 -0700, "Bill Daniels" wrote: Asked about the delay in recovery, the pilot said that the standard recovery technique used in the powered aircraft he had been flying was just to reverse the rudder and to keep the stick aft of center. I pointed out that every glider I knew of required forward stick for a sure recovery. (We did several more spins until we both were comfortable with his spin recovery technique.) I think the take-home lesson is that airplanes can spin more benignly than gliders. Relying on spin training in airplanes is just not always appropriate and can leave the pilot with misconceptions about glider spin recovery. I think the gentleman's spin recovery training was suspect. Since when was standard spin recovery other than: Full opposite rudder Pause Move the stick forward When the spin stops centralise rudder and recover gently from the dive? Even if the aircraft recovers with mere application of opposite rudder surely the full standard recovery must be taught? The fatality in the Blanik here a few years ago was that the spin became a spiral so even the Blanik won't necessarily stay in a spin. I think that, if you fly gliders that will spin, it is wise to experience the spin recovery at least once and preferably more often than that. As I said I agree. Note however you cannot do this in all types that you fly. Some like the Standard Libelle and Nimbus 3DM are placarded against deliberate spins. That said, there is nothing wrong with basic training that emphasizes recognition of an incipient spin over spin recovery. Recognition that a spin is imminent, and knowledge of the technique to prevent it, will save more lives than expert spin recovery. So, is spin training dangerous? Yes, but much less dangerous than not doing spin training. The path from novice to expert is sometimes fraught with peril but remaining a novice is more dangerous still. The Puch, Blanik, and Lark spin more like the glass gliders most of us fly. As such, they are excellent trainers. Just choose an instructor that is very experienced with them. Bill Daniels When two testpilot/spin instructors, at least one of whom had extensive spin experience in gliders can kill themselves in a Puch by spinning in I wonder how much experience the instructor has to have? The experienced cross country pilots I know never spin accidently. At most they may get a wing drop in a thermal. The question is what do they know or do that prevents them from ever spinning accidently? If we find this out we might make some progress. Mike |
Well, we certainly have two schools of thought on this spinning issue. I think
the "Spinners", hearken back 60 years or more and probably have their roots in military training. They say things like, "Train Hard, Fight Easy" Who are we fighting? My God, we're killing people as we try to make them safer pilots. I was amazed to read that the Brits seek out sailplanes with "GOOD" spin characteristics. Isn't that like buying a sailboat that is easily upset, just so we can all get dumped in the water and then set it right side up again? The truth is, most sailplanes from the Eastern block, spin real GOOD. Put them in the hands of a low time pilot and we are setting up a disaster. Aren't we just asking for trouble when we solo a student in a Puch? We had one spin-in, here in California with two high time sailplane pilots on board. We had a single place Lark spin-in from 10,000 feet with a low time pilot on board. RIP X 3 Here's a thought. Buy sailplanes that don't spin easily (G-103 & ASK-21) and enjoy this sport by teaching only spin entry and emmediate recovery. JJ Sinclair |
Repeating someone who wrote this earlier in the week :
"Sure, we should stop training landings as well because that's where the majority of the accidents happen." The ignorance in this particular discussion has reached a level where it's beyond help. "JJ Sinclair" wrote in message ... Well, we certainly have two schools of thought on this spinning issue. I think the "Spinners", hearken back 60 years or more and probably have their roots in military training. They say things like, "Train Hard, Fight Easy" Who are we fighting? My God, we're killing people as we try to make them safer pilots. I was amazed to read that the Brits seek out sailplanes with "GOOD" spin characteristics. Isn't that like buying a sailboat that is easily upset, just so we can all get dumped in the water and then set it right side up again? The truth is, most sailplanes from the Eastern block, spin real GOOD. Put them in the hands of a low time pilot and we are setting up a disaster. Aren't we just asking for trouble when we solo a student in a Puch? We had one spin-in, here in California with two high time sailplane pilots on board. We had a single place Lark spin-in from 10,000 feet with a low time pilot on board. RIP X 3 Here's a thought. Buy sailplanes that don't spin easily (G-103 & ASK-21) and enjoy this sport by teaching only spin entry and emmediate recovery. JJ Sinclair |
Inspiration by friends - mutal interest and motivation to get the PPL | Gary G | Piloting | 1 | October 29th 04 09:19 PM |
Baby Bush will be Closing Airports in California to VFR Flight Again | Larry Dighera | Piloting | 119 | March 13th 04 02:56 AM |
Some Fiction For Interest | Badwater Bill | Rotorcraft | 8 | March 6th 04 03:45 AM |
Spinning Horizon | Mike Adams | Owning | 8 | December 26th 03 01:35 AM |
