"Vaughn" wrote in message ...
"F1y1n" wrote in message om... I once asked an instructor to demonstrate a spin in a two-seat aircraft I was transitioning into. Did you have chutes? In the US, the only time you are allowed to spin dual without chutes is when you are working on a rating that requires spin training. If you were asking the CFI to spin without chutes (just a wild guess), he was 100% correct to turn you down. I would too. Unless you are already CFIG, you are always 'working on a rating' when flying dual with a (current) CFIG. No parachutes needed for spinning. And no, as I said, he did not turn me down because of the lack of a chute. I would also refuse to spin a student in a glider that I had not previously spun myself. This begs the question: Why the hell would you instruct in an aircraft you haven't spun yourself? Doing so would be foolish, IMHO. Like it or not; not in the US, spin training is not required for the commercial rating... ...but it is required for CFI. That does not make every CFI a qualified acro jock. If you read the FARs you will find that spin training is not acro. A spin is a well-behaved, predictable flight regime... Not necessarily true, not even true of all trainers. Some gliders have, (or at least are reputed to have) multiple spin modes. The spin rate, pitch angle, descent rate, and any pitch oscillation amplitude and frequency does depend on the CG and gross weight, sure, but a spin within the CG in an approved glider with a standard airworthiness certificate is always benign can be recovered using the documented procedures. As I said: 'well-behaved' and 'predictable'. Not all aircraft have perfect rigging, and a certain percentage have accumulated repairs and/or mods over years of operation that change the distribution of mass about the various axis and have an unknown effect on spin behavior. Any mods that effect the CG require a new weight & balance. See my comment above re safe flight within CG. You'd be suicidal flying a glider with an unkown spin behavior. Instructing in one would be border-line criminal. My point is: a spin is not some black magic. Learn it, and instruct it. If you are afraid of spinning you shouldn't be flying, much less teaching. Just two weeks ago, I found myself practicing stalls in a 152 that I wouldn't spin in a bet. It had a dent in the leading edge of one wing and had a nasty wing drop at every stall, but otherwise performed well. Most 150s and 152s I have flown drop a wing at stall, as do many older gliders. Does this make them unsafe to spin? Emphatically no! They will spin happily in either direction. |
![]() "F1y1n" wrote in message snip amplitude and frequency does depend on the CG and gross weight, sure, but a spin within the CG in an approved glider with a standard airworthiness certificate is always benign can be recovered using the documented procedures. As I said: 'well-behaved' and 'predictable'. Up to the two turn JAR 22 test standard for modern gliders. Beyond that, you are a test pilot. |
F.L. Whiteley wrote:
"F1y1n" wrote in message snip amplitude and frequency does depend on the CG and gross weight, sure, but a spin within the CG in an approved glider with a standard airworthiness certificate is always benign can be recovered using the documented procedures. As I said: 'well-behaved' and 'predictable'. Not true. The official procedures for weight and balance miss a lot of subtlety. There are those who believe this is what killed Art Scholl... Think about it... |
![]() "F1y1n" wrote in message om... "Vaughn" wrote in message ... "F1y1n" wrote in message om... I once asked an instructor to demonstrate a spin in a two-seat aircraft I was transitioning into. Did you have chutes? In the US, the only time you are allowed to spin dual without chutes is when you are working on a rating that requires spin training. If you were asking the CFI to spin without chutes (just a wild guess), he was 100% correct to turn you down. I would too. Unless you are already CFIG, you are always 'working on a rating' when flying dual with a (current) CFIG. No parachutes needed for spinning. And no, as I said, he did not turn me down because of the lack of a chute. Wrong. This is a very optimistic intrepetation of the FARs that I have heard before, I doubt that it would fly with the FAA. If you don't have a commercial, you are not "working on your CFI". I would also refuse to spin a student in a glider that I had not previously spun myself. This begs the question: Why the hell would you instruct in an aircraft you haven't spun yourself? Doing so would be foolish, IMHO. It is done all the time. Like it or not; not Take it up with the feds, I actually agree. (for the record, I delayed my solo until I received spin training) in the US, spin training is not required for the commercial rating... ...but it is required for CFI. That does not make every CFI a qualified acro jock. If you read the FARs you will find that spin training is not acro. Where? A spin is a well-behaved, predictable flight regime... Not necessarily true, not even true of all trainers. Some gliders have, (or at least are reputed to have) multiple spin modes. The spin rate, pitch angle, descent rate, and any pitch oscillation amplitude and frequency does depend on the CG and gross weight, sure, but a spin within the CG in an approved glider with a standard airworthiness certificate is always benign can be recovered using the documented procedures. As I said: 'well-behaved' and 'predictable'. Read the rest of this thread, and then go back and google old threads on the Puchaz. Not all aircraft have perfect rigging, and a certain percentage have accumulated repairs and/or mods over years of operation that change the distribution of mass about the various axis and have an unknown effect on spin behavior. Any mods that effect the CG require a new weight & balance. See my comment above re safe flight within CG. You'd be suicidal flying a glider with an unkown spin behavior. Instructing in one would be border-line criminal. My point is: a spin is not some black magic. Learn it, and instruct it. If you are afraid of spinning you shouldn't be flying, much less teaching. There is more to it than weight and balance, the distribution of weight around the cg is very important to spin behaviour. My point is that the glider on the flight line may not be the same as the glider that was manufactured. It is idiocy to assume it will always behave the same. Just two weeks ago, I found myself practicing stalls in a 152 that I wouldn't spin in a bet. It had a dent in the leading edge of one wing and had a nasty wing drop at every stall, but otherwise performed well. Most 150s and 152s I have flown drop a wing at stall, as do many older gliders. Does this make them unsafe to spin? Emphatically no! They will spin happily in either direction. Again; this was not the same airplane that left the factory, the airfoils were no longer symmetrical right and left. The airplane follows the laws of physics, it can't read the flight manual. Have a nice life; Vaughn |
![]() "JC" jrc at visi.dot com wrote in message ... Actually Vaugn, you are wrong. Parachutes are not required for spin training. This issue is addressed by the FAA in the Frequently Asked Questions section of their web site. Below is a copy of the question and answer. (The URL for the entire FAQ document is: http://av-info.faa.gov/data/640otherfaq/pt61-17.pdf ) I stand corrected. Vaughn |
Inspiration by friends - mutal interest and motivation to get the PPL | Gary G | Piloting | 1 | October 29th 04 09:19 PM |
Baby Bush will be Closing Airports in California to VFR Flight Again | Larry Dighera | Piloting | 119 | March 13th 04 02:56 AM |
Some Fiction For Interest | Badwater Bill | Rotorcraft | 8 | March 6th 04 03:45 AM |
Spinning Horizon | Mike Adams | Owning | 8 | December 26th 03 01:35 AM |
