If you were within the permitted CoG range, and used
the standard recovery method, the spin behaviour you described is definitely non-compliant with JAR 22 certification rules. JAR22.221 states that a sailplane certificated for intentional spinning must be able to recover from a fully developed spin (5 turns) within 1 turn after recovery action is done. This has to be demonstrated in several loading and control conditions. Additionally, this paragraph states that it must be impossible to obtain uncontrollable spins with any use of the controls. The Puchacz may not have been certificated to JAR 22, but possibly to the older OSTIV rules. However, I very much doubt that this type of behaviour would have been acceptable under older certification rules, although the verification/testing requirements might have been less strict in earlier days. Geir At 01:00 28 January 2004, Tim Shea wrote: I love to spin. It's exciting. I took aerobatic training with Wayne Handley and was taught spin recoveries by him. I have direct experience spinning the Puchacz at Minden. This is what I remember from my experience. Your mileage may vary. With friends (usually lighter than me) in the front, I spun it while sitting in the back seat more than a dozen times. The CG was within the published range and I didn't have any trouble with simple recovery- stick centered and forward and rudder away from the direction of rotation. Worked great. I should mention that I used to be 50 lbs heavier than I am now, but still in the published range for the plane. During the training towards my instructors rating, I spun the Puch twice with my instructor. The first 2 or so rotation spin I was able to recover normally, no sweat. The second manuver was quite different. I was asked to let the spin develop a little deeper for the second. After 4 or so rotations, the nose seemed to float up and the rotation *seemed* to slow considerably. I remember thinking that this is cool! Kind of like floating. When it was time for the recovery I applied the control inputs I'd been taught (as specified above) and much to my surprise, nothing different happened.....for a long time. I estimate that we completed another 5+ rotations nose high before it broke, rolled over and recovered. I had the stick centered and against the front stop with the rudder also pegged away from the rotation. We recovered with several (4 or 5) thousand feet under us (we'd been playing at cloudbase at about 15K). Once on the ground, we discussed this incident in the grumpy bar for at least an hour. I (and he) decided to never spin the Puch again. I didn't. I doubt he did either. I had heard of this happening before. I assumed that it was from operation outside of the design envelope. Apparently I was wrong. John Shelton probably said it best: 'On my own as a test pilot, I will certainly get killed'. I felt like a dumb-ass for quite a while (more than usual) after that. |
Geir Raudsandmoen om wrote: If you were within the permitted CoG range, and used the standard recovery method, the spin behaviour you described is definitely non-compliant with JAR 22 certification rules. JAR22.221 states that a sailplane certificated for intentional spinning must be able to recover from a fully developed spin (5 turns) within 1 turn after recovery action is done. This has to be demonstrated in several loading and control conditions. Fine. Additionally, this paragraph states that it must be impossible to obtain uncontrollable spins with any use of the controls. But how on earth can that be demonstrated? No matter *what* you do, you can't get into an uncontrollable spin? But there are an infinite number of possible things you *might* do with the controls. They can't ALL be tested. -- Bruce |
Independently of the type of certification which did the Puchacz =
undergo, it has been put through a very extensive in-flight testing = program. The SZD used to be a state runned company which in this area = meant that the new glider has to pass a very detailed programme of tests = almost without counting the costs (remember that it was designed in deep = communism era where the economy rules we know didn't exist in practice). It has to be tested thoroughly as it was intended to be full acro = allowed two seater which was mainly designed to be a primary trainer. Nowadays *all* Polish clubs use the Puchacz for spin training (the = Bocians have been prohibited to spin after they reached the age of 25), = as there are no other trainers than few (maybe 5 all) KR-03 Puchateks = (known also as Krosno or Peregrine). For ten years I have been flying = gliders I have never heard of any accident like this one which started = all the recent threads on Puchacz. There were few spin fatalities = indeed, even one in aour club, but all of them happened on the final = leg, or in the moment of the base/final leg turn, most of them caused by = the licensed (but not used to fly from the instructor's cockpit) pilot = in the backseat carrying passenger in the front seat. Regards, --=20 Janusz Kesik visit www.leszno.pl - home of the www.css-leszno.it.pl |
Puchaz Spinning thread that might be of interest in light of the recent accident. | Al | Soaring | 134 | February 9th 04 03:44 PM |
Spinning (mis)concepts | Arnold Pieper | Soaring | 106 | February 7th 04 01:02 PM |
Spinning Horizon | Mike Adams | Owning | 8 | December 26th 03 01:35 AM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
