I was taught this 'pause' between full opposite rudder
and stick forward and the wind 'shadow' effect was the reason; However, since it has been proven that even a Puchacz, which has a low(ish) tailplane, will recover faster without the pause (Dick Johnson) and most gliders have 'T' tails to which it doesn't apply at all, I for one will not be teaching the 'pause' to my students. Rob John Duo 'Si' K6 '350' In a fully developed spin the tail surfaces can see an airflow that has a significant component coming from underneath the tail surfaces. If the tail surfaces are 'conventional,' (i.e. not a T-tail), and the elevator and horizontal stabilizer are on the fuselage, below the rudder, then forward stick produces a 'shadow' in this airflow which can block the lower portion of the rudder near the elevator. This 'shadow' is reduced when the stick is back. If you stand below the elevator and look upward (difficult, I know) and move the stick forward in a 1-26, for example, this 'shadow' effect can be seen. Thus, I was told there are some POH's for conventional tail aircraft that recommend using rudder *before* forward stick in the full spin to maximize the effectiveness of the anti-spin rudder. At least this is what I recall as being the explanation received from my first flight instructor. Does anyone else recall this 'explanation?' Todd Pattist - 'WH' Ventus C (Remove DONTSPAMME from address to email reply.) |
Robert John wrote in message ...
I was taught this 'pause' between full opposite rudder and stick forward and the wind 'shadow' effect was the reason; However, since it has been proven that even a Puchacz, which has a low(ish) tailplane, will recover faster without the pause (Dick Johnson) and most gliders have 'T' tails to which it doesn't apply at all, I for one will not be teaching the 'pause' to my students. Rob John Duo 'Si' K6 '350' Then I hope you will read the revision to the AS-K 21 POH, which updated/changed the spin recovery protocol to include the 'pause' based on flight testing, after a spinning fatality in the K-21. No pause, slower recovery. Pause, more prompt recovery. K-21 is a T-tail. Beware broad judgments. Please know your POH and its recommended procedures. If you teach/deliberately enter spins, have a predetermined exit altitude for non-responsive behavior, or don't bother wearing the chutes. If there was on line access for the USAF Spin Eval report for the K-21, I would make it available... but I have no electronic source. Cindy B www.caracolesoaring.com |
The flight manual for the AS-K21 that I flew yesterday basically says
full opposite rudder, pause, and then stick forward. The manual also had a note that some of the manual's contents had been included due use by the USAF. On the other hand, the flight manual for my LS-3a states to terminate spins by "pronounced deflection of rudder opposite to spin direction and careful pull out". I guess that means you don't have to move the stick forward for spin recovery! Hmmm...must be magic! Steve Robert John wrote in message ... I was taught this 'pause' between full opposite rudder and stick forward and the wind 'shadow' effect was the reason; However, since it has been proven that even a Puchacz, which has a low(ish) tailplane, will recover faster without the pause (Dick Johnson) and most gliders have 'T' tails to which it doesn't apply at all, I for one will not be teaching the 'pause' to my students. Rob John Duo 'Si' K6 '350' In a fully developed spin the tail surfaces can see an airflow that has a significant component coming from underneath the tail surfaces. If the tail surfaces are 'conventional,' (i.e. not a T-tail), and the elevator and horizontal stabilizer are on the fuselage, below the rudder, then forward stick produces a 'shadow' in this airflow which can block the lower portion of the rudder near the elevator. This 'shadow' is reduced when the stick is back. If you stand below the elevator and look upward (difficult, I know) and move the stick forward in a 1-26, for example, this 'shadow' effect can be seen. Thus, I was told there are some POH's for conventional tail aircraft that recommend using rudder *before* forward stick in the full spin to maximize the effectiveness of the anti-spin rudder. At least this is what I recall as being the explanation received from my first flight instructor. Does anyone else recall this 'explanation?' Todd Pattist - 'WH' Ventus C (Remove DONTSPAMME from address to email reply.) |
Steve Pawling wrote:
... On the other hand, the flight manual for my LS-3a states to terminate spins by "pronounced deflection of rudder opposite to spin direction and careful pull out". I guess that means you don't have to move the stick forward for spin recovery! Hmmm...must be magic! ... The stick forward is in some way implied by the "careful pull out", if you keep the stick at the place which caused the spin, i.e. near the back stop, the pull out would be rather agressive if not stalled. |
Inspiration by friends - mutal interest and motivation to get the PPL | Gary G | Piloting | 1 | October 29th 04 09:19 PM |
Baby Bush will be Closing Airports in California to VFR Flight Again | Larry Dighera | Piloting | 119 | March 13th 04 02:56 AM |
Some Fiction For Interest | Badwater Bill | Rotorcraft | 8 | March 6th 04 03:45 AM |
Spinning Horizon | Mike Adams | Owning | 8 | December 26th 03 01:35 AM |
