Contest rules for 04
Old February 2nd 04, 10:49 PM
Eric Greenwell
Mark James Boyd wrote:
Is it just me, or are the competition rules becoming more like a sports car
navigation rally instead of a race?
Bill Daniels
One wonders, if the rules committee is largely unchanged from
the year before, and they come up with new changes, aren't
they saying they were too stupid to get it right the previous
year? So why would they think they'd get it right the
following year?
If only it were that simple! Rules change for several reasons. For example:
1) new technology
2) the contestants change their minds about what they like
3) someone comes up with a new idea (often a pilot not on the committee)
4) a problem is discovered with a previous rule that wasn't discovered
in the initial, limited use
If it were just stupidity, we'd eventually get the right guys on the
committee, but my observation is changing the committee (which has
happened over the years) doesn't change the amount of complaining, but
just who is complaining.
The tasks we flew 30 and 40 years ago were dramatically different than
we fly now. Times change, people change, the rules change. It looks like
noise if you watch just the year-to-year changes, but if you look over a
period of several years, you can see significant changes related mostly
to the 4 points I listed.
change "netto" to "net" to email me directly
Eric Greenwell
Washington State
USA
Old February 3rd 04, 02:11 PM
Brian Case
I am relatively new to contest flying I have been flying about 1
contest per year for the last six years mostly if 15meter and some
Sports Class Contests.
While there have been quite a few changes to the rules in the past 6
years there have really only been 3 or 4 changes that acutally affect
how I fly the contest.
1. GPS is the biggest change which has changed both the start and
finish quite a bit However the Start and Finish are an extremely small
portion of a contest flight and it is much easier that it was when
were using the Visual start finish gate. There have been (and probably
still are) a few years while we figure out the best way to utilize GPS
for the contests.
2. Only last year did the Turn points change much from the 1/4 mile to
1 mile cylinders. This makes the turnpoint easier but again is a
relatively minor change in how the flight is flown.
3. The Post Task is gone replaced with the MAT Task. I personally like
the MAT Task better and really is only a minor change
4. The Turn Area Task, The Jury is still out for me as to how well I
like this task and is acutally the biggest change is how the contest
is flown.
Still overall the contest flying is pretty much the same as it was 6
years ago. While you should be familiar with all the rules the main
points a
1. Figure out how and when to start. (keep it safe)
2. Go fast to the next Turn point (keep it safe)
3. Fly through the Turnpoint (TAT's are bit more complicated here)
(keep it safe)
4. Repeat 2&3 as necessary (keep it safe)
5. Figure out (before the flight) how to finish (keep it safe)
These are the exact same steps that I used 6 years ago to fly a
contest and it still works today. You can research the rules and and
look for ways to use them to improve your score but in the end is
usually the guy that flys the fastest that wins. Unless you finishing
in the top 10% of the Class you don't need to worry about using the
rules to your advantage anyway. You need a lot more practice learning
how to fly fast.
You will learn a lot flying a contest, even if you come if dead last
(and you probably will the 1st few times you fly one) But you might do
more x-country flying in a week than many glider pilots do all year.
Brian
CFIIG/ASEL
Small Club XC contest format & rules Sam Discusflyer Soaring 5 January 25th 04 03:50 AM
Start Anywhere Cylinder (SSA rules proposal) Mark Navarre Soaring 15 September 25th 03 01:13 PM
Safety Rules Pat Russell Soaring 3 September 20th 03 02:58 PM
US Contest Rules Committee Election Ken Sorenson Soaring 4 August 9th 03 07:06 PM
2003 Air Sailing Contest pre-report synopsis Jim Price Soaring 0 July 10th 03 10:19 PM
