So you can't penetrate downwind? So going down wind is withdrawing?
"Chris OCallaghan" wrote in message m... I'll give it a try.... Penetration: a measure of sailplane performance as a function of Lift, Drag, and Airspeed such that increase in drag is disproportionately small compared to increasing airspeed throughout the sailplane's speed range. Since penetration is most often used to describe a sailplane's ability to make progress against a head wind, a "penetration factor" of a sailplane could be measured by establishing L/D at speeds of 60, 80, and 100 knots, or, conversely, at some fixed rate of sink. The 300 feet per minute sink rate speed has been used as a de facto penetration factor in the past. The higher the measured airspeed at -300ft/min, the better the penetration. |
Va and turbulent air penetration speed. | Doug | Instrument Flight Rules | 70 | January 11th 04 08:35 PM |
Va and turbulent air penetration speed. | Doug | Owning | 69 | January 11th 04 08:35 PM |
RV-7a baggage area | David Smith | Home Built | 32 | December 15th 03 04:08 AM |
P-47/51 deflection shots into the belly of the German tanks,reality | ArtKramr | Military Aviation | 131 | September 7th 03 09:02 PM |
