Say a Sparrowhawk and a Cirrus. Guess is the Cirrus will penetrate
better and hence be able to achieve longer flights in windy and / or turbulent conditions? Wow. Now THERE is an interesting question. How does a glider with super stiff wings do going through turbulence vs. one with flexing wings? I'd suspect the stiffer wings would lose (they'd stall more cleanly instead of absorbing the impact) but the difference may be too small to be important. Any guesses on this one? This is pretty far out of my field... |
Mark James Boyd wrote:
Say a Sparrowhawk and a Cirrus. Guess is the Cirrus will penetrate better and hence be able to achieve longer flights in windy and / or turbulent conditions? Wow. Now THERE is an interesting question. How does a glider with super stiff wings do going through turbulence vs. one with flexing wings? I'd suspect the stiffer wings would lose (they'd stall more cleanly instead of absorbing the impact) but the difference may be too small to be important. Any guesses on this one? This is pretty far out of my field... Don't think its stiff vs. flexy. Rather, how well laminar flow is maintained (less drag) with less than perfect flow over the wings. Apparently some airfoils do better than others. This belief with the ASW-24 (which I've heard is suspect) probably cost more sales than races. Why a Cirrus would be better than a Sparrowhawk in this regard is beyond my understanding. BTW Ventii have very stiff wings and do well in turbulence and headwinds. Conjecturally Yours, Shawn |
If Gary Osoba is flying the SparrowHawk in turbulent conditions, he
has a nearly infinite L/D. He can do the dynamic soaring thing and extract energy from the turbulence and just keep going. I've seen him do it and it is amazing. If it is me flying, I don't know how to do dynamic soaring, so I tighten my belts and press on. The SparrowHawk is very stable and, while it has very low inertia, it has fairly high damping in all axes, so requires relatively little input from the pilot in turbulence so there would not be much additional drag from control deflections. Never have flown a Cirrus so I can't comment about it in this regard. The varying angles of attack will make a difference depending how much time is spent out of the drag bucket. No idea how it would compare on this example. At the speeds you would be flying into a headwind, you would have to have an incredibly strong shear to increase angle of attack to the point of stall so that wouldn't be much of a worry. If it is that strong, nothing flies very well. The stiffness issue is a little complex. If the energy from a vertical gust is used to bend the wing, less gets transferred to the glider. The glider can gain energy from both up and down gusts (and side gusts but that is more complicated). Taras Kiciniuk (I am really sorry if I spelled the last name wrong) has a great presentation on dynamic soaring that explains this with vector diagrams. One should actually pull the instant you hit an upward gust and push the instant you hit a downward gust. This is half of what Gary Osoba does. It is also backwards to what you work really hard at flying powered airplanes so the retraining is taking a while. ![]() Other aeroelastic effects would also make a difference. Generally, wings are designed to wash out a bit as positive load is applied (leading edge twists down as tip goes up). This prevents divergence which is bad - if the wing twists the other way (washes in), a.o.a. increases with positive load which increases a.o.a. which makes more positive load and so on - BANG. The more flexible wing will probably twist more, relieving more load and thus, transferring less energy to the glider. Therefore, I think the stiffer glider will have the advantage over the more flexible one, everything else being equal. Is any of this enough to notice (without using the dynamic soaring techniques)? I've no idea. The results would certainly be highly variable with the conditions. Doug Taylor Shawn Curry wrote in message link.net... Mark James Boyd wrote: Say a Sparrowhawk and a Cirrus. Guess is the Cirrus will penetrate better and hence be able to achieve longer flights in windy and / or turbulent conditions? Wow. Now THERE is an interesting question. How does a glider with super stiff wings do going through turbulence vs. one with flexing wings? I'd suspect the stiffer wings would lose (they'd stall more cleanly instead of absorbing the impact) but the difference may be too small to be important. Any guesses on this one? This is pretty far out of my field... Don't think its stiff vs. flexy. Rather, how well laminar flow is maintained (less drag) with less than perfect flow over the wings. Apparently some airfoils do better than others. This belief with the ASW-24 (which I've heard is suspect) probably cost more sales than races. Why a Cirrus would be better than a Sparrowhawk in this regard is beyond my understanding. BTW Ventii have very stiff wings and do well in turbulence and headwinds. Conjecturally Yours, Shawn |
Shawn Curry wrote:
Mark James Boyd wrote: Say a Sparrowhawk and a Cirrus. Guess is the Cirrus will penetrate better and hence be able to achieve longer flights in windy and / or turbulent conditions? Wow. Now THERE is an interesting question. How does a glider with super stiff wings do going through turbulence vs. one with flexing wings? I'd suspect the stiffer wings would lose (they'd stall more cleanly instead of absorbing the impact) but the difference may be too small to be important. Any guesses on this one? This is pretty far out of my field... Don't think its stiff vs. flexy. Rather, how well laminar flow is maintained (less drag) with less than perfect flow over the wings. Apparently some airfoils do better than others. This belief with the ASW-24 (which I've heard is suspect) probably cost more sales than races. Why a Cirrus would be better than a Sparrowhawk in this regard is beyond my understanding. BTW Ventii have very stiff wings and do well in turbulence and headwinds. Conjecturally Yours, Shawn I was wondering more about the differences in mass, rotational inertia, control effectiveness... Cirrus is a lot heavier than a sparrowhawk in percentage terms, so presumably will tend to fly through minor turbulence with less upset. Conversely Cirrus has lazy aileron response, so roll upsets take a little longer with controls deflected - presumably less efficient. Cirrus has all moving stabilisor - very powerful in pitch, and easy to get unintentional pitch movements in rough air. Cirrus wings are like rock - graphite 13% (?) wings on Sparrowhawk presumably just shrug off a lot of what shakes the first generation glass ships. Just idle wonderment on my part. Never flown a Sparowhawk, have some vague idea that what makes a difference in XC in my Cirrus is flying smoothly. Cheers Bruce |
Va and turbulent air penetration speed. | Doug | Instrument Flight Rules | 70 | January 11th 04 08:35 PM |
Va and turbulent air penetration speed. | Doug | Owning | 69 | January 11th 04 08:35 PM |
RV-7a baggage area | David Smith | Home Built | 32 | December 15th 03 04:08 AM |
P-47/51 deflection shots into the belly of the German tanks,reality | ArtKramr | Military Aviation | 131 | September 7th 03 09:02 PM |
