Ultra Light Towing
Old February 7th 04, 05:34 AM
Andreas Maurer
On Fri, 06 Feb 2004 20:57:58 +0100, Stefan
I've flown a Janus behind a G3-Mirage. It takes definitely longer to get
off the ground, but once airborne, the climb rate is nearly that of an
"ordinary" plane. The whole tow takes a bit longer, but due to the much
lower cost of the UL, it's still much cheaper.
I'd say it works fine from a paved runway or from a long grass runway.
Not recommended from short runways or with a tailwind, especially if the
rope break options are difficult or if there are obstacles at the end of
the runway.
I heard from a reliable source that aerotow tests with a single-seater
(iirc Ventus) behind an Impule 100 with a 100 hp Rotax 912S showed a
climb rate of more than 1.000 fpm... (!). This might be the first
ultralight that is a full replacement for a Remorqeur, even on
less-than-perfect conditions.
It helps significantly if the tow plane is aerodynamically clean.
The G3 Mirage and Mattin Wezel's Condor are NOT clean.
Bye
Andreas
Old February 7th 04, 09:34 AM
Bruce Greeff
the runway.
Bye
Andreas
Where could we get more information on said Impule ultralight?
Bruce
Old February 7th 04, 03:13 PM
Andreas Maurer
On Sat, 07 Feb 2004 11:34:31 +0200, Bruce Greeff
www.impulse-aircraft.de
Bye
Andreas
Old February 7th 04, 03:17 PM
"Bruce Greeff" wrote in message
Bruce
A Google search for "Impule ultralight" yielded nothing: however, "Impulse
ultralight" provided several links including the following:
http://www.impulse-aircraft.de/english/home/firma.html
http://www.soaridaho.com/
Old February 9th 04, 05:41 AM
Bruce Greeff
Bruce
Thanks - I got the same and was wondering if it was a typo, or not.
Skycraft Landing Light Question Jay Honeck Owning 15 February 3rd 05 06:49 PM
C-172 landing light switch JFLEISC Piloting 16 May 6th 04 01:15 AM
C-172 landing light switch JFLEISC Owning 10 May 5th 04 11:05 PM
The light bulb Greasy Rider Military Aviation 6 March 2nd 04 12:07 PM
OT but very funny after some of the posts we have had of late. Mycroft Military Aviation 1 August 8th 03 10:09 PM
