Z Goudie wrote in message ...
That old red herring again! The glider is flying in an airmass which is moving over the ground at a constant rate. No additional acceleration is required apart from that normally needed in a turn to supply the turning force. There may be some effect caused by descending/putting the lower wing down through any wind gradient but this actually improves the situation as the air is moving 'away' from the path of the glider more slowly and will consequently cause some increase in airspeed. (You can try the opposite of that effect by pulling up from a downwind racing finish through a strong wind gradient; watch the airspeed decay at an alarming rate). The biggest problem is that the apparent speed over the ground in say a 15kt wind jumps by 30kts and results in people trying to reduce the ground rush by raising the nose with no reference to the ASI. We have very nice herring in NL, not red however. Indeed I made a wrong supposition in my calculation of a 10° pitch angle required during the turn back curve of the DG500 to the airfield. A steeper pitch angle then the pilot obviously applied would have helped him a lot though to keep the glider from stalling and spinning in. The comment of one of our aerobatic pilots is that the DG-pilot flew to slow in the last part of the flight and a full spin with crossed controls (right rudder and left stick) evolved. The air may have been very turbulent in the lower layer because of several obstructions on the field. Karel |
SR22 Spin Recovery | gwengler | Piloting | 9 | September 24th 04 07:31 AM |
Spin Training | Captain Wubba | Piloting | 25 | April 12th 04 02:11 PM |
Cessna 150 Price Outlook | Charles Talleyrand | Owning | 80 | October 16th 03 02:18 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
