Eric Greenwell wrote: Mark James Boyd wrote: Every SparrowHawk built has been fitted with a BRS. Every customer has selected this option so far. We expect this to continue. Number 10 will fly in a couple of weeks and will have a BRS. Regards Greg Cole Greg Cole! bows down again and again, "we are not worthy" chanted...etc :- Outstanding! It seems to make a TON of sense both from the customer AND manufacturer perspective. I don't want to take up to much of your time (you SHOULD be in the shop building a twin-jet Sparrowhawk ![]() But did you use the 8" or 7" diameter systems? While it would be more satisfying to get answers from Greg, he doesn't routinely monitor the group, so I will attempt some answers. I don't know the diameter of the system currently used, but diameter doesn't seem to important to the pilot! I talked to BRS and they said the 8" option was mostly so folks could install an 8" of a certain weight rating, and then switch to a higher "weight" canister later if desired, without the diameter dimension changing... Seems raesonable, since a higher "weight" rating I'd guess also means "softer landing at a lower weight" |
The BRS in the SparrowHawk is a BRS 900 soft pack. The large 'chute
is used because it allows a higher deployment speed. With a maximum 415 lb. glider on a 'chute made for up to 900 lbs., I would expect descent rates to be slow. |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Puchaz spin count 23 and counting | henell | Soaring | 116 | February 20th 04 12:35 AM |
Cessna 150 Price Outlook | Charles Talleyrand | Owning | 80 | October 16th 03 02:18 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
