Russia Sailplanes website
Old February 18th 04, 09:49 PM
Eric Greenwell
John wrote:
The only
negative with the Russia is it is a little pitch sensitive, requiring
re-adjusting attitude with spoiler changes (that is, more spoilers
cause the plane to slow down). Takes a bit of practice to smooth out
your landing if you transition directly from a more stable bird like
the 2-33.
All the gliders I've flown have required a pitch-down when the spoilers
were opened, including my ASH 26 E, ASW 20 C, Libelle 301, Blanik, and more.
The Russia does have a very bad tailwheel that just does not hold air.
Expect to spend around $130 to replace the Russian tailwheel with a
Tost tailwheel. Some owners report leaky mainwheels, but nothing
beyond having to add air every other month. Cheap fixes ($8)
involving Slime are available for the mainwheel.
All tires lose pressure, smaller tires lose pressure more quickly. The
500 x 5 Goodyear tire on the mainwheel of my ASH 26 E required air every
month, even with it's inner tube. It's normal, not a "Russia" thing.
change "netto" to "net" to email me directly
Eric Greenwell
Washington State
USA
Old February 18th 04, 09:58 PM
Eric Greenwell
Willie wrote:
The PW5 seems to be a good fit for me in terms of performance, but I
have heard and read nothing but negative comments from other
sailplane pilots. Is it really a bad ship? It seems to have the
performance that I'm looking for (33 to 1) or better.
It isn't a bad ship. The negative comments are basically 1) "it's ugly",
and 2) "you can buy a used glider with more performance for less money".
The #1 is personal taste. #2 is correct, but not decisive. If you want a
new glider instead of a much older one, or want to fly in the World
Class, then the PW5 is worth considering. There are groups much more
enthused about the PW5 than some the posters here; for example, try
http://www.wcsa.org/ [World Class Soaring Association]
I think the New Zealanders like them too. I had two nice flights in PW5s
when I was down there a few years ago.
Eric Greenwell
Washington State
USA
Old February 19th 04, 06:01 AM
Bruce Greeff
Eric's comment is correct, and could do with some expansion.
From personal experience, owning a 30+ year old glass ship is something of a
never ending tinkering excercise.
The seals are rotten, and the canopy doesnt fit like the designer intended, and
the hinges are worn (still legal but I'd like to replace them), and the gell
coat is dull (got to get better with the polish, or maybe that refinish is due)
and then you have to get some regulated part worked on, like - your oxygen
cylinder tested and there is no ISO documentation.
Please note that this is with what many consider to be a "mint" condition 1971
model Schempp-hirth glider. A neglected one, or a rare and poorly supported one
is going to be a lot of work...
I happen to enjoy working on the toy as much as flying her, but if you want a
"get in and fly" experience a new glider will inevitably be less work.
For us it is academic, no PW5s in the country.
Old February 19th 04, 08:40 AM
bumper
I'll add that it's normal for most general aviation tires to lose air. Those
on my Mooney used to require adding air every month or so. But there is a
fix. Michelin sells an aircraft tube advertised to hold air better, and it
works!
John wrote:
The only
the 2-33.
more.
Eric Greenwell
Washington State
USA
Old February 19th 04, 02:06 PM
Mark James Boyd
1. You can't see if it's ugly from the inside. Besides, you're
going to wear that stupid fishing hat and take pictures your
wife will see forever, and you're worried about what the
GLIDER looks like?
2. You can buy a used glider with heavier wings that has
instant maintenance needs for less money. You have all those
hours to work on the glider, but you can't do another
two turns in each thermal? :P
The biggest advantages of the Russia and PW-5 is that they are
small and light and new. This is very convenient.
I personally wouldn't give up this kind of
convenience and ease of use for better performance
in a glider I was going to own, but there are those
who don't mind something bigger, heavier, that needs more
frequent TLC. Which type are you?
Old February 19th 04, 11:34 PM
Kirk Stant
(Mark James Boyd) wrote in message news:4034d0ed$1@darkstar...
GLIDER looks like?
No, but you can see what it looks like everytime to walk up to it, rig
it, wash it, tie it down. To some people beauty is very important.
And for most people, all things being equal, beautiful (or "more
normal") gets the nod.
What instant maintenance? Gliders are not like power planes in this
respect. Every new glider I've seen has needed more work to get it
set up and working correctly than the vast majority of used gliders.
You can buy a fully set-up used glider and be flying as soon as you
hand over the check. Good luck doing that with any new glider, from
PW-5s to Nimbus 4s! But as you say, for some new is important, just
like beauty for others. Oh, and you can do all the extra turns you
want, but if you can't keep up with your friends or get back...
So what if they are small and light? How much time do you spend
rigging? If you really mind lifting a few more pounds for a couple of
minutes, then by all means get a PW-5 (or Russia, or Apis, etc..).
But then you should also not mind the 25% lower performance. Of
course you could get a one-man rig and not worry about the weight at
all. Ironically, we all seem to be paying money to go the gym to work
out... And all that extra weight (meaning wingspan, and wingloading,
etc.) sure is nice to have on a booming day in the desert.
Some personal observations: I know 4 pilots out here in Arizona who
have owned PW-5s; 3 sold them after a couple of seasons and moved up
to 15m ships (304CZ, ASW-20, and Pik-20). The 4th flew his PW-5
primarily to compete and set records, since he also had an LS8 at the
time, since replaced by an ASH-26, he is hardly the typical PW-5 owner
(actually I don't know if he still has it). There is one PW-5 still
based at Turf where I fly, but it's owner bought a motorglider and I
havn't seen the PW fly in a while (pity, since I've been wanting to
try it out before it gets sold!).
Maybe it's just an Arizona thing, but the PW just doesn't seem to hack
it out here - the guys who had them (both experienced and new glider
pilots) got tired of flying by themselves, watching all the standard
and 15m ships disappear in the distance. And that is not my opinion,
it's what they said when asked why they sold their PW-5s.
This isn't a slam of the PW-5, which from all accounts is a nice
little glider to fly, and is popular with clubs. But anyone thinking
of buying one - especially new - instead of flying one in a club,
needs to think hard about what they want to do with it. I actually
tried to get our club to buy one, so I could race it in the World
Class - no luck.
Just my opinion, worth every penny you paid for it.
Kirk
Old February 20th 04, 01:07 AM
Eric Greenwell
I forgot to mention that if a PW5 is interesting to you, and a used
glider is acceptable, a used PW5 will be even cheaper.
Eric Greenwell
Washington State
USA
Old February 20th 04, 03:55 AM
Tim Mara
I dunno about this.......I've seen and owned a number of really nice older
gliders..sure there are plenty of "lumps" for sale out there, but still for
not too may $ you can still find some pretty mint older gliders out
there....maintenance on sailplanes really isn't all that complicated either
and you pretty much can't "ware one out"...you can of course damage one or
mistreat one, you can update one if you like but these are pretty much all
user issues and even new glider buyers do all this too....
but you are right about one thing, some of these new light and ultra-light
gliders are easy to assemble and disassemble and that may be more important
to some of their owners since they probably will need to retrieve them more
often when they don't make the final glide home! :-)
tim
Old February 20th 04, 05:57 AM
Eric Greenwell
snip
If the pilots are flying to the limits of their craft, they'll all
landout about the same. If they are flying to make it home, L/D doesn't
make much difference - the lower L/D glider just doesn't go as far
before turning around and heading b. Landouts are up to the pilot, once
he has some experience.
But to address the weight and size issue: These can actually be an
important factor. One thing that keeps many people from going
cross-country is the potential difficulty of a retrieve. A 600 pound
glider may be more than a guy and his wife can manage, but 300 pound
glider (like a Russia) isn't. Or it may mean s/he can retrieve
themselves, instead of always needing a crew. An easy to retrieve glider
is very liberating for some people, even if it has less performance,
because they are willing to land out more instead of nervously sticking
close to airports.
A high L/D glider effectively puts the airports closer together, but
having a light enough glider so that the retrieve isn't a bitch is a
viable alternative.
Eric Greenwell
Washington State
USA
Old February 20th 04, 06:18 AM
Mark James Boyd
Well, I've also pushed the PW-5 singlehanded about 5 miles total.
I've NEVER pushed the L-13 or 2-33 singlehanded. When
I land out on a runway, it's nice to be able to push the
glider to a certain spot off the runway afterwards, on my own.
The 1-26 was great for this too.
A trailer+glider that requires a V8 truck to tow is different
from one I can tow with a 6 cylinder SUV. The weight is there,
and has other implications than just rigging...
out...
Not me, brother. I'm already in shape. The shape I've chosen
is an oval...
It sounds like the pilots that got a coupla seasons and the
record setter got some great use. These gliders are entry level,
and I'd expect someone to move up later. I thought the
poster was looking for a first time glider (kinda like
a Cezzna 172.) The PIK-20 with a few groundloops and the
ASW-20 with quite a bit of complexity are excellent second gliders.
I've seen a few "used" gliders. Gelcoats, extra weight from repairs,
etc. aren't uncommon, and if you get something really mint,
the $$$$$$ really go upupupup...
Class - no luck.
Agreed, these are good club gliders and entry level first
gliders. If someone has quite a bit more experience, or knows
for sure they will stick with the sport like us fanatics, something
sexier may be warranted. After all, I haven't seen a
World class in the regionals anywhere near where I fly...
Kirk
Website Mltry.- Your Information, Customized for You, Family Communication, Chat, Please Help by Visiting and Signing Gues Wolf Naval Aviation 0 January 8th 05 06:16 AM
Russia Threatens to Strike Terror Bases Dav1936531 Military Aviation 51 September 18th 04 12:52 AM
P-3 Orion website updated Marco P.J. Borst Naval Aviation 0 March 6th 04 08:21 PM
Old website suddenly dies, replaced by new one Jack Glendening Soaring 2 February 8th 04 05:31 PM
Russia joins France and Germany captain! Military Aviation 12 September 9th 03 09:56 AM
