2-33 to 1-26
Old February 21st 04, 03:35 AM
Kevin R. Anderson
Yes, there is trim in a 1-26. Just not a tremendous amount. Usually full
forward is about best L/D, and full back is a good thermaling speed. ( if
the trim is set well)
I have made the transition the other way. I originally trained in a L-23
then transitioned to a 1-26. After over 200 hours in a 1-26 I took a check
flight in a 2-33 while visiting another club. The 1-26 is much lighter on
the controls, and much more responsive. The 2-33 is much more like a truck.
Just use a light hand on the controls. By the time you get off tow and make
a few turns you will get a big smile on your face and see how much fun the
little bird is. I usually fly my pattern at about 50 mph. This and keeping
the yaw string straight will take care of all of the things that have been
written about spins on this thread. I have not found the 1-26 to have any
tendency toward spinning. I have done some spins at altitude intentionally
and recovery is quite quick and conventional. The point is that you do not
want to spin ANY ship in the pattern.
The model of 1-26 that you are going to fly will make a difference in the
amount of spoiler that you will have. I started in an E model with both
upper and lower surface spoilers (our club ship), and now own a B model, top
only so less spoiler, but it still comes down fine. The bird also slips
very well.
Before you ever fly the bird however the first thing that you should do is
to spend 1/2 the amount of a tow to join the 1-26 Association.
www.126association.org The Association supports the 1-26 and sponsors
the 1-26 Championships each year. The last few years a badge camp has also
been included at the Championships.
Once you get some flights in the little bird you will find it to be a
delight. Then consider chasing your badges in the 1-26. At least make sure
that you get your silver in it, however all your badges through diamond are
possible in the 1-26 and are encouraged by die hard 1-26ers.
Hope this helps.
Kevin R. Anderson
Soar 192
Eastern VP 1-26 Association
"Jeremy Zawodny" wrote in message
Kirk Stant wrote:
Martin Gregorie wrote in message
On 19 Feb 2004 17:20:17 -0800, (Lennie the
Trim? In a 1-26?
I've seen one once. Never flown one. Couldn't possibly comment.
Actually, Lennie has a good point. In typical Schweizer fashion, the
trim in a 1-26 is usually (always?) a joke.
I don't know if the 2-32 is typical, but when I was training in 2-32s, I
really noticed if the trim wasn't set properly. Sure, I could still fly
the glider, but it was very distracting.
Jeremy
Old February 21st 04, 03:31 AM
Jim Phoenix
It's posible to adjust the trim mechanism to make it work better, I have
done some spring changes to make mine work very well. It's kinda tough
because you have to take the nose cone off and fiddle around a lopt, and
it's not really that big of a deal - the only time I like to use the trim is
on tow when the towpilot get a bit frisky and forgets its a 1-26 on the end
of the rope and we're bouncing off 70 mph.
Otherwise, the stick forces are so light, it's no big deal, besides, you're
mostly conentrating on where you are going to find that next thermal.
"Kirk Stant" wrote in message
om...
Trim? In a 1-26?
Fortunately, unlike the 2-33, the 1-26 pretty much doesn't need much
trimming due to it's light elevator forces.
Just in case, it's worth checking that the trim control is in the full
forward position prior to takeoff, especially if the pilot is light
and you are not familiar with that particular 1-26 (since they may
vary quite a lot!).
Still a fun little glider to fly, all things considered.
Kirk
