![]() "André Somers" wrote in message ... John Gilbert wrote: Angular guages perhaps. Sweeps of 180 to 270 degrees are quite readable, I agree. But what does the study say about altimeters with dual needles, that rotate multiple times? How many times have you misread the altitude or had to think hard to get it right? This has to be the most confusing instrument to read, unless you don't really care about knowing about that last +/- 1000 feet. Well... hardly ever, but maybe that's because our meters are, well, in meters :-) That means a full spin round is 1000m. Not something you'd easily misjudge I think. André I've flown airplanes with metric instruments (And Russian placards too). The airspeed, rate-of-climb, RPM, manifold pressure were no problem. Numbers is numbers I guess - fly with the needles in the green arc and everything works. But that damn metric altimeter was impossible - no way to read trends on an instrument that insensitive. With an altimeter that reads 1000 feet (304.8 meters) per rev of the big hand, you can thermal by watching the trend of the needle. Responding to "YO": Some people like analog gauges and some don't. Ergonomic studies just produce averages which may be useful to marketeers but what's important individually is what works best for that particular user. If the data are displayed on an electronic screen, the user can select the display method in a setup dialog box. i.e. check box one for round gauge analog, box two for vertical tape with a digit window etc... Check another box for metric or imperial units. With altitude in meters, expanding the scale of a vertical tape gives the same sensitivity as with imperial units. I've also flown with both vertical tapes and round gauges. At first the tapes were confusing but once adapted to the idea of having all the "V" speeds floating alongside the tape with the trend indicators, going back to round mechanical gauges seemed like the stone age. I vote for computer graphic displays of primary flight data. Graphical displays are inevitable anyway since all those little watchmakers who built and repaired mechanical instruments are all retired or dead now. Bill Daniels |
On Thu, 26 Feb 2004 09:28:30 -0700, "Bill Daniels"
wrote: I've flown airplanes with metric instruments (And Russian placards too). The airspeed, rate-of-climb, RPM, manifold pressure were no problem. Numbers is numbers I guess - fly with the needles in the green arc and everything works. But that damn metric altimeter was impossible - no way to read trends on an instrument that insensitive. With an altimeter that reads 1000 feet (304.8 meters) per rev of the big hand, you can thermal by watching the trend of the needle. You've just solved a mystery for me: thanks. The most confusing altimeter I've flown with was a two pointer job but with 3000 ft per rev of the big hand. I found it difficult to read rather than insensitive. I always wondered why anybody would build such a confusing instrument but now I understand. Looks like they retained the gear train from a metric instrument while changing the bellows and scale to make it read in feet, 3000 ft per rev. -- martin@ : Martin Gregorie gregorie : Harlow, UK demon : co : Zappa fan & glider pilot uk : |
Bill Daniels wrote:
I've flown airplanes with metric instruments (And Russian placards too). The airspeed, rate-of-climb, RPM, manifold pressure were no problem. Numbers is numbers I guess - fly with the needles in the green arc and everything works. But that damn metric altimeter was impossible - no way to read trends on an instrument that insensitive. With an altimeter that reads 1000 feet (304.8 meters) per rev of the big hand, you can thermal by watching the trend of the needle. I prefer to thermal on my "butt-feeling" and my audio variometer. I don't need my altimeter for that. I guess that might be different in regions with stronger thermals than we have to make due with here. I guess I could get used to other scales as well (did fly a Sedhberg with Imperial instruments once, real fun to fly 26 knots or so :-) !) Personally, I would not trade by old, reliable mechanical primairy instruments for a computerised system so easily. Not in a glider anyway. Battery power alone is just not reliable enough for primairy instrumentation in my opinion. It's fine for navigation, climb optimizing and other stuff you don't really need to fly safely, but not for altitude or airspeed. André |
Bill Daniels wrote:
... But that damn metric altimeter was impossible - no way to read trends on an instrument that insensitive. With an altimeter that reads 1000 feet (304.8 meters) per rev of the big hand, you can thermal by watching the trend of the needle. ... This is why I like to fly the few gliders in my club where both type of altimeters (meter and feet) are installed. By the way, as a quick way to make the difference between them we call the second one an "altipied", which could be transtalted as "altifeet". So I look on the metric instrument when I have anything to think about glide ratios, as vertical an horizontal distances are so in the same units (and this instrument is set at QFE) and on the other one for anything about airspace (set at QNH or flight level) or when I need self encouragement during climb, as the rotation of the needle is perceptible at a glance when the climbing speed is good. |
Free Flight Planning Software | Dean Wilkinson | Products | 0 | September 18th 04 10:44 PM |
Flight instructors as Charter Pilots | C J Campbell | Piloting | 6 | January 24th 04 07:51 AM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
Real World Specs for FS 2004 | Paul H. | Simulators | 16 | August 18th 03 09:25 AM |
