Oxygen Cylinders
Old February 29th 04, 10:49 PM
Frank Smith
Default Oxygen Cylinders
I know it is out there someplace but I cannot find it, I always thought it
was a DOT thing.
Anybody have the official link to where the cylinder testing intervals are
defined?
Fly safe, have fun,
Frank
to reduce SPAM my return address has been slightly altered.
Old March 1st 04, 01:14 AM
Jim Phoenix
Here ya go:
http://www.access.gpo.gov/nara/cfr/w...9cfrv2_03.html
180.205 and 180. 209 are the ones you're looking for. 180.209 is the chapter
with the number of years between hydro. There were some recent changes to
180.205, but not that you'd notice, bottom line on .205 is you have to have
the cylinder hydro'd prior to re-filling.
"Frank Smith" wrote in message
link.net...
was a DOT thing.
defined?
Fly safe, have fun,
Frank
Old March 1st 04, 01:32 AM
Michael McNulty
I've wondered about this in the past. The cited regulations deal with
packaging for transporting hazardous material in the course of commercial
interstate commerce. I would contend that when I fly with an oxygen tank I
am no more "transporting" oxygen than I am transporting my main wheel tire.
Do these regs really legally apply to gliders or other private aircraft?
Mind you, I'm not advocating ignoring the recertification times listed (I
have mine done), and I know that most FBO's won't fill a cylinder that is
out of date.
"Jim Phoenix" wrote in message
Here ya go:
chapter
have
link.net...
it
was a DOT thing.
are
defined?
Fly safe, have fun,
Frank
Old March 1st 04, 03:08 AM
Jim Phoenix
An excellent point, and one that's been debated for years until guidance was
developed to address this very issue.
As you say - as long as that cylinder is in your glider and you don't
deplete the oxygen, you are not "transporting" for the purposes of the 180
rules, but when you take the cylinder to your local refiller, he may not
refill it (180.205) unless it's been tested per the rule.
No big deal for you, but this has caused a change of heart for those who
have cylinders that remain charged, rarely used (e.g. fire bottles) and only
come off for a weight check or hydro. As long as they aren't transported or
refilled or Part 121 or 135, (it's gets sticky here, so we shall not tread)
they need not be hydro-tested.
Since glider oxygen bottles get deplenished and replenished regularly, the
rule will cause you to comply with the hydro testing requirements. If you
never use the oxygen and bottle remains in your glider and you do not remove
it - it may remain installed.
To quote from the beloved FAA Order 8300.10:
(6) Cylinders may remain in service without the required periodic
retesting, reinspection, and marking as prescribed in 49 CFR § 180.205 if
they meet the criteria in paragraphs 3D(1), (2), (3), and (4) and have not
been discharged.
HBAW 02-01 is he http://www.faa.gov/AVR/AFS/HBAW/HBAW0201B.RTF
Rules, rules, rules...
Nice catch there Michael!
"Michael McNulty" wrote in message
news:%ow0c.22507$aZ3.15552@fed1read04...
I
tire.
out of date.
Here ya go:
chapter
to
have
link.net...
thought
it
was a DOT thing.
are
defined?
Fly safe, have fun,
Frank
Old March 1st 04, 11:07 AM
Bruce Greeff
Frank
Try the local BOC people - they will know your local regulations.
In South Africa it is ten years between full testing (corrosion, cracks and
pressure) believe it or not.
Bruce
What's minimum safe O2 level? PaulH Piloting 29 November 9th 04 07:35 PM
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! Bruce A. Frank Home Built 1 July 4th 04 07:28 PM
hi alt oxygen Arquebus257WeaMag Military Aviation 62 March 28th 04 04:57 PM
Catastrophic Decompression; Small Place Solo Aviation Piloting 193 January 13th 04 08:52 PM
Oxygen mask and regulator sale - update nzuri Soaring 0 October 1st 03 09:31 AM
