I stand corrected. My original query still stands.
Where cameras and smoky barographs were used I can see the sense of a 'declaration'. With GPS do we really need it, surely the criteria should be the distance flown and this can now be positively verified with a data logger. Why complicate something so simple? A 300k or 500k downwind dash ie free distance is ok so why not a triangle At 11:48 05 March 2004, Tim Newport-Peace wrote: X-no-archive: yes In article , Don Johnstone writes At 17:06 04 March 2004, Ian Strachan wrote: snip- A proposal that badge distances should be allowed for free flights as well as pre-declared, was defeated. Which is hard to understand. Anyone with a programmable logger can get airbourne and then declare a flight by entering the details in the logger, and claim a badge flight. Those without a logger which has this facility cannot do this, they are at a disadvantage. Surely we should have a level palying field. Awarding badges on the distance flown where an approved logger is used, whether declared or not, would solve this problem. Those who cannot afford expensive kit are being discriminated against. The award of badges should be made on performance, not the ability of the pilot to purchase an expensive logger. Check your facts Don, declarations made after take-off are invalid. Sporting Code section 3: 4.2.2 Declaration validity a. The last declaration made before takeoff is the only one valid for the flight, but a concurrently flown and different competition task is allowed. Tim Newport-Peace 'Indecision is the Key to Flexibility.' |
I think that there is quite a difference between flying a declared task and
a free distance one. Declarations imply some degree of weather interpreting , task area selection and planning. Free distance - get under a stonking street and keep going! The difference is subtle but its there! Not sure if this is pertinent but free distance tasks are not acceptable for badge flights Ian "Don Johnstone" wrote in message ... I stand corrected. My original query still stands. Where cameras and smoky barographs were used I can see the sense of a 'declaration'. With GPS do we really need it, surely the criteria should be the distance flown and this can now be positively verified with a data logger. Why complicate something so simple? A 300k or 500k downwind dash ie free distance is ok so why not a triangle At 11:48 05 March 2004, Tim Newport-Peace wrote: X-no-archive: yes In article , Don Johnstone writes At 17:06 04 March 2004, Ian Strachan wrote: snip- A proposal that badge distances should be allowed for free flights as well as pre-declared, was defeated. Which is hard to understand. Anyone with a programmable logger can get airbourne and then declare a flight by entering the details in the logger, and claim a badge flight. Those without a logger which has this facility cannot do this, they are at a disadvantage. Surely we should have a level palying field. Awarding badges on the distance flown where an approved logger is used, whether declared or not, would solve this problem. Those who cannot afford expensive kit are being discriminated against. The award of badges should be made on performance, not the ability of the pilot to purchase an expensive logger. Check your facts Don, declarations made after take-off are invalid. Sporting Code section 3: 4.2.2 Declaration validity a. The last declaration made before takeoff is the only one valid for the flight, but a concurrently flown and different competition task is allowed. Tim Newport-Peace 'Indecision is the Key to Flexibility.' |
tango4 wrote:
Not sure if this is pertinent but free distance tasks are not acceptable for badge flights Yes they are ! Either free distance in straight line or free distance with up to 3 (predeclared) turn points -- Denis R. Parce que ça rompt le cours normal de la conversation !!! Q. Pourquoi ne faut-il pas répondre au-dessus de la question ? |
Denis wrote:
tango4 wrote: Not sure if this is pertinent but free distance tasks are not acceptable for badge flights Yes they are ! Either free distance in straight line or free distance with up to 3 (predeclared) turn points I have to point out a confusion that I had as well about definitions. A "free 3TP" task means the 3 turnpoints are declared before the flight, but the order of the turnpoints, and whether 1,2,or all 3 turnpoints are claimed is declared after the flight. I haven't seen this clearly explained anywhere but on some of the declaration forms themselves. This is different from what I would conceptually consider "free," which is when three turnpoins would be chosen after the flight from the three points on the gps trace which are furthest apart. Anyone with more comment on this please correct me if this is mistaken...I've only flown one free 3TP record, and the "free 3TP" task and form were what I used. -- ------------+ Mark Boyd Avenal, California, USA |
Mark James Boyd wrote:
I have to point out a confusion that I had as well about definitions. A "free 3TP" task means the 3 turnpoints are declared before the flight, but the order of the turnpoints, and whether 1,2,or all 3 turnpoints are claimed is declared after the flight. I haven't seen this clearly explained anywhere but on some of the declaration forms themselves. You're right twice. It is correct (for badges), and not clear at all :-((( This is different from what I would conceptually consider "free," which is when three turnpoins would be chosen after the flight from the three points on the gps trace which are furthest apart. That's the "free distance with up to 3 turn points for records" Anyone with more comment on this please correct me if this is mistaken...I've only flown one free 3TP record, and the "free 3TP" task and form were what I used. In short, the "free 3TP" is free for records, and declared (except the finish point and the sequence) for badges. This may be explained by historical reasons, but nowadays it is a full nonsense : the logic would implie that there be "free 3TP" -- like actual 3 TP for records -- and (declared) 3 TP -- like actual 3 TP for badges, but with declared finish point and TP sequence. Furthermore, there should be an additionnal record category for "declared 3TP" now that every other type of task ( straight distance, out&return, triangles) have both declared and free records ! But is IGC any logical ? :-((( -- Denis R. Parce que ça rompt le cours normal de la conversation !!! Q. Pourquoi ne faut-il pas répondre au-dessus de la question ? |
Denis wrote: Mark James Boyd wrote: I have to point out a confusion that I had as well about definitions. A "free 3TP" task means the 3 turnpoints are declared before the flight, but the order of the turnpoints, and whether 1,2,or all 3 turnpoints are claimed is declared after the flight. I haven't seen this clearly explained anywhere but on some of the declaration forms themselves. You're right twice. It is correct (for badges), and not clear at all :-((( This is different from what I would conceptually consider "free," which is when three turnpoins would be chosen after the flight from the three points on the gps trace which are furthest apart. That's the "free distance with up to 3 turn points for records" Anyone with more comment on this please correct me if this is mistaken...I've only flown one free 3TP record, and the "free 3TP" task and form were what I used. In short, the "free 3TP" is free for records, and declared (except the finish point and the sequence) for badges. This may be explained by historical reasons, but nowadays it is a full nonsense : the logic would implie that there be "free 3TP" -- like actual 3 TP for records -- and (declared) 3 TP -- like actual 3 TP for badges, but with declared finish point and TP sequence. Furthermore, there should be an additionnal record category for "declared 3TP" now that every other type of task ( straight distance, out&return, triangles) have both declared and free records ! Well, you've done a much better job clarifying that. I didn't know the record "free 3TP" could be points declared after the flight. Interesting... -- ------------+ Mark Boyd Avenal, California, USA |
Don Johnstone wrote:
I stand corrected. My original query still stands. Where cameras and smoky barographs were used I can see the sense of a 'declaration'. With GPS do we really need it, surely the criteria should be the distance flown and this can now be positively verified with a data logger. Why complicate something so simple? A 300k or 500k downwind dash ie free distance is ok so why not a triangle It's not a matter of technology, but philosophy. Cameras or GPS recorder, you can still make a witnessed takeoff and fly an undeclared flight. The declared flight definitely predates cameras! I don't know the history well, but certainly it is a more difficult task to achieve, and this gives it more value to many of us. Lately, undeclared tasks have been added, at least for records, so perhaps the philosophy is changing. -- ----- change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Don Johnstone wrote: I stand corrected. My original query still stands. Where cameras and smoky barographs were used I can see the sense of a 'declaration'. With GPS do we really need it, surely the criteria should be the distance flown and this can now be positively verified with a data logger. Why complicate something so simple? A 300k or 500k downwind dash ie free distance is ok so why not a triangle A couple of points, and if anyone thinks any of these are wrong, please correct me: 1. If a qualifying task is completed which is a subset of the declared task, this is fine: EXAMPLE: A B D C E If A-B-E-C-D-A is declared, A-B-C-D-A is flown, and A-B-C-A qualifies as a 300km triangle, then (assuming the OZ and altitude rules are met), this is considered a "declared and completed 300km triangle." Congratulations! 2. There is no limit on the number of turnpoints one may declare for a flight. 3. Turnpoints may be repeated in a delaration. So, for example, A-B-C-D-E-A-B-C-E-D-A-B-D-C-E-A-B-D-E-C-A-B-E-C-D-A-B-E-D-C- A-C-B-D-E-A-C-B-E-D-A-C-D-B-E-A-C-D-E-B-A-C-E-B-D-A-C-E-D-B- A-D-B-C-E-A-D-B-E-C-A-D-C-B-E-A-D-C-E-B-A-D-E-B-C-A-D-E-C-B- A-E-B-C-D-A-E-B-D-C-A-E-C-B-D-A-E-C-D-B-A-E-D-C-B-A-E-D-B-C is a perfectly valid task declaration. It's also quite useful, because if one declares this before the flight, one can fly the turnpoints in any order and after the flight, that subset achieved is considered a completed, declared task. And any subset of those points which qualifies for a badge is also completed and qualifying. So if one has a clever computer program to print out all the turnpoint permutations, and enough printer paper, and a friendly OO, one can simply fly any turnpoints in whatever order and come back and land and then figure out what the flight qualifies for. All quite proper. Reducio ad absurdum... The IGC should have approved the idea of post-flight declared turnpoints for badge tasks. It saves paper... -- ------------+ Mark Boyd Avenal, California, USA |
X-no-archive: yes
In article 404cf98a$1@darkstar, Mark James Boyd writes A couple of points, and if anyone thinks any of these are wrong, please correct me: 1. If a qualifying task is completed which is a subset of the declared task, this is fine: EXAMPLE: A B D C E If A-B-E-C-D-A is declared, A-B-C-D-A is flown, and A-B-C-A qualifies as a 300km triangle, then (assuming the OZ and altitude rules are met), this is considered a "declared and completed 300km triangle." Congratulations! 2. There is no limit on the number of turnpoints one may declare for a flight. 3. Turnpoints may be repeated in a delaration. For badges a maximum of 3 waypoints may be claimed and each Waypoint may only be claimed once. (SC3, 1.4.5(b). The sequence must be on the declaration. Tim Newport-Peace "Indecision is the Key to Flexibility." |
For badges a maximum of 3 waypoints may be claimed and each Waypoint may only be claimed once. (SC3, 1.4.5(b). Yes The sequence must be on the declaration. No ! The course must be declared, but "The TURN POINTS( ...) may be claimed once, *in any sequence* " (SC3, 1.4.5(b) also) -- Denis R. Parce que ça rompt le cours normal de la conversation !!! Q. Pourquoi ne faut-il pas répondre au-dessus de la question ? |
16 Aug 2004 - Today’s Military, Veteran, War and National Security News | Otis Willie | Military Aviation | 0 | August 17th 04 12:37 AM |
AVSIM News Update | Eric Lunston | Simulators | 16 | August 15th 04 04:49 AM |
Weak Dollar (Bad News - Good News) | JJ Sinclair | Soaring | 6 | January 27th 04 03:06 AM |
07 Aug 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Military Aviation | 0 | August 8th 03 02:51 AM |
