Tim Newport-Peace wrote:
4.2.1 Declaration content --------snip e. Way points and the sequence to be flown, start, turn(s), finish/goal as applicable to the specific soaring performance * I suppose that "as applicable to the specific soaring performance" means that "sequence" -- as well as goal ! -- are not applicable to the free distance w/3TP, or that you must declare it, but you need not fly it as declared (!) -- Denis R. Parce que ça rompt le cours normal de la conversation !!! Q. Pourquoi ne faut-il pas répondre au-dessus de la question ? |
![]() Running up and down just few kilometers from the airport is not the same performance what requires by the current 3 turnpoints (plus start and finish point) rule. Double out and return still allowed. Theoretically you don't have to go further than 125km from your home on a 500km task. I can imagine a paper declaration with simple GPS log for badges. This would involve more pilots with the same security what photo and barograph provide right now. /Janos Mark James Boyd wrote: In article , Don Johnstone wrote: I stand corrected. My original query still stands. Where cameras and smoky barographs were used I can see the sense of a 'declaration'. With GPS do we really need it, surely the criteria should be the distance flown and this can now be positively verified with a data logger. Why complicate something so simple? A 300k or 500k downwind dash ie free distance is ok so why not a triangle A couple of points, and if anyone thinks any of these are wrong, please correct me: 1. If a qualifying task is completed which is a subset of the declared task, this is fine: EXAMPLE: A B D C E If A-B-E-C-D-A is declared, A-B-C-D-A is flown, and A-B-C-A qualifies as a 300km triangle, then (assuming the OZ and altitude rules are met), this is considered a "declared and completed 300km triangle." Congratulations! 2. There is no limit on the number of turnpoints one may declare for a flight. 3. Turnpoints may be repeated in a delaration. So, for example, A-B-C-D-E-A-B-C-E-D-A-B-D-C-E-A-B-D-E-C-A-B-E-C-D-A-B-E-D-C- A-C-B-D-E-A-C-B-E-D-A-C-D-B-E-A-C-D-E-B-A-C-E-B-D-A-C-E-D-B- A-D-B-C-E-A-D-B-E-C-A-D-C-B-E-A-D-C-E-B-A-D-E-B-C-A-D-E-C-B- A-E-B-C-D-A-E-B-D-C-A-E-C-B-D-A-E-C-D-B-A-E-D-C-B-A-E-D-B-C is a perfectly valid task declaration. It's also quite useful, because if one declares this before the flight, one can fly the turnpoints in any order and after the flight, that subset achieved is considered a completed, declared task. And any subset of those points which qualifies for a badge is also completed and qualifying. So if one has a clever computer program to print out all the turnpoint permutations, and enough printer paper, and a friendly OO, one can simply fly any turnpoints in whatever order and come back and land and then figure out what the flight qualifies for. All quite proper. Reducio ad absurdum... The IGC should have approved the idea of post-flight declared turnpoints for badge tasks. It saves paper... |
Janos Bauer wrote:
Theoretically you don't have to go further than 125km from your home on a 500km task. it's actually 83.333 km only ! -- Denis R. Parce que ça rompt le cours normal de la conversation !!! Q. Pourquoi ne faut-il pas répondre au-dessus de la question ? |
Denis wrote: Janos Bauer wrote: Theoretically you don't have to go further than 125km from your home on a 500km task. it's actually 83.333 km only ! Hmmm...if S is start, F is finish, points are 1, 2, 3, and A is the airport: S 1 2 A 3 F Then S-1 = 1-2 = 2-3 = 3-F = 125km Since half of that is the max distance to the airport, 62.5 km is max distance (about 33NM). For gold distance of 300km, this is 37.5km (20NM). Astonishingly, for silver distance, one can fly a 3TP course without ever going more than 6.25km (3.3 NM) from the airport! Get towed out to near the start, and just fly back and forth over the airport four times! I'm not saying it's easier than just grabbing a thermal to 6000ft and then doing a 50km downwind dash ![]() pretty darned easy...geez, at 3.3 NM from the airport, 1000ft AGL is final glide even for a 2-33 :O Of course assume half glide, and add pattern, blah blah, but even that's just 3000 ft. Not exactly a challenge... -- ------------+ Mark Boyd Avenal, California, USA |
50 km silver - the 50 km has to be one leg in a straight stripe - read
2.1.1.a . You're going to have to get 25 km from the airfield. Ian |
tango4 wrote: 50 km silver - the 50 km has to be one leg in a straight stripe - read 2.1.1.a . You're going to have to get 25 km from the airfield. Ian Darn good thing SOMEBODY is willing to look at the regs. Thanks Ian! I thought that 3.3nm from the airport was a little absurd... -- ------------+ Mark Boyd Avenal, California, USA |
![]() Oh yes, you right! I will try it this summer ![]() Denis wrote: Janos Bauer wrote: Theoretically you don't have to go further than 125km from your home on a 500km task. it's actually 83.333 km only ! |
Kirk Stant wrote:
A couple of points, and if anyone thinks any of these are wrong, please correct me: 1. If a qualifying task is completed which is a subset of the declared task, this is fine: EXAMPLE: A B D C E If A-B-E-C-D-A is declared, A-B-C-D-A is flown, and A-B-C-A qualifies as a 300km triangle, then (assuming the OZ and altitude rules are met), this is considered a "declared and completed 300km triangle." Congratulations! This is wrong, and I goofed. 4.2.2 "No turn points after a missed turn point can be claimed." Interestingly, though, the start and finish as far as I know are NOT turnpoints. So A-B-A can still be claimed as an out and return, but since E was missed, no turnpoints after E can be claimed. Again, comments are welcome. This is complex and comments are helping me work through it. Huh? Last time I checked, a triangle had three points. So a DECLARED triangle has three DECLARED points, not as many as you want. You declare what you are going to fly, then either fly it or don't. Pretty simple, even for a power pilot... Well, in the annex C examples, SC3 does describe declared courses which are not triangles, but which include points which qualify as a triangle, and that this is fine (the lesser included performance can be claimed). The idea here being that if someone declares a 3TP course, and completes it, if there is a lesser included O&R, triangle, or straight distance which qualifies or makes a record, then this is fine. Are more than 3TPs allowed in a declaration? I can't find any restriction on this... 2. There is no limit on the number of turnpoints one may declare for a flight. See above. A declared triangle has a start, two turnpoints, and a finish. You can't just declare your entire turnpoint list. Hmmm...I think you can, but the caveat is that if any turnpoints are missed along the way, the performance stops (4.2.2 above). This is clearly a show-stopper... I honestly don't see anything in the regs which specifically limits one from declaring more than three turnpoints for a task. Again, I welcome comments and corrections... 3. Turnpoints may be repeated in a delaration. A-B-C-D-E-A-B-C-E-D-A-B-D-C-E-A-B-D-E-C-A-B-E-C-D-A-B-E-D-C- A-C-B-D-E-A-C-B-E-D-A-C-D-B-E-A-C-D-E-B-A-C-E-B-D-A-C-E-D-B- A-D-B-C-E-A-D-B-E-C-A-D-C-B-E-A-D-C-E-B-A-D-E-B-C-A-D-E-C-B- A-E-B-C-D-A-E-B-D-C-A-E-C-B-D-A-E-C-D-B-A-E-D-C-B-A-E-D-B-C is a perfectly valid task declaration. It's also quite useful, More like total bull****. Eeeep. Yes I was just plain wrong. Thanks to the posters that helped me find 4.2.2 which makes this clear... Is that how you teach power students to plan their crosscountry flights? "Just fly around and land at any airport you happen to see out the window, that will count for your preflight XC planning..." Of course not G. LOL. I'm just trying to see where the verbiage is for each of these tasks. Keep in mind, the free 3-TP tasks seem to allow just that, and yes, one can plan for those too, so although it doesn't apply to the non-free tasks, such an idea isn't so farfetched when flying for free records. I've planned, gotten briefed, and flown to 20-30 airports in one day before. Duats makes this less complex to plan and brief than one might imagine. If I was flying the quite respectable distances you overachievers do, I'd certainly have a standard duats course which included all the airports that were potential landouts on the way. "Crosswind runway closed for construction" is nice to know beforehand! Why? THE WHOLE POINT IS TO DECLARE THE FLIGHT BEFORE YOU FLY IT, THEN FLY IT! Otherwise, you are just wandering around. Nothing wrong with that, but it isn't a declared badge flight. True. Again 4.2.2 makes that clear. Mark, read more Pez, wax up the PW-5, declare a task, then go fly it - you'll feel a lot better afterwards. Rereading Pez is funny too...and had some fun in house thermals Saturday. Spring is a comin' Oh, and when you land out, get a ground retrieve, not an aerotow - your friends will appreciate the steak dinner. Believe it or not, I got the wife and baby at the gliderport! And they had a blast. I dunno about this ground retrieve idea tho, sounds sketchy to me... ;( Kirk 66 Mark 35 (but I tell everyone I'm 21) -- ------------+ Mark Boyd Avenal, California, USA |
16 Aug 2004 - Today’s Military, Veteran, War and National Security News | Otis Willie | Military Aviation | 0 | August 17th 04 12:37 AM |
AVSIM News Update | Eric Lunston | Simulators | 16 | August 15th 04 04:49 AM |
Weak Dollar (Bad News - Good News) | JJ Sinclair | Soaring | 6 | January 27th 04 03:06 AM |
07 Aug 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Military Aviation | 0 | August 8th 03 02:51 AM |
