Any news from IGC?
Old March 8th 04, 11:25 PM
Tim Newport-Peace
X-no-archive: yes
In article 404cf98a$1@darkstar, Mark James Boyd
writes
A couple of points, and if anyone thinks any
of these are wrong, please correct me:
1. If a qualifying task is completed which is a subset
of the declared task, this is fine:
EXAMPLE:
A B
D C E
If A-B-E-C-D-A is declared, A-B-C-D-A is flown, and
A-B-C-A qualifies as a 300km triangle, then (assuming the
OZ and altitude rules are met), this is considered a
"declared and completed 300km triangle." Congratulations!
2. There is no limit on the number of turnpoints one
may declare for a flight.
3. Turnpoints may be repeated in a delaration.
For badges a maximum of 3 waypoints may be claimed and each Waypoint may
only be claimed once. (SC3, 1.4.5(b). The sequence must be on the
declaration.
Tim Newport-Peace
"Indecision is the Key to Flexibility."
Old March 11th 04, 07:06 PM
Denis
Yes
The sequence must be on the declaration.
No ! The course must be declared, but
"The TURN POINTS( ...) may be claimed once, *in any sequence* "
(SC3, 1.4.5(b) also)
Denis
R. Parce que ça rompt le cours normal de la conversation !!!
Q. Pourquoi ne faut-il pas répondre au-dessus de la question ?
Old March 13th 04, 06:20 PM
Denis
4.2.1 Declaration content
--------snip
e. Way points and the sequence to be flown, start, turn(s), finish/goal
as applicable to the specific soaring performance *
I suppose that "as applicable to the specific soaring performance" means
that "sequence" -- as well as goal ! -- are not applicable to the free
distance w/3TP, or that you must declare it, but you need not fly it as
declared (!)
Denis
16 Aug 2004 - Today’s Military, Veteran, War and National Security News Otis Willie Military Aviation 0 August 17th 04 12:37 AM
AVSIM News Update Eric Lunston Simulators 16 August 15th 04 04:49 AM
Weak Dollar (Bad News - Good News) JJ Sinclair Soaring 6 January 27th 04 03:06 AM
07 Aug 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Military Aviation 0 August 8th 03 02:51 AM
