This past year, I have stuck to a policy of making all thermal turns
to the right only. The airport I fly out of has left turns in the pattern. My idea is I am developing the habit of turning slow to the right only. All left turns are made at higher pattern speeds. With the condition I am just recreationally flying locally (don't have to be that efficient and can burn a turn to center each thermal by going the "wrong way"), I found that thermaling for a while to the left, then landing made the high speed left turns in the pattern feel a bit "different". This was especially noticiable after not flying for awhile. The result was babying the plane thru the turns instead of "bank and yank". Does this make sense for low-time pilots, or pilots who take time off from flying occasionally? Seems like if you have not flown for awhile, then thermal a few dozen slow left turns, you would naturally tend to prefer slow left turns in the pattern. That is what you were just praticing to do, after all. Is there safety benefits to thermaling only to the right, and landing only with left turns? Will a pilot develop habits or preference for slow speed right turns and high speed left turns? John |
As far as I am concerned, landing and thermaling are two different things.
Keep them separate. At altitude, thermal any which way you want, as long as you do it safely. Practice landings over and over again if you feel something is "different." Each time you enter the pattern, you should set yourself in "Landing Mode" and everything should feel the same every time except for minor adjustments for wind or other aircraft. If you're going to have an accident, statistics say it will happen in the landing pattern: So keep your landings the same every time. "John" wrote in message om... This past year, I have stuck to a policy of making all thermal turns to the right only. The airport I fly out of has left turns in the pattern. My idea is I am developing the habit of turning slow to the right only. All left turns are made at higher pattern speeds. With the condition I am just recreationally flying locally (don't have to be that efficient and can burn a turn to center each thermal by going the "wrong way"), I found that thermaling for a while to the left, then landing made the high speed left turns in the pattern feel a bit "different". This was especially noticiable after not flying for awhile. The result was babying the plane thru the turns instead of "bank and yank". Does this make sense for low-time pilots, or pilots who take time off from flying occasionally? Seems like if you have not flown for awhile, then thermal a few dozen slow left turns, you would naturally tend to prefer slow left turns in the pattern. That is what you were just praticing to do, after all. Is there safety benefits to thermaling only to the right, and landing only with left turns? Will a pilot develop habits or preference for slow speed right turns and high speed left turns? John -----= Posted via Newsfeeds.Com, Uncensored Usenet News =----- http://www.newsfeeds.com - The #1 Newsgroup Service in the World! -----== Over 100,000 Newsgroups - 19 Different Servers! =----- |
John writes
Is there safety benefits to thermaling only to the right, and landing only with left turns? Will a pilot develop habits or preference for slow speed right turns and high speed left turns? What if there were already another glider in the thermal but running anti-clockwise? Would you forgo the obvious thermal so kindly marked out by the other aircraft rather than take it to the left, or take it to the right regardless of the precedent set by the glider there first? Is the pattern where you fly always on a left hand circuit? Even if it is, approaching it in such a formulaic fashion can't be conducive to safety. Keeping a flexible and open mind to the variation of circumstance and being confident and competent to adapt and cope accordingly is a much safer approach, IMHO. And the best place to practice co-ordinated turns of any attitude is at altitude. And in any case, from the little I've seen myself, some thermals require as aggressive a turn as any final turn into approach might justify in order to work them properly. And not every turn, or at least not every adjustment in the pattern absolutely demands an aggressive a turn as the final turn should be. -- Bill Gribble /-----------------------------------\ | http://www.cotswoldgliding.co.uk | | http://scapegoatsanon.demon.co.uk | \-----------------------------------/ |
John: the issue of joining a gaggle of other gliders which are thermalling to
the left has already been addressed by another pilot. I would like to add this: the airport out of which you fly has a left turn pattern. Will you *always* fly out of that airport, and *never* out of another where the pattern may be different? It is best to practice both right and left turns at altitude in order to feel comfortable in either. Cheers, Charles |
![]() "John" wrote in message om... This past year, I have stuck to a policy of making all thermal turns to the right only. The airport I fly out of has left turns in the pattern. My idea is I am developing the habit of turning slow to the right only. All left turns are made at higher pattern speeds. With the condition I am just recreationally flying locally (don't have to be that efficient and can burn a turn to center each thermal by going the "wrong way"), I found that thermaling for a while to the left, then landing made the high speed left turns in the pattern feel a bit "different". This was especially noticiable after not flying for awhile. The result was babying the plane thru the turns instead of "bank and yank". Does this make sense for low-time pilots, or pilots who take time off from flying occasionally? Seems like if you have not flown for awhile, then thermal a few dozen slow left turns, you would naturally tend to prefer slow left turns in the pattern. That is what you were just praticing to do, after all. Is there safety benefits to thermaling only to the right, and landing only with left turns? Will a pilot develop habits or preference for slow speed right turns and high speed left turns? John The subject of preferred turn direction has come up all too frequently on this news group. If you can't thermal equally well to the right and left, or fly patterns equally well to the right and left, please get more training! Don't be surprised if other pilots avoid you in the air until you can do both well. I believe that the inability to turn well in both directions is a strong indicator of diminished flying abilities. As such, it is a reliable precursor to an accident. On a BFR, it's a showstopper. Bill Daniels |
On Tue, 9 Mar 2004 17:28:15 +0000, Bill Gribble
wrote: And in any case, from the little I've seen myself, some thermals require as aggressive a turn as any final turn into approach might justify in order to work them properly. And not every turn, or at least not every adjustment in the pattern absolutely demands an aggressive a turn as the final turn should be. Right on. The strongest thermal I found last season was also very narrow - it only worked well with a 60 degree bank and very careful flying (a Pegase gets twitchy when asked to turn that tight). It would not have been usable with another glider sharing it at a similar height. -- martin@ : Martin Gregorie gregorie : Harlow, UK demon : co : Zappa fan & glider pilot uk : |
John,
For what it's worth, I don't think this is a good idea. You may not have a choice which way you thermal, especially if you join others. If you have concerns about maintaining proper airspeed in the pattern, I suggest the following: at some fixed altitude well above the IP, increase your airspeed to pattern speed and maintain it while you make your way to the IP. Even if you decide to stop and test a potential thermal, keep flying at your chosen pattern speed. If you decide to stay with the thermal to extend your flight, then slow down. If not, keep up your speed. This will attune you to the sound, feel, and pitch attitude of the glider for several minutes prior to enterning the pattern. If your IP altitude is 700 msl, you could increase your speed as soon as you descend below 1500 msl. And remember, in the pattern, you should be checking your ASI often, at least once every 7 seconds. Any variation in speed should be addressed immediately. If your speed varies more than + or - 5 knots, you should take a refresher flight with an instructor. There's no shame in sharing a flight with someone who can help get you back in the groove more quickly. OC |
Bill Daniels wrote:
The subject of preferred turn direction has come up all too frequently on this news group. If you can't thermal equally well to the right and left, or fly patterns equally well to the right and left, please get more training! Don't be surprised if other pilots avoid you in the air until you can do both well. I believe that the inability to turn well in both directions is a strong indicator of diminished flying abilities. As such, it is a reliable precursor to an accident. On a BFR, it's a showstopper. Bill Daniels Equally well? So, when I do my BFR I should make my left turns slightly less precise, so they match my perfectly adequate right turns. Seems a bit harsh. :-) Shawn P.S. I try to thermal to the right more than left, so I won't have to fudge as much on my next BFR. |
I've always just flown the direction of the lifted wing for
the thermal. Sure, you could probably just do them all to the right, and it wouldn't make much difference, but if you ever competed, the extra falling out of the thermal and the confusion when joining others would be new. I personally don't like thermalling right turns, because of my power experience (left is best!), but when I look at my traces, I'm about 50/50. The reason many patterns are left, and right for helicopters, is because this is where the pilot has the seat and the best vis in side-by-side seating. In low vis circle-to-lands, it's nice to be on the correct side of the cockpit... In article , John wrote: This past year, I have stuck to a policy of making all thermal turns to the right only. The airport I fly out of has left turns in the pattern. My idea is I am developing the habit of turning slow to the right only. All left turns are made at higher pattern speeds. With the condition I am just recreationally flying locally (don't have to be that efficient and can burn a turn to center each thermal by going the "wrong way"), I found that thermaling for a while to the left, then landing made the high speed left turns in the pattern feel a bit "different". This was especially noticiable after not flying for awhile. The result was babying the plane thru the turns instead of "bank and yank". Does this make sense for low-time pilots, or pilots who take time off from flying occasionally? Seems like if you have not flown for awhile, then thermal a few dozen slow left turns, you would naturally tend to prefer slow left turns in the pattern. That is what you were just praticing to do, after all. Is there safety benefits to thermaling only to the right, and landing only with left turns? Will a pilot develop habits or preference for slow speed right turns and high speed left turns? John -- ------------+ Mark Boyd Avenal, California, USA |
LOL Shawn... if the turns are "adequate".. the BFR should not be an issue...
don't have to be perfect.. just safe... but I do remember something about the BFR standards being to the level of the rating.. so if you hold a Commercial rating, the BFR standard is higher than a Pvt pilot. BT "Shawn Curry" wrote in message news:16s3c.529913$na.1269374@attbi_s04... Bill Daniels wrote: The subject of preferred turn direction has come up all too frequently on this news group. If you can't thermal equally well to the right and left, or fly patterns equally well to the right and left, please get more training! Don't be surprised if other pilots avoid you in the air until you can do both well. I believe that the inability to turn well in both directions is a strong indicator of diminished flying abilities. As such, it is a reliable precursor to an accident. On a BFR, it's a showstopper. Bill Daniels Equally well? So, when I do my BFR I should make my left turns slightly less precise, so they match my perfectly adequate right turns. Seems a bit harsh. :-) Shawn P.S. I try to thermal to the right more than left, so I won't have to fudge as much on my next BFR. |
For Auction: Thermal Imaging Camera - One Day Left | sell2all | Rotorcraft | 0 | April 29th 04 08:29 PM |
For Auction: Thermal Imaging Camera - One Day Left | sell2all | Naval Aviation | 0 | April 29th 04 08:09 PM |
For Auction: Thermal Imaging Camera - One Day Left | sell2all | General Aviation | 0 | April 29th 04 08:09 PM |
Spin on thermal entry - how-to | Bill Daniels | Soaring | 0 | January 29th 04 05:43 PM |
Thermal to Wave contact! | C.Fleming | Soaring | 1 | January 21st 04 01:54 PM |
