Thermal right, land left
Old March 13th 04, 09:17 AM
Mark James Boyd
Jack wrote:
On 3/12/04 2:05 PM, in article 40521816$1@darkstar, "Mark James Boyd"
Where's the stall warning horn?
On the Cessna, where it belongs. Don't even think about putting one in a
sailplane.
Soaring ought to be about flying the aircraft, not just monitoring the
government-mandated distractions. The thing would either be activated during
most thermaling, or have such a close tolerance as to give no useful warning
to those who would most need it -- and they are expensive. Would you
recommend flashing lights on the panel, a speaker tone to compete with the
vario, or both? Perhaps you would also like to incorporate a stick-shaker?
Who said anything about the gubmint? And what would I want
with a vario during the landing phase, off-field or not?
If I've got the gear down and the spoilers out, I'd be
playing the fool to try using the vario for anything...
Have the vario shut itself off and let the stall warning
buzzer on...
Expensive? I couldn't comment on that...And are the fatal accidents
so rare as to make this idea pointless? Perhaps...
As far as spoilers and flaps changing the stall speed, I suppose that's
glider dependent on how much. And as far as bugs, again I
don't know how far off the normal stall speed you'd see...
Maybe it's negligible, maybe not. Dunno...
Mark Boyd
Avenal, California, USA
Old March 13th 04, 04:31 PM
Eric Greenwell
buzzer on...
Some varios, like the Cambridge 302, already have gear warning, spoiler
unlocked on takeoff warning, and airspeed alert built into them. It even
adjusts for G loading. I suspect it would be a simple change to it's
software to have two airspeed alerts, based on gear position:
Gear up (soaring): set it a little below normal thermalling speed (about
46 knot setting works on my glider with my 302).
Gear down (landing): set it a little below the typical pattern speed
(about 50 knots would work on my glider).
change "netto" to "net" to email me directly
Eric Greenwell
Washington State
USA
Old March 14th 04, 12:54 PM
Robertmudd1u
Some may think this a cheap shot, but what the heck.
Believe it or not some pilots fly gliders with fixed gear. They even fly them
X-C and make land outs. They even stall/spin them.
Too many people in this sport think you need ALL the bells and whistles and a
$100,000+ glider to be a "real" glider pilot. That attitude is hurting us.
Robert Mudd
Old March 14th 04, 03:46 PM
Eric Greenwell
I was trying to keep the discussion simple and focused on the air speed
alert idea. It'd also failin a retractable gear glider if the pilot
forgot to put the gear down.
Fixed gear gliders could use a switch for "landing mode". Perhaps one
switched on by opening the spoilers during the pattern checks that stays
switched on even when the spoilers are closed after the checks would be
better. The pilot would manually reset it after landing, or after using
the spoilers while soaring.
Agreed, but the discussion isn't about being a "real" glider pilot, but
how to help the pilot when his piloting fails. People spinning in are
definitely hurting us. If the airspeed alert idea is useful, it can be
cheaply implemented by pilots using the Cambridge 302 and similar high
end varios. That's got to be good.
Extending the protection (if it is protection) to pilots that won't buy
an expensive vario, or the $1100 DSI from DG, would be the next
challenge. If proven to be of value (and having people using the idea
via 302/DSI route would be one way), I think you'd see it popping up in
cheaper systems. A special unit that did only the airspeed alert for
landing would be a lot cheaper than the DSI. The DSI itself might get a
lot cheaper if these kinds of things began selling, and competitors
appeared.
Eric Greenwell
Washington State
USA
Old March 14th 04, 07:36 PM
Mark James Boyd
Robert Mudd
I certainly would not use the word "need" with respect to a
glider AOA indicator.
And yes, cheap and simple is important. Perhaps the cheapest idea
is simply the ol' harmonica style Cezzna AOA indicators, one
mounted on each wingtip of a 1-26 (easier to install on a metal wing,
and the 1-26 is a glider with more than it's share of stalls
leading to fatalities).
Then, if added complexity is warranted, a small switch on the
spoilers which deactivates the audio vario when the spoilers are out,
so one can now just barely hear the stall horns.
Ideally, it would be nice to have removable wingtips, so
one could experiment without modifying a whole wing...
Perhaps there are other types that would have this feature
to allow inexpensive experimentation. Then maybe try the electric
AOA tabs too...
Mark Boyd
Old March 14th 04, 08:48 PM
Bill Daniels
"Mark James Boyd" wrote in message
news:4054b43e$1@darkstar...
them
and a
us.
Robert Mudd
AOA tabs too...
Mark Boyd
Tape two yaw strings (which then become pitch strings) on each side of the
canopy at the lowest and most forward part you can still see. Fly once with
a grease pencil to mark the inside of the canopy at the string positions for
best L/D, minimum sink, and stall. By using a string on each side of the
canopy, the error introduced by inadvertent yaw is obvious and can be
eliminated with rudder.
The string position for best L/D, min sink, and stall will always be the
same whether the glider is ballasted, empty or in a steep turn - although
the airspeeds will be very different.
The string angle difference between minimum sink and stall is large so the
bright red, wiggling strings angled up steeply are a good visual stall
warning.
Bill Daniels
Old March 15th 04, 12:15 AM
cernauta
warning.
That must be true only for unflapped gliders, or it's valid only for
one specific flap setting in a flapped glider. Or you have to make
different coloured markings for each and every flap setting.
Aldo Cernezzi
Old March 15th 04, 12:59 AM
Bill Daniels
"cernauta" wrote in message
warning.
Aldo Cernezzi
You're right about flaps making a difference in the calibration. I've only
tried this on two flapped gliders and one without flaps. However, It seemed
to work pretty well in all cases. I actually didn't see too much difference
in the string indications at different flap settings.
The flap issue is partly moot since the flap settings are related to
airspeed bands. Stall concerns would likely arise only with the flaps in
their most positive two settings, landing or slow thermalling. The
near-stall indication is very obvious.
Bill Daniels
Old March 14th 04, 10:11 PM
Uri Saovray
Speaking of simple warning devices:
How about a simple hookup to a horn which is activated when the
airbrakes are opened while the towhook is engaged (i.e. open spoilers
during tow)?
A microswitch on the airbrake levers would be the no-brainer part.
What about the towhook? Magnetic sensor? where? How? Other ideas?
Uri
(Mark James Boyd) wrote in message news:4054b43e$1@darkstar...
Robert Mudd
AOA tabs too...
Old March 14th 04, 10:39 PM
Robertmudd1u
David Noyes had such a system on his Ventus CM. There was a micro switch
mounted so that the trigger blade was moved by the oval Tost ring as it was
inserted into the tow hook.
Robert Mudd
For Auction: Thermal Imaging Camera - One Day Left sell2all Rotorcraft 0 April 29th 04 08:29 PM
For Auction: Thermal Imaging Camera - One Day Left sell2all Naval Aviation 0 April 29th 04 08:09 PM
For Auction: Thermal Imaging Camera - One Day Left sell2all General Aviation 0 April 29th 04 08:09 PM
Spin on thermal entry - how-to Bill Daniels Soaring 0 January 29th 04 05:43 PM
Thermal to Wave contact! C.Fleming Soaring 1 January 21st 04 01:54 PM
