Speaking of simple warning devices:
How about a simple hookup to a horn which is activated when the airbrakes are opened while the towhook is engaged David Noyes had such a system on his Ventus CM. There was a micro switch mounted so that the trigger blade was moved by the oval Tost ring as it was inserted into the tow hook. Robert Mudd |
Uri Saovray wrote:
Speaking of simple warning devices: How about a simple hookup to a horn which is activated when the airbrakes are opened while the towhook is engaged (i.e. open spoilers during tow)? A microswitch on the airbrake levers would be the no-brainer part. What about the towhook? Magnetic sensor? where? How? Other ideas? Uri This would be an easy addition to the typical gear warning system, with the new switch simply over-riding the gear switch. Fixed gear gliders would need to add a spoiler switch and warning buzzer. Pilots concerned about warning proliferation could consider using a voice chip to speak "Spoilers" and "Gear" for the two alerts, instead of a buzzer. Voice chips are cheap and simple to use these days. -- ----- change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
So if we agree this is a good idea, my main question is the design of
the tow sensor: 1) It must be robust 2) It must not interfere with the hook mechanism (open spoilers AND can't release???) 3) If it is magnetic - will it interfere with the compass? Does anybody care? 4) A Large magnet at the end of the tow rope - will it survive the fall to the ground (either on winch or from the tug Ideas? Uri Eric Greenwell wrote in message ... Uri Saovray wrote: Speaking of simple warning devices: How about a simple hookup to a horn which is activated when the airbrakes are opened while the towhook is engaged (i.e. open spoilers during tow)? A microswitch on the airbrake levers would be the no-brainer part. What about the towhook? Magnetic sensor? where? How? Other ideas? Uri This would be an easy addition to the typical gear warning system, with the new switch simply over-riding the gear switch. Fixed gear gliders would need to add a spoiler switch and warning buzzer. Pilots concerned about warning proliferation could consider using a voice chip to speak "Spoilers" and "Gear" for the two alerts, instead of a buzzer. Voice chips are cheap and simple to use these days. |
Install a strain gauge internal to the fuselage right up against the hook mount. Get Peter Masak to design a simple circuit that trips an electronic relay when the strain exceeds a certain amount. Knowing Peter, it should take him less than an hour. Jim Vincent CFIG N483SZ illspam |
Hi Robert,
Read the story at http://home.wxs.nl/~kpt9/gear.htm and you may have second thoughts. Karel, NL "Robertmudd1u" schreef in bericht ... Gear up (soaring): set it a little below normal thermalling speed (about 46 knot setting works on my glider with my 302). Gear down (landing): set it a little below the typical pattern speed (about 50 knots would work on my glider). Some may think this a cheap shot, but what the heck. Believe it or not some pilots fly gliders with fixed gear. They even fly them X-C and make land outs. They even stall/spin them. Too many people in this sport think you need ALL the bells and whistles and a $100,000+ glider to be a "real" glider pilot. That attitude is hurting us. Robert Mudd |
Hi Robert,
Read the story at http://home.wxs.nl/~kpt9/gear.htm and you may have second thoughts. Karel, NL Sorry Karel, I am missing your point. I did not say such systems were not a good idea just that they need to be designed for fixed gear glider too, and not be expensive. On my retractable gear glider I do have a warning horn for airbrake and landing gear. The information in your link is interesting, Ia m sure some will find the schematic valuable. I sure saved it. Robert Mudd |
Hi again Robert.
Read your thread not good enough I guess. Sorry for that. Nice to understand that you are using yourself an airbrake/gear warning system. Indeed a warning system for unlocked or extended airbrakes on fixed gear gliders would do a good job too. Karel, NL "Robertmudd1u" schreef in bericht ... Hi Robert, Read the story at http://home.wxs.nl/~kpt9/gear.htm and you may have second thoughts. Karel, NL Sorry Karel, I am missing your point. I did not say such systems were not a good idea just that they need to be designed for fixed gear glider too, and not be expensive. On my retractable gear glider I do have a warning horn for airbrake and landing gear. The information in your link is interesting, Ia m sure some will find the schematic valuable. I sure saved it. Robert Mudd |
On Mon, 15 Mar 2004 07:12:18 GMT, Jack wrote:
Right on! And exactly why we get so many arrogant and ultimately ignorant remarks concerning the so-called inadequacies of the PW-5. Clearly, too many people don't understand the concept of competition. Gliding is not about competition. Gliding is about having fun. As others have pointed out before, I don't have fun to spent my hard-earned money on a Ka-6 performing glider instead of a beautiful ASW-20. Not to mention that I don't have fun to fly such a thing after I'm used to the performance of a 40+ L/D. Bye Andreas |
For Auction: Thermal Imaging Camera - One Day Left | sell2all | Rotorcraft | 0 | April 29th 04 08:29 PM |
For Auction: Thermal Imaging Camera - One Day Left | sell2all | Naval Aviation | 0 | April 29th 04 08:09 PM |
For Auction: Thermal Imaging Camera - One Day Left | sell2all | General Aviation | 0 | April 29th 04 08:09 PM |
Spin on thermal entry - how-to | Bill Daniels | Soaring | 0 | January 29th 04 05:43 PM |
Thermal to Wave contact! | C.Fleming | Soaring | 1 | January 21st 04 01:54 PM |
