Thermal right, land left
Old March 14th 04, 12:54 PM
Robertmudd1u
Gear up (soaring): set it a little below normal thermalling speed (about
46 knot setting works on my glider with my 302).
Gear down (landing): set it a little below the typical pattern speed
(about 50 knots would work on my glider).
Some may think this a cheap shot, but what the heck.
Believe it or not some pilots fly gliders with fixed gear. They even fly them
X-C and make land outs. They even stall/spin them.
Too many people in this sport think you need ALL the bells and whistles and a
$100,000+ glider to be a "real" glider pilot. That attitude is hurting us.
Robert Mudd
Old March 14th 04, 03:46 PM
Eric Greenwell
I was trying to keep the discussion simple and focused on the air speed
alert idea. It'd also failin a retractable gear glider if the pilot
forgot to put the gear down.
Fixed gear gliders could use a switch for "landing mode". Perhaps one
switched on by opening the spoilers during the pattern checks that stays
switched on even when the spoilers are closed after the checks would be
better. The pilot would manually reset it after landing, or after using
the spoilers while soaring.
Agreed, but the discussion isn't about being a "real" glider pilot, but
how to help the pilot when his piloting fails. People spinning in are
definitely hurting us. If the airspeed alert idea is useful, it can be
cheaply implemented by pilots using the Cambridge 302 and similar high
end varios. That's got to be good.
Extending the protection (if it is protection) to pilots that won't buy
an expensive vario, or the $1100 DSI from DG, would be the next
challenge. If proven to be of value (and having people using the idea
via 302/DSI route would be one way), I think you'd see it popping up in
cheaper systems. A special unit that did only the airspeed alert for
landing would be a lot cheaper than the DSI. The DSI itself might get a
lot cheaper if these kinds of things began selling, and competitors
appeared.
change "netto" to "net" to email me directly
Eric Greenwell
Washington State
USA
Old March 14th 04, 07:36 PM
Mark James Boyd
Robert Mudd
I certainly would not use the word "need" with respect to a
glider AOA indicator.
And yes, cheap and simple is important. Perhaps the cheapest idea
is simply the ol' harmonica style Cezzna AOA indicators, one
mounted on each wingtip of a 1-26 (easier to install on a metal wing,
and the 1-26 is a glider with more than it's share of stalls
leading to fatalities).
Then, if added complexity is warranted, a small switch on the
spoilers which deactivates the audio vario when the spoilers are out,
so one can now just barely hear the stall horns.
Ideally, it would be nice to have removable wingtips, so
one could experiment without modifying a whole wing...
Perhaps there are other types that would have this feature
to allow inexpensive experimentation. Then maybe try the electric
AOA tabs too...
Mark Boyd
Avenal, California, USA
Old March 14th 04, 08:48 PM
Bill Daniels
"Mark James Boyd" wrote in message
news:4054b43e$1@darkstar...
them
and a
us.
Robert Mudd
AOA tabs too...
Mark Boyd
Tape two yaw strings (which then become pitch strings) on each side of the
canopy at the lowest and most forward part you can still see. Fly once with
a grease pencil to mark the inside of the canopy at the string positions for
best L/D, minimum sink, and stall. By using a string on each side of the
canopy, the error introduced by inadvertent yaw is obvious and can be
eliminated with rudder.
The string position for best L/D, min sink, and stall will always be the
same whether the glider is ballasted, empty or in a steep turn - although
the airspeeds will be very different.
The string angle difference between minimum sink and stall is large so the
bright red, wiggling strings angled up steeply are a good visual stall
warning.
Bill Daniels
Old March 15th 04, 12:15 AM
cernauta
warning.
That must be true only for unflapped gliders, or it's valid only for
one specific flap setting in a flapped glider. Or you have to make
different coloured markings for each and every flap setting.
Aldo Cernezzi
Old March 15th 04, 12:59 AM
Bill Daniels
"cernauta" wrote in message
warning.
Aldo Cernezzi
You're right about flaps making a difference in the calibration. I've only
tried this on two flapped gliders and one without flaps. However, It seemed
to work pretty well in all cases. I actually didn't see too much difference
in the string indications at different flap settings.
The flap issue is partly moot since the flap settings are related to
airspeed bands. Stall concerns would likely arise only with the flaps in
their most positive two settings, landing or slow thermalling. The
near-stall indication is very obvious.
Bill Daniels
Old March 15th 04, 01:59 PM
John
Bill,
Are you still using the AOA indicators made from yaw strings? Which
glider type is it mounted on?
I assume these strings would be forward, so you visualize them at the
same time you see the normal yaw string. Is that correct?
John
Old March 15th 04, 02:37 PM
Bill Daniels
"John" wrote in message
om...
Bill,
I have tended to use them with new gliders to calibrate my seat of the pants
feel near a stall. Once my senses are atuned to the glider the strings are
no longer neccessary. I have tried them on a Lark IS28, Blanik L-23 and a
Nimbus 2C. The string indications were simular on all.
The strings need to be as far forward as possible to get away from the
near-field flow over the wing. If I recall my Aerodynamics 101, the perfect
place for an AOA sensor would be about 10 wing chord lengths ahead of the LE
on a nose boom. The best practical position is near the forward end of the
canopy side frames. This happens to put them in the pilots field of view.
The 3D flow over the glider's nose seems to amplify the response of the
strings to changes in AOA so don't expect the string angles to represent the
actual AOA. While the absolute accuracy is terrible, the indications are
very repeatable and once calibrated to the three critical AOA's, they do
give useful data.
The biggest problem is that they are highly sensitive to yaw angles but if
both strings are giving the same indication, the yaw error is cancelled out.
Another nuisance issue is that the strings tend to get sucked under the
canopy frame as it is being closed trapping the strings.
Bill Daniels
Old March 15th 04, 07:57 PM
Eric Greenwell
warning.
Aldo Cernezzi
Have you tried these in a shallow turning stall, when it is the wing tip
that stalls, not the root?
Eric Greenwell
Washington State
USA
Old March 15th 04, 08:46 PM
Bill Daniels
Yep, and the indication is still useful. No doubt the AOA measured near the
centerline is lower than the actual AOA of the inside wingtip. (Your point,
Eric.)
But, the AOA indication you do get is significantly greater than minimum
sink so that you would take it as a stall warning, or at least an indication
that lowering the nose would result in better performance.
YMMV, but my experience with them has been that the 10cm long strings are
25mm or so higher at stall than at min sink while the difference between
best L/D and min sink is only 5 - 10mm. The strings angle upward and wiggle
a lot near stall.
All I can say is try it. If it doesn't do anything for you, rip 'em off.
It's a pretty cheap experiment.
Bill Daniels
For Auction: Thermal Imaging Camera - One Day Left sell2all Rotorcraft 0 April 29th 04 08:29 PM
For Auction: Thermal Imaging Camera - One Day Left sell2all Naval Aviation 0 April 29th 04 08:09 PM
For Auction: Thermal Imaging Camera - One Day Left sell2all General Aviation 0 April 29th 04 08:09 PM
Spin on thermal entry - how-to Bill Daniels Soaring 0 January 29th 04 05:43 PM
Thermal to Wave contact! C.Fleming Soaring 1 January 21st 04 01:54 PM
