I think the difference isn't so much height gained, but back calculating
to horsepower based on a 1 "G" acceleration at the start of the launch. I've flown off a Supacat and while it had good acceleration, it sure didn't match up to the whopper of a winch that was built by the permian soaring association. Talk about a zippy launch! http://members.cox.net/tsample10/SpecialProjects.html By the way, I think this "unified winch design" concept is a really great move. If you have a diesel driving through a fluid flywheel you don't need that much power: we have a Supacat with a 245 hp Deutz V8 aircooled industrial diesel and torque converter (no gearbox). This can launch an ASH-25 or just about any Nimbus. With a 15 m glider, K-21 or Grob you'd expect 1200-1400 ft on a 1000m run in calm conditions and over 2000 ft if its blowing a bit. I'd agree with everything you've said about the specialised nature of a glider winch, the heavy duty engineering and the costs. -- martin@ : Martin Gregorie gregorie : Harlow, UK demon : co : Zappa fan & glider pilot uk : |
Bill Daniels wrote:
"Mark James Boyd" wrote in message I'd love to see a winch design that uses a 100hp or less engine, can be easily bolted on the back of an old pickup, and has engine and parts that are low maintenance and (especially engine) easy to acquire (either locally or via shipping). Alternately, how about a "spare tire" that is really a winch drum. a stable sturdy "jack" and some way to route the cable to ensure it winds up nice. Might not work (thoughts of side loads tipping my car over come to mind!), but it sure is fun to play with the thuoght! -- Mark, unfortunately, the physics of a winch launch says that it takes about 1 kWh or 3,600,000 Joules to launch a glider. The peak power demand places Hmmm...so all gliders are alike? A Gapa or Russia REQUIRES the same HP as a ballasted LAK-12 or Nimbus 4? Something 400 pounds vs. 1600 pounds? I know this isn't what you meant... I read the Marske site and saw the (wt lbs) x (wing loading lbs) x .03 = hp and it looked like these mini gliders "needed" about 100 hp. yet another constraint on the minimum HP that must be available. Those numbers point to a 400 to 500 HP engine to be able to provide launch service to any glider in the existing fleet. Although the initial cost of a well engineered winch is high (nearly as much as a tow plane) the long term costs are only a few percent as much a tug. A coupla points: well engineered, is limited in how high you can get, and very hard to move around are winch disadvantages. The height is tough to get with any winch (8000 ft sightseeing sled rides ain't gonna happen). But if we assume we'll only fly 500 gross wt. with 6# wing loading, how does this ease the engineering and building costs, and how mobile is this new mini-winch? If we can build four of these things for the price and energy of a 400hp version, is the launch weight limitation less of a disadvantage? How about if we can build eight of these for the same price? How about if we can build 16? Obviously if you fly 1600 lbs of glider, this does you no good. And sure, there are non-recurring engineering costs to making 2, 4, 8, 16 of these. I guess what I'm saying is I'm not gonna see a big winch that launches 1600 lbs at MY gliderport in the next 5 years, but I'm gonna bet I'll see a small, portable, back of the truck winch at Tehachapi at the Vintage Sailplane Rally in about a month... I've also seen pictures and know there are dozens (maybe hundreds) of hugely capable, overengineered (IMHO) winch designs (they seem to all be custom homebuilts). For novelty, I'd like to see the juxtaposed minimalist approach. I've been very impressed by the lighter, smaller gliders I've seen recently. I'm excited about the idea of towing them with a 75 hp towplane. I'd like to see a 100 hp winch, even if it was underpowered, just to see HOW underpowered... The good news is that the total energy consumed for one launch (About 1 liter of diesel fuel equivalent) is tiny compared to any other launch method except bungee launch. (Excluding, of course, the beer you have to provide the bungee crew.) Auto tow's about the same, but without the construction costs, from what I gather. The huge downside (I'm finding out) is that auto-tow takes a HUGE amount of room/runway... A glider winch is a highly specialized piece of machinery that needs the kind of engineering Ulrich is asking for. Please avoid the temptation to cobble some junk together to make a barely workable winch. That sort of thing has given winch launch a bad name in the USA. There's that word "needs" again. ;P Keep in mind you are sharing this thread with ME, an avid experimenter and no stranger to failure... A well run winch operation is very attractive to newcomers to the sport. It shows a lot of ground activity that is visible to the onlookers and the rides are a real thrill. Lets get winching! The only winch I know of on the west coast USA that one can schedule use of is Northwest Soaring an hour east of Seattle. I called them and it's a May-Oct operation at Cle Elum. Fortunately the flights out of San Fran area are $130 round trip, so it'll be cheap to visit there this summer ![]() -- ------------+ Mark Boyd Avenal, California, USA |
Ulrich Neumann wrote: (Mark James Boyd) wrote in message news:405aa3e8$1@darkstar... mat Redsell wrote: My statement was very confusing... what I really meant was without the winch I think that we will be in troubles down the road for affordable tows.... And in part I do think that we have taken a wrong road with high wing loading. for example with the Monarch we are able to tow it aloft with 160 lbs of tension at a speed of about 15 mph with a wind down the runway of about 10 mph. This requires a very small rope and small horsepower. http://www.continuo.com/marske/ look under articles for : ultralight design parameters design parameters of the ultralight glider I'd love to see a winch design that uses a 100hp or less engine, can be easily bolted on the back of an old pickup, and has engine and parts that are low maintenance and (especially engine) easy to acquire (either locally or via shipping). Alternately, how about a "spare tire" that is really a winch drum. a stable sturdy "jack" and some way to route the cable to ensure it winds up nice. Might not work (thoughts of side loads tipping my car over come to mind!), but it sure is fun to play with the thuoght! Mark, a 100HP or less winch? What are you trying to launch - kites or RC gliders? The Europeans are replacing their winches powered traditionally by Detroit's finest with big rig Diesels, because ...? Lets get real here. As nice as it sounds to have your own personal winch in the trunk, the reality looks more like you could haul your car around with the winch. But keep the ideas coming. Ulrich Neumann The previous post about the Marske stuff was my reference. Keep in mind that yes, I AM talking about very lightweight gliders (either ultralight or close to it). Not necessarily as interesting to the "soaring enthusiasts" found here, but interesting to me as a "soaring consumer." If you wonder where this push comes from, it's from years of having fellow pilots tell everyone how airplanes cost "tens of thousands of dollars" and take $5000 to learn how to fly. I own a $6000 airplane which one could learn to solo in about 20 flights ($2000). http://www.cse.ucsc.edu/~mjboyd/cfi/GHFCcharter A lot of aviation is overkill. Garmin 430, lights, a starter, flaps, oleo struts, a heater, blah blah blah. And who needs a PPL? Solo is solo. There's no doubt who's flying the thing...where did all this complexity come from? Society, certainly not the aircraft itself... Do we NEED a 245 hp winch? Is it POSSIBLE to launch with something smaller and less hassle? Do we NEED two 40# thrust turbines, or just one and a lighter glider? ;P -- ------------+ Mark Boyd Avenal, California, USA |
Experience with a pay-out winch? | Gary Boggs | Soaring | 1 | February 12th 04 08:12 AM |
Winch design | c1rrus | Soaring | 10 | January 19th 04 12:18 PM |
Winch Way Is Up !! | Craig Freeman | Soaring | 45 | November 6th 03 03:08 PM |
using winch instead of aerotow | goneill | Soaring | 5 | August 27th 03 02:46 PM |
Conspiracy Theory’s real Script: Slave CIA, FBI change the story jews wanted to tell the media | Jean-Paul Roy | Restoration | 0 | July 12th 03 12:55 PM |
