Winch Experts wanted
Old March 23rd 04, 11:31 PM
Dave Martin
Some years ago when our Ford V8 and straight Jaguar
engines were falling apart someone suggested we went
on to Chevrolet engines 5.7l.
These were originally sourced from ex US Airforce buses,
like the typical US school bus. We bought the bus
took the engine out then scrapped the remains of the
bus. They were cheap even with a bus attached!
As far as I can recall they engines went straight in
the winch and then as they got tired were given a 'stock
car' tune and with heavy duty pistons etc.
Over about 15 years the engines have given excellent
service.The automatic gear box that came with the engine
is used for the drive and the drive lever fixed so
the winch driver can only engage neutral or drive.
The drive to the prop shaft can be tailored to any
axle with a bit of skilled welding.
Our main winches are a Skylaunch and Tost with the
Chevrolet engine. The engine in the Tost sits on a
sledge with gearbox and radiator attached, so if anything
breaks it can be easily removed and a spare slid in.
The current engine runs on gas and will launch A DG
500 with no problems.
We went for this engine because it is readily available,
either new, from a bus or re conditioned. Spare parts
are also available. It can also be easily tuned and
played with to produce extra power
Not sure what the full description of the engine is
but this US site found by a simple internet search
http://www.automotix.com/engines_by_...-engines_t---C
HV-350RLB-4.html
This looks like the engines we use. The prices also
look very reasonable.
Dave
Old March 24th 04, 06:27 AM
F.L. Whiteley
"Dave Martin" wrote in message
HV-350RLB-4.html
Dave
Great engine, but barely adequate at 5500MSL with normal aspiration.
Frank Whiteley
Experience with a pay-out winch? Gary Boggs Soaring 1 February 12th 04 08:12 AM
Winch design c1rrus Soaring 10 January 19th 04 12:18 PM
Winch Way Is Up !! Craig Freeman Soaring 45 November 6th 03 03:08 PM
using winch instead of aerotow goneill Soaring 5 August 27th 03 02:46 PM
Conspiracy Theory’s real Script: Slave CIA, FBI change the story jews wanted to tell the media Jean-Paul Roy Restoration 0 July 12th 03 12:55 PM
