Filser interfacing woes
Old April 3rd 04, 08:23 AM
tango4
Why not try an up-to-date laptop with bluetooth capability. With a bluetooth
adaptor in the cockpit downloads, uploads and task programming can be
acheived from the laptop in your car or minivan!
Ian
"CV" wrote in message
Eggert Ehmke wrote:
All new notebooks have USB ports, that replace the serial ports. To
connect
an old serial cable, you need an usb-to-serial adapter. These adapters
are
to be found in electronic shops, and on eBay in the 10-20 $ range (at
least
in europe). They work fine.
Eggert
Big thanks to you, and others who replied. The adapter seems to be
the quick and easy way out for the moment. But I'll keep the PDA
in mind too. Must say that fiddling around with the laptop in
the cockpit when you are just about to derig and have a thousand
other things to think about is a bit invonvenient.
Thanks again /CV
Old April 5th 04, 06:09 PM
Denis
interesting, but are there Bluetooth adaptors that fit on a LX 5000
without requiring a PC (I guess it would be a serial to Bluetooth
adaptor) ? Have you tried it ?
Denis
R. Parce que ça rompt le cours normal de la conversation !!!
Q. Pourquoi ne faut-il pas répondre au-dessus de la question ?
Old April 5th 04, 06:55 PM
tango4
I have tried it with variable results. I have some RS232 to bluetooth
adaptorsthat automagically connect to my laptop once it comes within range.
Once I have sorted out how to make a reliable connection I'll post the
results here.
Ian
"Denis" wrote in message
bluetooth
Denis
Old April 5th 04, 08:55 PM
Denis
results here.
Ian
thank you - I will be interested by the reference if it works well ...
Denis
Volkslogger woes Dan Rihn Soaring 10 March 25th 04 03:10 PM
Russian Air Force Woes - Time to start again? Peter Kemp Military Aviation 31 February 21st 04 02:10 AM
V-22 crash woes over, military says, By Tony Cappacio Otis Willie Military Aviation 0 January 23rd 04 02:36 AM
Cambridge 302 DDV woes - Help me PLEASE !!! Mike Borgelt Soaring 7 October 11th 03 10:44 AM
