HI Bob
That is what I was referring to. The deformation limit for carbon designs with thin wings appears to be the point at which it becomes impossible to maintain control movement. As an example, there are various apocryphal tales of uncommanded airbrake openings on open class aircraft with thin flexible wings. The Nimbus 4 appears to be the most common suspect here. So the deflection limit is not a "x degrees from rest", or a plastic deformation (although there is a requirement for this in the regulations) but a deflection beyond which the control actuators do not work correctly or have unacceptably high resistance. My point came from published discussions on the construction of the Eta, and the DG1000 where both constructors commented that the ultimate strength of the structure was well in excess of the limit load, and that the limit load was imposed by the deflection of the wing. There is an interesting test story at: http://www.dg-flugzeugbau.de/bruchversuch-e.html The destructive test requirement is that the wing must withstand 1.725* the limit load for three seconds at a temperature of 54Celsius. The DG1000 wing withstood this - and eventually failed at 1.95 times the design load limit. This is one reason why I believe you would probably be able to get away with a brief overstress load. I am not sure of the limits on older designs, but would expect there to be less margin of strength. As I understand it the modern thin section wings are flexible enough that the load limit is imposed by control freedom limitation, and the wing must withstand 1.725 times this load in test. Flutter is the subject of speed limitation which give speeds and margins that the designer/manufacturer must demonstrate flying to. The regulations imply that the glider must be demonstrated safe at a minimum of 23% margin above the placarded Vne. So your margins for flutter, versus ultimate strength are 1.23 vs 1.725 in JAR22 (unless I got the math wrong) |
Bruce Greeff wrote:
As I understand it the modern thin section wings are flexible enough that the load limit is imposed by control freedom limitation, and the wing must withstand 1.725 times this load in test. Flutter is the subject of speed limitation which give speeds and margins that the designer/manufacturer must demonstrate flying to. The regulations imply that the glider must be demonstrated safe at a minimum of 23% margin above the placarded Vne. So your margins for flutter, versus ultimate strength are 1.23 vs 1.725 in JAR22 (unless I got the math wrong) It's perhaps mathematically true but your argument is wrong (if your conclusion is to say that there is more risk of flutter than overloading). You cannot compare pourcentages of load and speed ! It takes less tenth of second at any moment to take the 2 or 3 g's that will exceed your (supposed) 72.5% load margin, whereas it will take several seconds to take the 60 or 65 km/h of margin in speed (supposing 23% margin), or depending of the dive angle you might never get over the speed margin... And although it may be true that some parts of the wing (e.w. center section) has more stress margin due to deflection limit, it does *not* guarantee you that all the parts of the wing has the same extra margin: in the Nimbus 4 accident the central wing did not break, but the outer wing did, with fatal consequences :-( -- Denis R. Parce que ça rompt le cours normal de la conversation !!! Q. Pourquoi ne faut-il pas répondre au-dessus de la question ? |
Started this thread (Avoiding Vne) some weeks ago with a kind invitation to
respond to the idea of pulling the airbrakes while still in the rotating mode of a spin. The idea behind it is when rotation has been stopped with the glider at a pitch angle of say 60° or more this will be at a lower speed then when the airbrakes stay closed all the time. Possibly a build up of speed to over Vne can then be avoided after that. Of course airbrakes should be closed again in the following pull up manouvre. Any comments? "Denis" schreef in bericht ... Bruce Greeff wrote: As I understand it the modern thin section wings are flexible enough that the load limit is imposed by control freedom limitation, and the wing must withstand 1.725 times this load in test. Flutter is the subject of speed limitation which give speeds and margins that the designer/manufacturer must demonstrate flying to. The regulations imply that the glider must be demonstrated safe at a minimum of 23% margin above the placarded Vne. So your margins for flutter, versus ultimate strength are 1.23 vs 1.725 in JAR22 (unless I got the math wrong) It's perhaps mathematically true but your argument is wrong (if your conclusion is to say that there is more risk of flutter than overloading). You cannot compare pourcentages of load and speed ! It takes less tenth of second at any moment to take the 2 or 3 g's that will exceed your (supposed) 72.5% load margin, whereas it will take several seconds to take the 60 or 65 km/h of margin in speed (supposing 23% margin), or depending of the dive angle you might never get over the speed margin... And although it may be true that some parts of the wing (e.w. center section) has more stress margin due to deflection limit, it does *not* guarantee you that all the parts of the wing has the same extra margin: in the Nimbus 4 accident the central wing did not break, but the outer wing did, with fatal consequences :-( -- Denis R. Parce que ça rompt le cours normal de la conversation !!! Q. Pourquoi ne faut-il pas répondre au-dessus de la question ? |
K.P. Termaat wrote:
Started this thread (Avoiding Vne) some weeks ago with a kind invitation to respond to the idea of pulling the airbrakes while still in the rotating mode of a spin. The idea behind it is when rotation has been stopped with the glider at a pitch angle of say 60° or more this will be at a lower speed then when the airbrakes stay closed all the time. Possibly a build up of speed to over Vne can then be avoided after that. Of course airbrakes should be closed again in the following pull up manouvre. Any comments? well... after 114 answers, I think you have good specimens of the very diverse opinions that have been expressed so far ;-) in short, mine is : apply full airbrakes just after applying the initial spin recovery control inputs, and keep them out during dive (gentle) pull out... -- Denis R. Parce que ça rompt le cours normal de la conversation !!! Q. Pourquoi ne faut-il pas répondre au-dessus de la question ? |
Hi Denis,
If I understand you well you will wait with pulling the airbrakes until the glider has stopped its rotation and then carefully put some back pressure on the stick. I was considering the idea of pulling the brakes with the glider still in its rotation mode in order to keep forward speed as low as possible at any time. However this may frustrate the spin recovery action; I just don't know. What's your idea about this. Of course handbooks do not say anything about this. B.t.w. my provisional handbook for the Ventus-2cxT forbids spin exercises. My idea is to avoid spins with this glider any time anyway; however I will try to get some feeling about the glider's behaviour close to entering this "acrobatic" flying mode. Karel, NL "Denis" schreef in bericht ... K.P. Termaat wrote: Started this thread (Avoiding Vne) some weeks ago with a kind invitation to respond to the idea of pulling the airbrakes while still in the rotating mode of a spin. The idea behind it is when rotation has been stopped with the glider at a pitch angle of say 60° or more this will be at a lower speed then when the airbrakes stay closed all the time. Possibly a build up of speed to over Vne can then be avoided after that. Of course airbrakes should be closed again in the following pull up manouvre. Any comments? well... after 114 answers, I think you have good specimens of the very diverse opinions that have been expressed so far ;-) in short, mine is : apply full airbrakes just after applying the initial spin recovery control inputs, and keep them out during dive (gentle) pull out... -- Denis R. Parce que ça rompt le cours normal de la conversation !!! Q. Pourquoi ne faut-il pas répondre au-dessus de la question ? |
K.P. Termaat wrote:
Hi Denis, If I understand you well you will wait with pulling the airbrakes until the glider has stopped its rotation and then carefully put some back pressure on the stick. I was considering the idea of pulling the brakes with the glider still in its rotation mode in order to keep forward speed as low as possible at any time. However this may frustrate the spin recovery action; I just don't know. What's your idea about this. Of course handbooks do not say anything about this. the ASH 26 handbook does say "spinning is not noticeably affected by extending the airbrakes paddles, but it will increase the height loss when pulling out, and is therefore less advisable" I suppose the last sentence refers to loss of total energy (i.e. after recovery you will re-gain more height if you made it without airbrakes than with). It is not true of height loss down to lowest point (you will loose less height with airbrakes because the diving speed is diminished and the curving radius is reduced by the square of the speed -- even with 3.5 G allowed w/ airbrakes instead of 4 G w/o the height loss should be lesser with airbrakes out -- -- Denis R. Parce que ça rompt le cours normal de la conversation !!! Q. Pourquoi ne faut-il pas répondre au-dessus de la question ? |
| Thread Tools | |
| Display Modes | |
| Avoiding Shock Cooling in Quick Descent | O. Sami Saydjari | Owning | 32 | January 21st 04 05:32 AM |
| Avoiding gliders | Stefan | Piloting | 16 | August 6th 03 06:44 AM |
