Bruce Hoult wrote: In article , Stewart Kissel wrote: http://www.ntsb.gov/NTSB/brief2.asp?...0417&ntsbno=CH I04CA090&akey=1 That looks more like: "if the manufacturer issues an AD [1], you'd probably better do it, whether you legally have to or not". -- Bruce [1] in this case, installing a locking device onto L'Hotellier connectors. I'm really happy the pilot escaped death. This has been fatal in other accidents. 1. So, assuming there was insurance, would this accident be covered? Or would the insurer say: a) you didn't put it together correctly; bad dog, no coverage b) you didn't comply with the AD; bad dog, no coverage c) both 2. Will the pilot then say, hey, what about my annual condition inspection? How come the annual was signed off if the ship didn't comply with an AD? 3. Then what happens when the mechanic says, gosh, the service I contract with for AD updates didn't show this AD, so I didn't know to look for it and would have not signed it off it had I known? Inquiring minds want to know! |
![]() 1. So, assuming there was insurance, would this accident be covered? Or would the insurer say: a) you didn't put it together correctly; bad dog, no coverage b) you didn't comply with the AD; bad dog, no coverage c) both |
In my experience, many people do not cover all the critical elements of doing a
crontrol check. I recently gave a presentation on positive control checks, critical assembly checks, preflight checks and other checks. If you're interested, here it is: http://www.mymedtrans.com/personal.htm You might find elements here that might help you. Jim Vincent CFIG N483SZ illspam |
In article , Jim Vincent
writes In my experience, many people do not cover all the critical elements of doing a crontrol check. Or spelling checks, come to that. ![]() -- Mike Lindsay |
I've gone back and forth on this. I've been a big
proponent of the assembly check, and thought the PCC was redundant. Recently, however, during a PCC a bellcrank broke and this was caused by the pressure exerted by the "helper." Nice to have this happen on the ground, and I can't think of how this could have been detected without a PCC. So now I think a PCC is useful too... Good article Jim...it's great to see your insights... In article , Jim Vincent wrote: In my experience, many people do not cover all the critical elements of doing a crontrol check. I recently gave a presentation on positive control checks, critical assembly checks, preflight checks and other checks. If you're interested, here it is: http://www.mymedtrans.com/personal.htm You might find elements here that might help you. Jim Vincent CFIG N483SZ -- ------------+ Mark Boyd Avenal, California, USA |
Mark James Boyd wrote:
I've gone back and forth on this. I've been a big proponent of the assembly check, and thought the PCC was redundant. Recently, however, during a PCC a bellcrank broke and this was caused by the pressure exerted by the "helper." Nice to have this happen on the ground, and I can't think of how this could have been detected without a PCC. So now I think a PCC is useful too... WHat aircraft was this, which bellcrank, and how was the helper exerting pressure? Or was he simply holding the surface steady while the pilot applied the pressure? What, exactly, broke (bellcrank, mounting of the bellcrank, a bearing), and why did it fail? -- ----- change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Was a 2-33. Heard about it secondhand (or I'd give more
detail). I've seen service difficulty reports in Cezznas, dunno if there are such things for gliders, maybe the mechanic who fixes it will give official details...I'll ask... In article , Eric Greenwell wrote: Mark James Boyd wrote: I've gone back and forth on this. I've been a big proponent of the assembly check, and thought the PCC was redundant. Recently, however, during a PCC a bellcrank broke and this was caused by the pressure exerted by the "helper." Nice to have this happen on the ground, and I can't think of how this could have been detected without a PCC. So now I think a PCC is useful too... WHat aircraft was this, which bellcrank, and how was the helper exerting pressure? Or was he simply holding the surface steady while the pilot applied the pressure? What, exactly, broke (bellcrank, mounting of the bellcrank, a bearing), and why did it fail? -- ----- change "netto" to "net" to email me directly Eric Greenwell Washington State USA -- ------------+ Mark Boyd Avenal, California, USA |
Eric Greenwell wrote in message
WHat aircraft was this, which bellcrank, and how was the helper exerting pressure? Or was he simply holding the surface steady while the pilot applied the pressure? What, exactly, broke (bellcrank, mounting of the bellcrank, a bearing), and why did it fail? I know of one case where an elevator push rod failed during a PCC (Ventus) and another where an aileron circuit bell crank failed in flight at the weld line. (G103Acro). Andy |
Jim,
Very good and complete presentation, I agree with all you are saying. Interesting that you recommend a practice that I rarely see in this country - in fact when rigging at a contest site I feel like my wife and I are the only ones doing it right: Assistant SITS in cockpit, PIC is walking around the plane moving/holding control surfaces giving instructions to the assistant. The normal picture I observe is that the pilot is in the glider, parachute and harness on and ready to go and some bystander is told to hold onto the control surface while the pilot vigorously shakes the stick or whatever. Rudder is never subject to being tested. Even worse is the situation when the pilot stands outside the cockpit rattling the stick while some poor schmock tries to keep the aileron or elevator from banging against the stops. All you instructors out there, this is very bad practice and someone must have been teaching it to the US glider population. Herb, J7 illspam (Jim Vincent) wrote in message ... In my experience, many people do not cover all the critical elements of doing a crontrol check. I recently gave a presentation on positive control checks, critical assembly checks, preflight checks and other checks. If you're interested, here it is: http://www.mymedtrans.com/personal.htm You might find elements here that might help you. Jim Vincent CFIG N483SZ illspam |
What's wrong with the standard procedure where the pilots move the stick and
the assistance hold the control surfaces?? Often the assistance is not a pilot, so putting him in a cockpit expecting him to operate stick and rudder is too much. My wife wouldn't even reach the rudder pedals. I much rather move the stick and rudder myself while giving the assistance simple instructions. All the assistance needs to do is apply pressure in the right direction while the pilot moves the stick to full deflection each direction. By moving the stick myself I can ensure it feels right and have a full travel. Don't get me wrong, I am strongly advocating PCC and never skip it, but I can't think of any reason why on earth I would trust a bystander to seat in my cockpit, and do the pilots job. Ramy "Herbert Kilian" wrote in message ... Jim, Very good and complete presentation, I agree with all you are saying. Interesting that you recommend a practice that I rarely see in this country - in fact when rigging at a contest site I feel like my wife and I are the only ones doing it right: Assistant SITS in cockpit, PIC is walking around the plane moving/holding control surfaces giving instructions to the assistant. The normal picture I observe is that the pilot is in the glider, parachute and harness on and ready to go and some bystander is told to hold onto the control surface while the pilot vigorously shakes the stick or whatever. Rudder is never subject to being tested. Even worse is the situation when the pilot stands outside the cockpit rattling the stick while some poor schmock tries to keep the aileron or elevator from banging against the stops. All you instructors out there, this is very bad practice and someone must have been teaching it to the US glider population. Herb, J7 illspam (Jim Vincent) wrote in message ... In my experience, many people do not cover all the critical elements of doing a crontrol check. I recently gave a presentation on positive control checks, critical assembly checks, preflight checks and other checks. If you're interested, here it is: http://www.mymedtrans.com/personal.htm You might find elements here that might help you. Jim Vincent CFIG N483SZ illspam |
ELT Checks | Kevin Chandler | Owning | 28 | September 16th 10 02:47 PM |
Formation flying | Bingo | Home Built | 21 | August 23rd 04 12:51 AM |
~ 8 MORE DEAD US SOLDIERS - 93 IN APRIL SO FAR - BUSH CHECKS TURKEY | MORRIS434 | Military Aviation | 0 | April 22nd 04 09:44 AM |
A couple Questions-Ramp Checks and Experimental Operations | Badwater Bill | Home Built | 48 | October 8th 03 09:11 PM |
Flight Checks | Mark Jackson | Instrument Flight Rules | 5 | September 24th 03 06:39 PM |
