X-no-archive: yes
In article , Eric Greenwell writes Greg Arnold wrote: Brian Iten's file with the high noise reading in on the OLC site for April 4, if anyone wants to look at it. I think we need the original file (.cai format) from the logger. The noise recordings look much too high for gear down noise. What program was used to produce the IGC file from the CAI file? If it was the cai2igc.exe, perhaps that program does not rescale the engine noise level to the IGC values? I have has a look at Brian's .IGC file and it show maximum values of 195, which suggests that any rescaling is being done by the viewing program and not on conversion to .IGC format. The download was done using SeeYou. What I do see is that the maximum value of 195 (equivalent to 999 on any other recorder, and top-of-scale for Cambridge 10/20/25) is reached and sustained (flat tops to ENL graph) during both Take-off/Tow and final stage of flight to landing (presumably when the wheel was down), as well as occasionally during what I take to be urination. The ENL on this recorder is abnormally high. A new design of recorder showing these characteristics would not get IGC approval. I would guess that the ENL system on this recorder is in need of adjustment/repair. Best regards, Tim Newport-Peace. Technical Advisor to Global Navigation Satellite System Flight Recorder Approval Committee (GFAC) of the International Gliding Commission of the Federation Aeronautique Internationale |
Buying an L-2 | Robert M. Gary | Piloting | 13 | May 25th 04 04:03 AM |
FA: 5 Airplane Model Kits - Bomber, Jet, Warbird | Disgo | Aviation Marketplace | 0 | February 22nd 04 05:00 PM |
How much could I get for these back issues? | Aaron Smith | Home Built | 8 | December 15th 03 12:07 PM |
Updated IGC approval documents for Cambridge GNSS flight recorders | Ian Strachan | Soaring | 0 | August 27th 03 05:28 PM |
Cambridge GPS-NAV Model 10 DB9 Pinout | Terry Healy | Soaring | 1 | August 11th 03 05:54 PM |
