Questions for any iPaq users out there
Old April 7th 04, 06:01 AM
Ted Wagner
Default Questions for any iPaq users out there
1. I have an iPaq series 55xx and I can't make out the display outdoors, or
in the cockpit. (Yes, I have the brightness set to max.) Is this typical of
iPaqs? Are the older iPaqs brighter? Do I have an "off" unit?
2. What hardware do I need to connect the iPaq to my LX5000 to use the
Downloader program? (Note: My glider already has a Pocket PC mount, in which
the iPaq gets power and a connection to the LX5000 for the GPS stream. But
it doesn't work for Downloader. I want to connect the iPaq to the 5-pin
instrument panel serial connection so I can download the .igc files to the
iPaq.)
Advance thanks --
ted/2NO
Old April 7th 04, 01:21 PM
Jim Kelly
All iPaq displays are very difficult to read in sunlight (despite
the marketing hype . . ). I have anguished over this for ages. There
is a filter that helps greatly, but still nowhere near tolerable.
Many have tried other filters but this seems to be the best as it
stops reflections:
ClearTouch screen protection:
http://www.boxwave.com/products/clea...t3_ipaq_39.htm
us$13 or us$28/3 plus $6 freight, or at:
http://www.craggyaero.com/screen_protectors.htm
Most of us turn the map off which increases the readability markedly
(you can turn it on easily as needed).
At least the H5xxx that you have has the bigger display. Many folks
have been lured into the lower priced models that have 15% less
area!
Hope this helps?
Happy Easter to all.
Cheers,
Jim Kelly
"Ted Wagner" wrote in message
ws.com...
outdoors, or
typical of
in which
stream. But
5-pin
to the
iPaq.)
Advance thanks --
ted/2NO
Old April 7th 04, 01:40 PM
G.Kurek
"Ted Wagner" wrote in message ews.com...
I use Ipaq 3970 with Anywhere map, as for the usage in Cezznaz the
dammed thing is shaking so much that I'm not able to see anything
anyhow, but I don't recall having problems in the glider where I don't
use any brightness and I'm able to see it (on sunny days), I thought
that brightness on mine is more than enough.
iPaq.)
Advance thanks --
ted/2NO
I'm still renting...
Old April 7th 04, 03:25 PM
Bert Willing
I run an Ipaq 3950 - no problems with visibility at all.
Bert Willing
ASW20 "TW"
"G.Kurek" a écrit dans le message de
om...
ews.com...
or
of
which
But
iPaq.)
Advance thanks --
ted/2NO
Old April 7th 04, 02:46 PM
cernauta
iPaq.)
Most probably, your current connection is nearly perfect. You only
miss the connection for reverse communication: the "out" pin of the
Ipaq must be connected to the "in" pin of the Filser.
You must have this sorted out.
bye
Aldo Cernezzi
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 September 2nd 04 05:15 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 03:04 PM
iPaq wiring, cradles and mounts for gliders - Ideas?? Jim Kelly Soaring 12 December 4th 03 11:45 PM
iPAQ h2210/h2215 Review Paul Remde Soaring 0 September 3rd 03 03:45 AM
iPaq screen viewability Raphael Warshaw Soaring 7 July 27th 03 06:02 PM
