"Ted Wagner" wrote in message ews.com...
1. I have an iPaq series 55xx and I can't make out the display outdoors, or in the cockpit. (Yes, I have the brightness set to max.) Is this typical of iPaqs? Are the older iPaqs brighter? Do I have an "off" unit? I use Ipaq 3970 with Anywhere map, as for the usage in Cezznaz the dammed thing is shaking so much that I'm not able to see anything anyhow, but I don't recall having problems in the glider where I don't use any brightness and I'm able to see it (on sunny days), I thought that brightness on mine is more than enough. 2. What hardware do I need to connect the iPaq to my LX5000 to use the Downloader program? (Note: My glider already has a Pocket PC mount, in which the iPaq gets power and a connection to the LX5000 for the GPS stream. But it doesn't work for Downloader. I want to connect the iPaq to the 5-pin instrument panel serial connection so I can download the .igc files to the iPaq.) Advance thanks -- ted/2NO I'm still renting... |
I run an Ipaq 3950 - no problems with visibility at all.
-- Bert Willing ASW20 "TW" "G.Kurek" a écrit dans le message de om... "Ted Wagner" wrote in message ews.com... 1. I have an iPaq series 55xx and I can't make out the display outdoors, or in the cockpit. (Yes, I have the brightness set to max.) Is this typical of iPaqs? Are the older iPaqs brighter? Do I have an "off" unit? I use Ipaq 3970 with Anywhere map, as for the usage in Cezznaz the dammed thing is shaking so much that I'm not able to see anything anyhow, but I don't recall having problems in the glider where I don't use any brightness and I'm able to see it (on sunny days), I thought that brightness on mine is more than enough. 2. What hardware do I need to connect the iPaq to my LX5000 to use the Downloader program? (Note: My glider already has a Pocket PC mount, in which the iPaq gets power and a connection to the LX5000 for the GPS stream. But it doesn't work for Downloader. I want to connect the iPaq to the 5-pin instrument panel serial connection so I can download the .igc files to the iPaq.) Advance thanks -- ted/2NO I'm still renting... |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 05:15 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
iPaq wiring, cradles and mounts for gliders - Ideas?? | Jim Kelly | Soaring | 12 | December 4th 03 11:45 PM |
iPAQ h2210/h2215 Review | Paul Remde | Soaring | 0 | September 3rd 03 03:45 AM |
iPaq screen viewability | Raphael Warshaw | Soaring | 7 | July 27th 03 06:02 PM |
